Question about Pioneer DVR-640H DVD Recorder/HDD Recorder
Pionner DVR-540H-S no longer plays DVD's
My Pionner DVR-540H-S no longer plays DVD's, regardless of region or disc type, whether home-burned or shop bought. It continues to play DVD's fine. The last disc to play successfully before this problem arose was a CD which initially wouldn't play because dirty, but which played fine after I cleaned it.My guess is that this disc did some dirt damage to the lens stopping it from playing DVD's but not from playing CD's. Does anybody know how to deal with this problem. The manual recommends not using laser cleaning discs. Has anybody out there solved a similar problem before?
  • LittleVision Feb 01, 2009
    Thanks Mark, I have tried to do as advised but when I open the machine I find the disk player is completely enclosed and there is no access to the optic lens without further dismantling which I am very loathe to do. I guess they design these things to give you no chance to clean them and I will probably have to take it to a service agent and pay dearly.
    Cheers,
    éamon
    Scholar:
    New Friend:
  • 70 Answers
Little,
good day, true it's not advisable to use disc cleaner for it may also damage or scracth the optic lens inside.Possibly the optic lens of your player is either dirty caust by dust or faulty. but let's do hope it's only dust related and the only thing you can do now is to open and unscrew the upper cover of your player. Get a soft cotton buds, after dismantling the upper cover locate the optic drive lens and clean the lens by wipping it gently in circular direction. then try to play some DVD.
cheers,
mark
Posted on Feb 01, 2009
  • Mark Frederick Pavia
    Mark Frederick Pavia Feb 04, 2009
    eamon,
    could you take a picture of the inside part of the DVD player and a close pic withe the loading mechanism and send it to me so ican show you which screws to be remove and what to do. you can send the pics to workshop.fungkuei@vanuatu.com.vu or markiez23@gmail.com
    mark
MY TOSHIBA DVR MODEL DR420KU WILL NOT RECORD ON DISC. IT KEEPS GIVING AN ERROR CODE AND NOW IT WILL NOT PLAYBACK DVD-R DICS, BUT IT WILL PLAY MY DVD+R DISCS. WHAT COULD BE THE SUDDEN PROBLEM?
see the cause and remedies:
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Finally the OPU optical pickup contain lasser beam, NOT are reading the TOC from DISK+ Syscon can be defective, you must go to the repair shop TV for fix it see the diagram attached, is a complex equipment.
God bless you
Jul 16, 2012 | Toshiba RS-TX20 DVD Recorder
Selective playing of DVD's on Sharp DVD Recorder
Given that the machine will read disks it has written itself but not play regular discs, I suspect the lens assembly is slightly out of alignment and needs adjusting. This is not normally something you can do at home unless you have the correct test gear. It will need to go to a repair shop. One thing you can try before that is to clean the lens. Buy a quality (Scotch 3M, Philips ) cleaning disc and try it. Could be it's only a speck of dust on the lens.....
Aug 01, 2007 | NAD C541 CD Player
How to play region A blu ray discs on region c Blu ray player. i have bought this player in India but would like to play BD discs got for USA, and the player does not plays such disc.
The Player will not play the Blu-ray discs other than Region C.
This is because all the Blu-ray/DVD Players are designed such way that it will play only the discs that are manufactured and sold in the same country where the Player is manufactured.
You can play the discs that are "Region ALL".
However, you may try copying the content of the Region A/B Blu-ray discs to a Computer then create a video Blu-ray disc to check whether you can play them in the BDPS370.
Jul 21, 2010 | Sony BDPS370 BluRay Player
DVDs burned with Pioneer DVR-110D do not play on the same burner
Are you burning the files with a DVD+R format. Use DVD-R. Not all players will recognize DVD+R. Also, check the region that the movies are made in and see if the player can be switched to that region. Also, are you trying to burn files larger than 700 MB. If you are, in creating an iso image or copy if you are downloading the file you have to match the checksum of the original file to the downloaded one.
Jul 25, 2009 | Pioneer DVR-109 DVD±RW Dual Layer...
Burned DVDs play on PC but won't play on home player. I have 3 PC (2HPs and 1 Parts built),running XP home, pro, media. I bought 2 Samsung SH-S182 DVD±RW Dual Layer Burner, and have tried them on all 3...
Nero 6 and 7 does not provides us the facilitiy of burning the DVD in appropriate DVD Format. Instead it burns the DVD in the normal DATA Format, which is not supportable by our DVD Player. To play the DVD in our DVD Player we should burn the DVD in the appropriate DVD Burner which itself converts the extension of the movie and make it proper for a DVD Player to read it. It also adds some files to the DVD which is sometimes used by the dvd player in running the DVD.
Thank You
Vinay Ramani
INDIA
Oct 07, 2008 | Ahead Software Nero 6 Ultra Edition...
Go Video Unlock Code
check the menu settings or (setup) on the dvr 4000 to see if it has options to enable or disable parental lock or to change region settings to region 1.
also the dvds you made are they +r or -r on what brand dvd record disc on dvd-r this may solve the problem but use a quality brand disc like memorex dvd-r it is compatible with many players and recorders also make sure the disc you made on the recorder were finalized.
Jan 03, 2008 | GoVideo Go Video DVD/VCR Combo
Hp dvd player
This problem can often be caused by the DVD player software thinking it is in a region different than your discs. (DVD discs are often encoded with 'region codes' meaning a disc purchased in Asia will not work in a player expecting to see North American discs)
What can happen is the player 'forgets' where it is, and your regioned discs won't play any longer (region free discs should continue to work as will audio CDs ....)
A power surge, random cosmic ray or similar flakiness can cause a player to 'forget' what region it was designed for ....
If that is what has happened you need to 'reset' the region code.
Altho I can diagnose this, I have NO CLUE as to how to do this with a hp DVD player. Anyone out there know how to reset the region codes for this (or generically for a DVD player?)
Thanks!! //cheapz
Nov 15, 2007 | Televison & Video
TV says WRONG DISC TYPE
is the dvd a store bought disc or a burnt dvd? If the disc is a store bought disc I unfortunately can't help you. But if the dvd you are trying to play is burned from dvd burner you are most likely using the wrong type of burnable dvd. There are two types of dvd's you can burn, DVD-R and DVD+R. You need to make sure which one you dvd player can play, some play one or the other, some play both. I have also heard of some older ones that can't play any type of burned disc. Hope that helps Peter
Aug 18, 2007 | RCA T09085 9 in. TV/VCR Combo
DVD+R will not play
2 Things 1 You need to Finalize the disc to play of a DVD player check that out with your DVD burn program. 2 Check the DVD players capability with certain discs, not all payers will run 'burned disks' sometimes even the brand of disk matters or whether it is + or- type There are may variables with the DVD firmware. Finalize first the the first step.
Jul 31, 2007 | Emerson EWD7004 DVD Player
DVR doesn't read disc, says region doen't match
check the region of the new one probably it is region 4 made in china.your disc is a region one thats the reason why it cannot play on your new dvr which is a region 3 or 4.go on the web and see hw you can hack the code or burn a copy of that same disc.then try it in your new dvr.good luck
Jan 22, 2007 | Yamaha DVR-S120 DVD Player
Pioneer DVR-640H DVD Recorder/HDD Recorder Logo
491 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
