I tried to start it up still won't start , lights and everything is working has gas , turns over but won't start
Timing belt probably slip or broken throwing off valve timing.if you getting fuel and spark more likely timing belt.timing belt need replacing every 60000 miles intervals.
best to get vechicle code scan first before spending alot of money.i had a vechicle years ago i was driving timing belt broke while i was driving vechicle shut down like run out of gas.it would turn over but not crank.my car was a old car i had 1977 chevy monza it had timing belt also but your vechicle has on board computer best to do a code scan first before spending a lot of money.
HEY JONAH ,THANKS A LOT I GOT 3 SOLUTIONS TO MY PROBLEM I THANK ALL THE GUYS BUT YOU WERE ON THE MONEY IT WAS THE TIMIN BELT , DARN THING COST ME MORE MONEY THAN I HAD BUT I NEED MY BABY GIRL SHE HAS NEVER FAILED ME , SHE BROKE AT HOME THANK GOD . NOW THERE IS A PROBLEM I AM HAVING MY SRS LIGHT IS ON AND MY PASSENGER AIRBAG LITE IS ON , I HAVE NO LIGHT ON MY GEAR SHIFT AND CD PLAYER CAN YOU MAYBE TELL ME WHAT IS THE PROBLEM , HOPEFULLY IT'S SOME FUSES
sound like fuse blowed got too many things not working..
Check the simplest first before going to examine further. In this case battery isnt the culprit, and fuel neither. The first thing if we are in this condition which can help, is to check cooling system ie: water in radiator. I had experienced it once. The second simple check is to check cranking sound. If no sound, then its will lead to some early conclusion, batt has no enuff power to crank.
THANKS I AM ONLY A GIRL BUT I THOUGHT SPARK PLUGS ALSO . THE CRANK IS STRONG EVERYTHING IS SUPER STRONG BUT NO GO , I BOUGHT DIAMON BRAND NEW OVER 5 YEARS AGO PAID CASH AND NEVER HAD A PROBLEM UNTIL NOW I AM IN DISTRESS
TIMING BELT
Fuse for fuel pump.
Fuel filter,air filter,spark plugs,crankshaft sensor,any codes.
battery could be bad conection ,battery must have 12.5V.loose bolts on battery and clean wire brush,how you know evreythink is good.
TIMING BELT
I did a spark test& a fuel test from rail so leaning towards time?
could be fuel pump
first scann for any codes.
check for spark at spark plugs
HEY GUYS THANKS A LOT FOR ALL OF YOUR OPIONS AND SUGGESTIONS , TURNED OUT TO BE THE TIMING BELT , WHEN I GET IN TROUBLE I AM GOING TO GET YOU GUYS ON THE NET BEFORE I PAY A SOLUTION I WILL ALREADY HAVE A SOLUTION ... YOU GUYS WERE GREAT THANKS A MILLON ............ PATRICIA ARANA
Hi what mileage was.
