Question about PC Chips MB PCCHIPS M863G V5.1C w/XP2400+ Motherboard
Upgrade memory I have an m863G V5.1 motherboard. How can I find out what is the maximum amount and type of memory I can use? I currently have 2, 256mb kingston memory sticks
  • mrtonyla13 Feb 01, 2009
    Thank you so much
  • PC Chips Master
  • 4,806 Answers
Hi there
The motherboard supports 2BG DDR SDRAM memory, 1BG each slot, make sure the memory clock speed is no higher than 400 MHz.
Thanks for using Fixya!!!
Posted on Feb 01, 2009
Gt5082 what is the best sticks for gateway gt5082
Memory Upgrade for Gateway GT5082 Computer, the Gateway GT5082
Computer takes the PC3200 DDR SDRAM DIMMs. Supports Dual Channel DDR. Memory
Type, and comes installed with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) of Memory. You can upgrade your
Gateway GT5082 Computer to up to a maximum of 4.0 GB Memory, the system has 4 sockets to install Memory, already with 2.0 GB = 512 MB (removable) + 512 MB (removable) + 512 MB (removable) + 512 MB (removable) standard Memory installed.
For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
Choose the following Memory Upgrade for Gateway GT5082 Computer.
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope it helps
Apr 14, 2012 | A-Data Technology 1GB kit (512MBX2)...
I currently use 256 mb ram,I want change 1 gb ram,pls ur opinion
Upgrading RAM on your ASUS P4B-MX Motherboards is easy, we carry compatible RAM Upgrade for ASUS P4B-MX Motherboards, the ASUS P4B-MX Motherboards takes the PC100/133 SDRAM DIMMs.
Supports ECC RAM Type, and comes installed with 0 MB (removable) of RAM. You can upgrade your ASUS P4B-MX Motherboards to up to a maximum of 3.0 GB RAM, the Motherboards has 3 sockets to install RAM, already with 0 MB (removable) standard RAM installed. For best Motherboards performance use the maximum amount of allowed RAM per slot for your system.
Buy our Motherboards RAM with confidence, we provide lifetime warranty on all RAM Modules purchased, backed with an excelled customer support. Choose the following RAM Upgrade for ASUS P4B-MX Motherboards.
hope this helps you
Mar 20, 2012 | ASUS Intel 845 Chipset P4B-FX Motherboard
I want to increase the memory ram for my HP Pavillion a 335 w , on my research so far I found that the largest memory it takes is the 512, it already has 1 gyga, in it, so I assume it has 2 512, I would...
the maximum amount of RAM for that pc is 1GB so upgrading isn't possible if you wanted to upgrade the speed of the RAM the maximum speed is 333 MHz which is not very fast so i would assume that's what the current RAMs speed is.
Apr 01, 2011 | Computers & Internet
I want to upgrade my RAM and I'm not sure what I need
Go to www.crucial.com and download their program, this program will scan your system and tell you
what type of memory your system uses, amount installed, maximum that can be installed...
Feb 04, 2011 | ASUS Computers & Internet
How many slots for dram chipsets? For AZ11/ AZ31 motherboard? Thanks!
FIC AZ11 (First International Computer {Inc}
3 Ram Memory slots.
Supports SDR Sdram at 100MegaHertz, or 133MHz. (PC100, and PC133 respectively)
Maximum Total Amount is 1.5GB
Maximum Amount for EACH ram memory slot is 512MB. (1/2GB.)
Uses the VIA KT133 motherboard chipset,
(Northbridge - VIA VT8363
Southbridge - VIA VT82C686A/B)
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
Socket A processor socket for AMD processors. (Also referred to as Socket 462)
http://www.xbitlabs.com/articles/mainboards/display/fic-az11.html#
FIC AZ31
3 Ram Memory slots
Same type of ram memory as above, same total amount, and amount for each ram memory slot.
Uses the VIA KT133A motherboard chipset.
(Northbridge - VT8363A
Southbridge - VT82C686B
Socket A processor socket.
http://en.wikipedia.org/wiki/Socket_A
http://www.baber.com/baber/411/fic_az31.htm
Oct 30, 2010 | FIC AZ 11E Motherboard
Does this motherboard support ddr400
Yes, this does support ddr400, there are two memotry sockets on the board they will hold 1 gig each you could try a 2gig stick in each but according to the spec on the board it only takes upto 2gigs of ram.
Jan 31, 2010 | Intel D845GVSR Motherboard
What is the maximum memory I can install on MSI N1996 motherboard
Windows XP (32 bit OS) can only use 4GB maximum (2 E32) and actually uses a little less than that as it uses a portion of that memory for housekeeping and internal operations. The N1996 is not the model number of the motherboard however, according to MSI's website it is one of the supplier codes. I find going to the following website and running the "scan my system" option will let you now exactly the kind and amount of memory your computer can use. www.crucial.com
Jan 26, 2010 | Intel Motherboard
Best Graphics Card, RAM for D101GGc
go for the nvidia geforce 8500, your board Support for up to 2 GB of system memory so no 4GB( too bad)
Jan 27, 2009 | Intel D101GGC Motherboard
Upgrading to 2 GB Memory - only one DIMM recognized?
have you booted your computer into bios and see what it tells you there
Aug 19, 2008 | PC Chips MB PCCHIPS M863G V5.1C w/XP2400+...
Upgrading/Identifying Pcb Inputs
Your mobo will take a pentium 4 socket 478 processor, what Ghz you want it upto you, i think they went upto 2.8Ghz but i could be wrong. This is an old socket type board so you may be better upgrading it or try the internet for a supplier. The max amount of memory you can use is 2GB of DDR memory 266MHZ or commonly known as PC2100.
Feb 11, 2007 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
97 people viewed this question
Top PC Chips Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Steven Burn
Steven Burn
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
