Question about Traxxas Rc Revo Nitro Monster Truck
Wheels spinning when starting
When i start my revo it takes off if i dont keep the gas pulled it dies ive tried to set the idile is there anything else i can try this truck ic only two weeks old just started this all at once
    Problem Solver:
  • 11 Answers
The problem is your clutch not the slipper clutch but your clutch that is against your flywheel on the engige,What has happened is that the spring that goes around the clutch shoes has broken or came loose.That causes the clutch shoes to not disengage from the slipper and transmission, therefore when you start the truck it wants to drive forward usually it wont run or idle unless you apply the throttle. Sometimes it will stick in second gear and when you start it you give it throttle to keep it running and it takes off in second at a low idle.To solve this remove the engine and the clutch and i bet you will find that the spring is broke or came off.
If your slipper clutch needs adjusted usually you will apply throttle and all that happens is that your engine rebs up and the truck wont go forward unless you really reb it up and that is not good on the engine.
When revos are 2-3 weeks old it is common for the slipper to need adjusted a 1/4 to 1/2 turn,traxxas keeps them adjusted really loose from the factory that is why a lot of people have trouble trying to pull i wheelie with a revo.
Posted on Sep 05, 2009
  • 99 Answers
Sounds like the high speed and low speed needle settings are off. Try setting them back to factory settings (they may have rattled out of place during shipping) where the high speed needle is supposed to be around 4 full turns out from completely closed and the low speed needle is supposed to be flush with the inner ring of the slide. Check out your manual for more specific tuning methods. Most likely, you'll have to richen (counter-clockwise[lefty loosy]) both the high speed (first) then the low speed needles. Then once the needles are set you can adjust the throttle stop (idle screw). If you are still having problems, and you're near the Columbia, MO area, I work on traxxas trucks especially the 3.3 engine. I have a T-maxx 3.3 myself. Don't forget the after-run procedures! Everytime! Hope I could help you out.
Posted on Feb 26, 2009
  • wraith0127 Feb 26, 2009
    By the way, I've been working on r/c vehicles for a while. I'm just new to FixYa!
    Problem Solver:
  • 10 Answers
Have you tried to adjust the throttle trim on the remote?
Posted on Jun 02, 2009
Gas problems?
Jun 14, 2013 | 2011 Yamaha Stryker
1997 chevy cavalier
Take it back and get your money back ,you have bought a pig in a poke here
May 18, 2013 | 1996 Pontiac Grand Am
Sputtered out and now it won't stay running; dies when put in gear.
Mass air flow , crank sensor . I wouldn't discount anything . Having a scan tool that can view engine sensor data would be a great help too , testing fuel pressure and flow and back pressure test the exhaust .
058 Engine Hard to Start or No Start Lean Fuel Condition
055 Engine Hard to Start or No Start Scan Data for EGR
057 Engine Hard to Start or No Start Ignition Module Test
007 Catalytic Converter Testing
Jun 10, 2017 | 1999 Buick Regal LS
Starts but won't stay running
sounds like a bad throttle position sensor or a fuel pressure regulator. also check the idle air control vavle
Nov 05, 2012 | 2002 Oldsmobile Silhouette
2007 kawasaki Ninja 250r Cranks but wont startt
It sounds like the float needle valves are lletting gas run into the bowl,in turn running gas into the motor,and fouling the spark plugs. Have you noticed if the oil level seems to be going UP,or the fuel level is going down? Kawasaki motorcycles are prone to leaking needle valves in the carbs for some reason. And the longer it sits,the worse its going to get.Try this,...pull the spark plugs and see if they are wet with fuel.Then,unhook the coils,and spin the motor over with the plugs out.If it shoots raw fuel about a foot out of each or ANY cylinder,then that is your problem. JUST BE SURE TO DISABLE THE COILS BEFORE SPINNING MOTOR OVER,AND DONT BE CLOSE TO THE PLUG HOLES WHEN YOU SPIN IT OVER!!
Good Luck!
Sep 26, 2012 | 2007 kawasaki Ninja 250R
My 2002 honda civic lx died on my going down the road. i pulled over and tried to restart it. it started and then bogged down and died. ive been able to start it repeatedly but it continues to bogg down...
Fuel pressure test is usually carried out with the engine off by bypassing the fuel pump relay.
If the cutting out is caused by anything covered by the engine management a code should be stored in the obd memory. I suggest you have a code read first.
Sep 12, 2017 | Honda Cars & Trucks
I have a kawasaki lakota 300 (2001) It starts and runs with the choke on soon as i turn choke off it dies idle adjustment screww does nothing. I can here that it is working. Ive ran it up and down the...
You need to take off your carburetor , disassemble it, and clean the jets (specifically the slow jet) and the passageways in the carburetor body that feed the gas to the carburetor throat. Carefully set your air screw setting back to stock setting. and reassemble. Inspect the intake manifold and air box tubes for cracks and separations. That should get you idling again.
Oct 06, 2010 | kawasaki KLX 300 Motorcycles
Starts but takes a few seconds to start
Hey there jonablac,
well if it starts and then takes a minute to start up all the way from trying to die or cut out the you need to turn up you engines idle speed or if it starts then dies and won't start again wait a couple of minutes and then try to start it back up beacuase it could mean your engine has gotten a little flooded or you don't have you vehicle's engine idiling speed adjusted fast enough.
I hope this helps,
Shadowy Ace
Aug 20, 2010 | 1999 Chevrolet Silverado 1500
Fuel pump reset
well ive never heard of a reset for a fuel pump but if you put your ear to the gas tank and have someone turn the key on (not start) and see if you hear a buzzing sound if you dont then the pump is bad.
May 09, 2010 | 1992 Toyota Previa
Traxxas Rc Revo Nitro Monster Truck Logo
1,560 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
John mullen
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
