My Logik loglm101du hi-fi has crashed.
This morning I tried to turn it on after two years of near perfect functioning and it just wouldn't turn on. I tried ''turn it off and on again'' etc. and my dad checked the fuses and gave it a thorough seeing to and couldn't find anything wrong with it. If anyone has any ideas about how to fix it it would be greatly appreciated!
SOURCE: amp keeps blowing fuse
I have this same problem. You have blown the internal amp. I have had 2 of these do the same thing. There is nothing you can do but report it to infinity and try to get the unit replaced.
Posted on Feb 08, 2007
Krazytech
  • 725 Answers
SOURCE: Blinking "Normal" button
PROBLEM: STOPPED RUNNING, WILL NOT START AND
CLEAN LED BLINKS 7 TIMES, THEN REPEATS
(WATER HEATING FAULT)
Control is programmed to stop
running and not allow any
further cycles if it detects a
water heating problem (no
temperature increase detected
in heated Main Wash on
3 consecutive cycles). Control
blinks the Clean LED 7 times
repeatedly and disables the
Start/Resume key until
cleared.
Running Diagnostics clears the
control and allows it to operate
again. The water heating problem
must be fixed or the control will
stop running again. See potential
causes below.
Heater circuit problem:
■ Open in heater.
■ Open connection or
component in heater circuit.
■ Faulty heater drive circuit on
control.
1. Check operation of heater in
Diagnostics cycle.
2. Unplug dishwasher or disconnect
power.
3. Check resistance of heater and all
components and connections in the
water heating circuit or heat dry
circuit.
Wash pump not pumping water
past the heater efficiently.
See “WASH PUMP WILL NOT
PUMP”.
Door switch not making
contact consistently:
■ Faulty or sloppy door latch
assembly (which can be
aggravated by high door
closure force keeping strike
plate from fully seating).
■ Faulty door switch (high
resistance).
NOTE: Neutral switch on
plastic tub models is only in
series with motor and heater;
other loads are not affected.
1. Unplug dishwasher or disconnect
power.
2. Measure resistance of door
switch contacts while checking
mechanical operation of latch
assembly. Confirm switches not
loose from assembly. Check strike
plate and door closure.
Lack of water to heat. See “WILL NOT FILL OR LOW
WATER”.
PROBLEM: WON’T START AND START/RESUME K
Posted on Oct 21, 2008
SOURCE: a crashed acer aspire t671-tb7z
Try pressing F12 on boot-up. I'd recommend getting another PC as I have had multiple problems with this one. Or at least make sure you back up work regularly
Posted on Nov 07, 2008
SOURCE: have hayward pool model 712 2 no idea how to start, prime, etc.
what I do isto take the top off the filter collectot just before the motor, insert your hose and fill the line from the strainer basket to the motor basket.let it runn for acouple of minutes.quikly take out hose and screw on basket cover,turn on motor and wait about one minute.you will see pool water start to volume to motor and filter.You will have to fix the shorting out of the motot first though.since I do not know how the unit is configured ,it's hard to say.
Posted on Apr 09, 2009
mikehitchner
  • 28 Answers
SOURCE: 30 amp ignition fuse in engine compartment blows at start
It sounds like a bad ignition switch or something is grounding out.Try to isolate the problem to key positions.See if the fuse blows when you turn the key to ACC(when your dash lights come on without starting)If the fuse does not blow then when you go to start it and it blows it could be one of many problems,the more common ones could be ignition switch,wiring,starter relay,starter soleniod,or perhaps the starter itself is shorting out,this can sometimes happen when a starter goes bad.
Posted on Apr 12, 2009
Peugeot 306 52 plate,pulled out the garrage one morning all perfect,left for 30mins tried to start to go to work turns over but wouldn't start,tried everything even diognostic machine of mine and the
Did you check for fuel pressure with a gauge on motor
or scan tool, if that data is avail?
Did you put one of those HEI Spark Plug testers in a plug wire
or cop coil
Do the cams turn
I'm not into the Peugeot, but is expect you may have a timing
belt ?
You may not have data on the ignition switch & its contacts
Do you have battery voltage to the ignition & injectors with key on
Injector pulse when cranking ( crank sensor !!)
Jul 26, 2013 | Cars & Trucks
My 1999 Lexus ES300 wouldn't start this morning. There's no sound when trying to turn over...no clicking are anything. When I listen under the hood there's a slight click in the alternator
Hi Susie, Turn on the head lights and get someone to observe them while trying to start. If they dim during trying to start, replace the battery. Regards John
Aug 26, 2012 | 1999 Lexus ES 300
My SGT is brand new, only a week old and it has aldready crashed. I can't access it at all, the screen lock won't react and it's been hung up like that for over an hour now. I was listening to...
First put the charger plug in the Tab, I just tried mine that was sitting on the desk, even though I held the power on button for a long time it would not start. I pluged the charger in so the red charging light is on Tried to start and it worked perfectly. i.e. the voltage level is very critical, if it is a fraction low it won't start.
Jun 09, 2011 | Samsung Galaxy Tab Tablet PC
My computor crashed and tec removed all from computor I dont have a code for windows 7 to activate h.p. windows intel cenrrino purchesed at Hi-Fi corp approx 3 years ago
You could use System Recovery to get your PC to factory settings, and with this you'll get the OEM Windows license again, this function is available when computer boots, but if you've formatted, changed partitions or installed a different operating system, maybe System Recovery couldn't be available.
Feb 18, 2011 | HP Computers & Internet
Wi fi button
Look carefully on your "Function" keys example, F1, F2, F3 to F12 that are located above your keyboard. On each function keys, there is an icon. One of those is wi-fi. Find which function key has the wi-fi icon then find key to activate those functions. It is called "Fn" key (located in the bottom of your keyboard near "Ctrl" or "Alt"). Now press and hold "Fn" + "F#" then release. This should turn on your wi-fi. On mine, I have wi-fi on "F8" so I would press "Fn" + "F8".
Jan 12, 2010 | Computers & Internet
I have a logik loglm101du cd player and it won't come off standby
Try replacing the fuse inside, it might be just too warm where it is standing.
Sep 23, 2009 | Audio Players & Recorders
87 people viewed this question
 Grubhead
Grubhead
