Question about Irons
Morphy richards steam generator model 42271
Have a steam generator and tried using it today but the steam is not coming through sole plate, changed the antiscale filter today as well, is there something i can do to make it work again, as not willing to buy new one, it is 3 years old.
  • 3 Answers
Is there a noise when u press the trigger? if not there is sometimes a reset button on the front of the base. failing that the problem may well be the solenoid which opens to let the water into the steaming tank which is repairable but can be awkward.
Posted on Feb 06, 2009
Why is there No steam from morphy Richards 42247 model steam generator?
It may be calcified or have lime scale. If the heater is "gummed up", it cannot heat properly. Try using either vinegar (takes longer) or an iron cleaner. You pour it in and it breaks up the scale. CLR works quite well too. Use pipe cleaners to clear out the holes in the sole plate.
Jun 02, 2014 | Morphy Richards Jet Stream 42271 Iron
Descale
Soak and/or run vinegar or CLR through it. They also make a steam iron cleaner.
May 11, 2013 | Morphy Richards Jet Stream 42271 Iron
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
There is not enough steam coming from the iron any more
YOU PROBABLY HAVE LIME BUILT UP IN YOUR IRON, TRY DESCALING LIKE YOU WOULD YOUR COFFEE MAKER.
HOPE THIS HELPS!
Sep 05, 2011 | Morphy Richards Jet Stream 42271 Iron
The iron will not steam and the standby button is constantly flashing
Always switch off the unit and allow to cool before cleaning or storing. .... If your steam generator does not work, check the following points: ... working temperature, the LOW STEAM ICON will flash whilst the heating cycle takes place ... steam. 9 When ironing is complete, press the POWER. STANDBY button.
Jul 27, 2011 | Morphy Richards Jet Stream 42271 Iron
My Morphy Richards Jetstream is about 5 or 6 years old & works fine except that when I first use the steam I get brown water marks on items. This means I have to wash them again. What can I do to solve...
Try cleaning the inside of the water holder it might just be calcium built up, use white vinegar to clear it and you'll prolly be fine. Put vinegar where you usually put the water and heat the iron up and steam the vinegar through the iron then put water, try distilled water to save this problem from happening again or try filtered water.
Jun 08, 2011 | Morphy Richards Jet Stream 42271 Iron
Steam comes out of the base system reducing the amount of steam that now comes out of the iron. The filter has been changed, could it be block with scale.
Yes it could. Try using CLR, Lime Away, both are Calcium, Lime, and Rust removers. They attack and disolve all 3 types of build ups almost instantly. You can buy eithere at most supermarkets, hardware stores. Use it on your shower heads too, it will improve water flow, Follow instructions to the letter,
May 16, 2010 | Morphy Richards Jet Stream 42271 Iron
Irons Logo
512 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
