Question about PfaFF Creative 7570
Sewing design thread breackage
Thread breakage ( as in 15-20 times for a 10,000 stitch design!) so I have to sew at half-speed. seems as though there would be a remedy for this. dealer replaced embroidery foot..no change..help!
    New Friend:
  • 186 Answers
Assuming that the timing, needle clearance, position finger and needle plate position are all properly set you can try the following:
1. Oil the hook (use Pfaff hook oil, it is a lighter weight than the normal white oil used on sewing machines).
2. Check the hook tip and flank for damage, buff out if possible.
3. Check the needle plate for damage and buff out.
4. Replace the needle.
This is a great machine and is worth keeping up, Pfaff doesn't make the all metal hook anymore which is a shame.
good luck!
Posted on Feb 01, 2009
I have an elna 3210 3230. Thread keeps breaking, stitch does not interlock. Help. Mary Poretta
Sounds like possibly more than one problem.
Why is my thread breaking
https://www.sewhere.com/why-is-my-thread-breaking-how-to-avoid-thread-breakage-at-your-sewing-machine
Sewing Machine Problem 1 Thread Breakage
If the top thread is not picking up the bobbin thread, it's possible the machine has been knocked out of time. Did the needle hit something or break recently? You can search for sewing machine timing or take it for service.
Dec 31, 2017 | Elna Sewing Machines
When sewing it skips stitches also the thread keeps breaking.
Remove the thread from the machine.
Install a brand new needle.
RAISE the presser foot and rethread the top thread.
Verify the thread path is correct.
Load and thread the bobbin case & install it. Verify it is correct.
Set the top tension at the midway point.
Re-test your stitch.
10 reasons for skipped stitches
Mar 22, 2017 | Sewing Machines
My mb4 is stitching designs off centered and when i started the machine it hit the hoop and broke the needle. i replaced the needle but now the thread keeps breaking?
Remove the thread and rethread. Usually, thread breakage occurs when the thread is not following the thread path. However, there could be other reasons:
Nov 14, 2016 | Sewing Machines
Upper thread keeps braking
Usually thread breakage is a result of incorrect threading or the thread tension set too tight.
Remove the upper thread. RAISE the presser foot and rethread from the beginning (verify the threading sequence is correct).
Check that the tension is set at the midway point between the high and low numbers.
Retest. If still breaking, there are other less common problems (thread/needle incompatibility, burrs or knicks catching the thread, etc) that may be the cause. Check the following web sites:
Sewing Machine Thread Keeps Breaking
Feb 11, 2016 | Brother Sewing Machines
Janome tension problem: skips stitches and breaks the thread.
Is the thread and b
needle correct for the material sewn? Otherwise the dealer or manufacturer is the best bet.
May 01, 2017 | Sewing Machines
My Husqvarna diamond top thread keeps breaking while doing loop embroidery. It sews a couple of stitches and then you can hear when the thread breaks. Ive tried changing the needle and bobbin, and cleaning...
Hello
Primary causes of upper thread breakage:
-- misthreading: pull all the thread off and thread again, using the manual, step by step. Read each step aloud before you do it. (sounds dumb, but helps.) (And make sure you thread the takeup lever!)
-- thread has wrapped itself around a thread guide or spool pin from one of the breaks. Take the spool off the machine before rethreading.
-- bad or damaged needle. Replace with the right size for the fabric, turned correctly (backwards needles skip stitches)
-- dirty machine, especially in the bobbin case area: review cleaning instructions and do it, using brush and vacuum only
-- bad/cheap thread: should not be slubby or break easy. Try another spool.
-- top thread tension too tight. 4 is normal for most fabrics, most stitches.
Tips;
1) do a light cleaning (brush and vacuum) every day you sit down to sew.
2) replace the needle if you hear it hit metal, if you've got a really bad thread jam, if you see it deflect as you sew (for instance, sewing over the side seam on jeans when hemming). Replace every 3-8 hours of actual stitching time anyhow.
3) buy good quality thread
4) when your machine isn't sewing right, stop; take all the thread off of/out of the machine (bobbin out of bobbin case, spool off spool pin) and give it a quick cleaning. Rethread from scratch, carefully. If that doesn't fix it, do it again, then replace needle and rethread one more time, manual in hand (yah, even if you've threaded it 8 million times before). #4 is curative about 98% of the time. The other 2% often requires professional attention.
Jul 11, 2011 | Husqvarna Designer I
Singer CE-150: Constant error messages, thread breakage, etc.
Check the sensor at the top of the machine. It is where the thread passes through the plastic "u-turn". Check to see if the wheel turns when you pull the thread through the machine. The wheel has a red marking on it. If the wheel isn't turning when you pull the thread, it may not be sensing the threading correctly.
I hope this helps. God bless you!
Mar 09, 2010 | Singer CE-100 Futura Computerized Sewing...
Pfaff creative half-speed and thread breaks
YIKES - what a nightmare! We can approach your problem two ways, but to determine whether the problem is your machine or your design, I need to know if you have been using one design, or if you've tried to embroidery several different designs and are getting threadbreaks about every 10,000 stitches, no matter what design, needle, thread, and bobbin you use.
Here are some rules you should following whenever you embroider on your machine:
  • Change your needle and insert a newly wound bobbin every time you start a new project
  • Use a size Embroidery Needle - size 90 for most projects
  • Check the backside of your design - you should see alot more bobbin thread than embroidery thread. If you don't see enough bobbin thread, loosen your top tension. If the tension is set automatically, change it manually.
  • Your design might be the problem. Some designs have WAY to many stitches. If you haven't already, choose several different designs with different styles - for example, a monogram, a design that is mostly satin stitches, a design that is mostly straight stitches, and so on. Sew one or all over and over so you determine whether your thread will continue to break about every 10,000 stitches.
I hope this helps. Machine embroidery is so much fun once you've learned and practiced. I hope to hear from you - machine embroidery is not hard to learn, but there is a lot to learn. Thanks.
If you want to get right to work, skip the troubleshooting and answer as many questions as you can or have time for. It is possible that your problem is the design and not the machine. Try one suggestion at time so you what helps and what doesn't. Questions first:
  1. Is the machine brand new, or new to you?
  2. Do you have your manual?
  3. Do you been embroidering by machine for a while, or are you just learning?
  4. Does this problem occur with every design you sew, or is it one particular design that you are having trouble with?
  5. How many total stitches are in the design you are trying ot sew?
  6. What kind of thread are you using (rayon, poly, sewing?)
  7. Did you buy the machine from a dealer, and if so, does it have a warranty?
  8. Have you taken lessons on how to use your machine for both sewing and embroidery?
  9. Are you familiar with embroidery backings, needles, and threads and how to choose which to use for a particular project?
Feb 01, 2009 | PfaFF Creative 7570
Thread breakage light keeps coming on
No, my problem is still not fixed, but being unemployed I can't afford to purchase a plan, I thought this information was free sorry. Thank you
Dec 27, 2008 | Singer CE-100 Futura Computerized Sewing...
Free Motion Sewing - Jams
The Designer 1 usually has a very nice free motion stitch using the V1 stitch. It should pull only slightly to the rear so that no bobbin thread shows while doing free motion embroidery. Upper tension may be increased for balanced stitch when stippling.
If your machine doesn't sew with the regular stitches with the teeth up, and it's properly threaded, the thread must be dragging on the bobbin case somewhere. First get the machine sewing a straight line, then try V1 again.
Feb 19, 2008 | Husqvarna Designer I
Sewing Machines Logo
171 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
