Fisher stero cassette deck CRW47H the little drive belts from the motor to the tape drive have disolved. are replacements available
  • 336 Answers
Your best bet is to get generic replacement belts at www.mcmelectronics.com You will have to measure each belt's length and diameter, also width if its a flat belt.
Posted on Feb 01, 2009
I turn the unit on I have power to the unit. I put a tape in to play and the tape does not play. nothing happens. the last time I used it was about one year ago.is there some kind of belt drive motor or...
The belt drive unit is only ran by a SMALL rubber band. It may be that the actual band is broken or the motor itself is shot. Unplug the stereo from the wall and remove the cover CAREFULLY, look in at the tape drive and check the "RUBBER BAND" first.
Mar 16, 2008 | Audio Players & Recorders
Why don't tape decks play?
If your X-10 has a separate drive motor for the capstan , it could be weak and in need of replacement.
The C-3X could have belt drive and the belts could be weak and in need of replacement.
Jan 03, 2016 | Teac Audio Players & Recorders
RS-X501 DOUBLE CASSETTE DECK PROBLEM WITH TAPE DRIVE ON BOTH DECKS
Usually the fault is the failure of the BELT on the mechanism. You will need to remove the covers to have a look on the motor drive behind the mechanism of the tape drive. Thebelt can be changed if you are technically capable to remove and reset the mechanism.
May 06, 2011 | Technics RS-TR272 Single Cassette Deck
RUBBER DRIVE BELT FOR A360 FOR TEAC CASSETTE DECK
Drive belts on tape decks are mostly universal. You only need to measure the diameter of each belt in mm and then enter the result in Google as "Cassette drive belt ??mm".
Mar 13, 2011 | Teac W-865R Single Cassette Deck
My Nakamishi Cassette Deck 2 is eating tape. It switches off when it does, but how can I fix this? From the look of it this cassette deck has the same cassette drive as the DR-8. Is that correct?
It could be the take up spindle does not have enough torque causing the tape to bunch up after the capstan. If you open up the unit you will notice ether belts or rollers for the tape drive. If it has belts you can replace the belt after cleaning the pulleys. If it has rollers you may be able to clean them with a rubber cleaner (not alcohol which will dry the rubber and cause glazing). Make sure the capstan and the pinch roller is clean using a rubber revitalizing cleaner on the pinch roller. "Goof off" from a hardware store is great for the capstan if it has a lot of metal oxide on it.
Feb 24, 2011 | Nakamichi DR 8 Single Dual Cassette Deck
Tape reel on either deck stops and tape gets jammed. This is on a Tascam dual cassette deck model 322.
Try replacing the belt, because when the belt is a bit old it looses its elasticity and it can't drive the whole thing properly.Tape A and Tape B works independently.
Jul 25, 2010 | Tascam 322 Advanced Dual Well Single...
Cassette will not exit, nor play and does a clicking soud
Cassette will not exit,eject nor play and does a clicking sound, one side of cassette door will not close.
Jun 15, 2010 | Sony TC WE835S Stereo Dual Cassette Deck...
Fisher cassette player and Fisher cd player need belts
I believe that FISHER was trade brand of Sanyo if that helps?
Mar 07, 2009 | Audio Players & Recorders
204 people viewed this question
 Grubhead
Grubhead
