Question about Sanyo DS24424 24" TV
How to replace fuse on sanyo tv DS 24424
I can't find where the fuse is to replace it. My tv quit working, and we are almost positive it is just the fuse. I would like to know where exactly is the fuse inside the tv? Or is there a site that has the manual or shows a picture of the inside of the tv and which fuse to replace?
    Scholar:
  • 125 Answers
Actually, when a fuse blows, most of the time there is something that went bad and is causing the fuse to blow. Some TVs don't use the typical glass fuses. Instead the might use a surface mount soldered component. These components are usually labeled with the letter F for fuse. Example would be F1 or F2. They are usually found near the power cord or near the power supply. Hope this helps...
Posted on Mar 15, 2009
Sanyo 50 tv DP50741 speakers quit working
Make sure your audio setup hasn't changed. You can select where the audio goes in setup. If everything is correct, then the main board needs to be replaced. You can get it here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Dec 05, 2016 | Sanyo Dp50741
Digital?
No sorry to dissapoint DS is short for Definition STANDARD ... and is a cheap 20 inch model assigned to category 2 of televisions. To improve its reception you could apply a Digital setop box to it to get all the additional channels seen on a Digital. Probably last longer than most new plasmas and LCD's as this is quite a robust little TV.
Please rate my help++++Thanks for using FIXYA
Nov 28, 2009 | Sanyo DS20930 20" TV
Remote works sometime but not always
1. replace with fresh alkyline batteries.
2. If you have fluorescent lights, they will interfere with the remote.
3. Turn OFF lights, remote will work. Turn ON lights, the remote may not work well.
The "code" depends on the Remote brand/model.
Different maufacturers of remote control units don't use the same code numbers (there is no standard remote code for any TV).
Hope this helps!
Sep 08, 2009 | Sanyo DS27510 27" TV
Do I need converter for Sanyo DS24424A manufactured in 2005.
hiya
what you may need is a freeview box unless ur tv has in built digital
rik
Feb 24, 2009 | Sanyo HT27546 TV
Programing remote control
Since you obtained a used TV, there probably wasn't an owner's manual with it. Here is the site where you can read and/or print the manual. http://www.sanyoservice.com/pdf/images/DS27510(OM)_excluded_French.pdf
On page 6 in the Quick Tips column, the second tip states: If the remote control does not work: Press TV key (see item 1).
Good luck resolving your problem.
Jan 29, 2009 | Sanyo DS27510 27" TV
Sanyo ds-25350 TV won't turn on, just clicks twice
Sanyo ds-25350 ? Not recognising that model number.
Sep 16, 2017 | Televison & Video
DS 27930 remote control
My problem is this TV of ours does not work now so if I cannot get it fixed I guess you can buy our remote control.
Doopey
Feb 17, 2008 | Sanyo DS27930 27" TV
Is it an anaolog
The Sanyo DS 13310 TV is a standard NTSC TV with a 181-channel PLL tuning system1.gif....which means that it is not digital.
Jan 27, 2008 | Televison & Video
Sanyo DS 31520
make sure your got the right cable mode selected through the remote or autual switch on back of tv. if not it youll only see cable channels up to channel 13 that means in is standard tv mode or air. once you selected cable ...run autoprogram and it find all the channels for you. these newer sets, dont bother with looking for a cable switch, its all done automaticly when you hit that autoprogram button but it would be in the menu under setup.
Sep 06, 2007 | Sanyo DS31520 31" TV
TV SANYO MODEL DS 25390
It would be a waste to take this TV to Brazil, as this is not a Multi system TV, and will not recieve PAL M broadcasts.
May 29, 2007 | Sanyo DS25390 TV
Sanyo DS24424 24" TV Logo
1,046 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
