Question about Canon PowerShot G9 Digital Camera
Cana powershot g9 memory card kocked
I tried 2 new memory cards n i cant get to format them cause it keep showing memory card locked but i made sure both cards work opened nn i still get the same problem but those two same card works in my aunt cam n she and the same model as mines,can some one help me
  • hotbread756 Feb 01, 2009
    hey i did that,thats what i was saying but it still saying its locked
  • reecied May 11, 2010
    this was awesome advice! thank you
  • 4,806 Answers
Hi there
The card may be in write protect mode, take the card out and look around the edges for a small lock, like this >>>>>>cana powershot g9 memory card kocked - 528f45e.jpg
put the card back in the camera and you should be good to go.
Thanks for using Fixya!!!
Posted on Feb 01, 2009
Canon g9 just started getting card locked error. I checked, the card is not locked - also tried different cards. It works sometimes. Tried to reset the settings and received "busy" message.
Check the right strap lug and see if it is loose. It is a well know problem with the G9 that the screws that hold it onto the top cover come lose and fall into the camera, causing many different problems is they short out parts of the circuit
Feb 17, 2013 | Canon PowerShot G9 Digital Camera
I have a Canon PowerShot G9 camera. When i plug it into usb cord to dowload pictures, i get the error message "Communication Error" across the viewing screen of the camera.
The problem I believe is the sequence or flow of the connection.
With the camera turned off. Connect the USB cable to a computer USB port and the other end to the camera digital port turn the camera on by using the "Playback" button here is a diagram
Place diagram here
You know there is an easier and better way of transferring picture files and that's by using a memory card reader. A memory card reader plugs into the USB port of a computer and the camera memory card is inserted into the reader slot. The computer then looks at this as an external Hard Drive. Both methods will need you to format the memory card after the images have been downloaded to the computer. Formatting the memory card in the camera in which it is to be used will clean the card and making it compatible with the camera both the camera and memory card can then communicate without errors.
Jan 16, 2011 | Canon PowerShot G9 Digital Camera
Will not read the memory card .keeps saying no memory card and cannot record when ever you try to take a picture
Possibly the SD or SDHC memory card has been locked here is a diagram of a memory card in the two positions.
Also a new memory card will need to be formatted to the camera before the camera can properly communicate with the memory card.
Diagram
Here is a screen shot of the Format page showing the menus
Diagram
Have fun
Jan 12, 2011 | Canon PowerShot SX10 IS Digital Camera
Doesn't detect memory card
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the switch on the side of the card, or the switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Jun 15, 2010 | Canon PowerShot G9 Digital Camera
After inserted A new batteries in the screen shows card locked how I can fix that
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
May 15, 2010 | Canon Powershot SX110 IS Digital Camera...
Formatting memory card
First of all, yes, you will lose your pics if you format the card now. Get a card reader and download the pics to your computer. If you've used 1.7GB on a 2GB card, it may very well be full since the camera uses part of the card to write the files.
Feb 17, 2010 | Canon PowerShot G9 Digital Camera
G9 memory card locked
Have you tried sliding the small protection lock switch on the side of the memory card?
Jun 19, 2009 | Canon PowerShot G9 Digital Camera
Canon G9 camera and G7 similar problem... checked out memory cards and they were reformatted. cards work fine in other digital carmeras I own. Can not get either camera to read a memory card
Usually this means there is a problem with the memory card part in the camera that reads the card. When this happens it will usually say either memory card error or card locked, even when the card is fine. Try emailing this site for help with this: www.camerasandparts.com All they help with are the Canon Powershot cameras and they're excellent for help with these models. Good luck with it. They'd be the place that could help with this.
Dec 31, 2008 | Canon PowerShot G9 Digital Camera
Can't format 2Gb Extreme III SD card in Canon G9 camera
bad card trash it and get new one changeing formats will cause errors most camera's use their own format if u cange it from one to the other so many time it burns card out
Dec 28, 2008 | SanDisk Memory Media
Canon PowerShot G9 Digital Camera Logo
104 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
