Question about Canon i850 InkJet Photo Printer
Emptying waste tank??
Where is the ink tank and how to I open it to empty it??
  • 1,602 Answers
UNDER NIETH THE DRUM, IF YOU ARE NOT SURE GO ON LINE THE MANUFACTURE NAME MODEL TYPE MANUAL
CANON 850i INKJET PHOTO PRINTER MANAUL
ENTER
Posted on Feb 04, 2009
Where is the waste tank on a samsung CLP 300 laser printer?
Remove the waist toner bottle which is on the right of the drum as the cover is opened. Suggest emptying it inside a plastic bag to avoid breathing any of the toner dust. If you have time to make sure the container is dry inside, it may also be washed out with warm water and dried completely.
Jul 28, 2014 | Samsung CLP 300 Laser Printer
Getting a false error message that the ink/toner is empty and wastebin is full when i print to my phaser 8860 from a macbook on 10.6 (networked printer)
The waste bin full error can occur if the waste bin was not removed from the machine for over 10 seconds when it was emptied. Please remove the waste bin and wait for a full 10 to 20 seconds before replacing the Waste bin.
If the message still displays turn off the machine and leave it off for 1 minute then turn the machine back on.
Then run software update to make sure you have the latest OS updates.
Then delete the printer and re-add the printer.
Aug 04, 2011 | Xerox Phaser 8860MFP Printer
My Canon printer is pixma ip 3500. My printer is blinking and when i want to print there is a message "the ink absorber is full". Please help me what is the solution? Thank you very much.
All inkjet printers have a waste ink tank for ink which does not make it on the paper. When it's full, the printer stops working. You might be able to reset the counter in the printer, but unless you also emptied the tank, it won't help. It's like using a chip resetter to tell an empty cartridge it has ink. The "out of ink" error will go away but you still can't print. Unless you want to go through the tedious and messy process of emptying the ink tank, you are best off getting another printer. They're practically disposable today.
Mar 06, 2011 | Canon PIXMA iP3500 Printer
I emptied the waste toner and the red light is still on....samusng clp-300 which says that it is full
Sometimes just emptying the waste toner tank will not clear this fault. The printer uses a light sensor to determine when the tank is full. You will need a cotton swab and clean the part of the tank that the sensor is viewing the tank. Try to clean the clear window of the inside of the tank. It can be difficult since the placement of the window with respect to the tank opening. Other way is to try to wash out the inside of the tank with soap and water which can be messy but it will do a better job. Hope this helps.
Oct 23, 2010 | Samsung CLP 300 Laser Printer
Red alarm light blinks with message "waste ink near full" What should I do??
First, you should check the manual to see if it says anything about this condition. If not, or you lack a manual, open the cover. The print heads will probably move to the middle so you can access the cartridges. Watch what direction it came from. If you look over on that side you'll see the parking area. The waste ink reservoir is below the parking area or may be on a moving parking mechanism. You may be able to pull it out or just get it with some paper towels. There might be a special door or procedure for emptying the waste ink receptacle.
Oct 01, 2009 | Canon MultiPASS F60 All-In-One InkJet...
Epson C46 green and red lights flashing, saying parts need servic
Care to read this link
http://tricks-collections.com/2008/06/reset-epson-stylus-color-printers/
Goodluck
By the way emptying the waste bin needs disassembling of the unit then washing the ink foam.
Jul 19, 2009 | Epson Stylus C46 InkJet Printer
My Canon I550 quit printing.
An error has occurred in the printer. The number of flashes indicates the type of error, as outlined below. Check the cause and take the appropriate action.
bullet.gif Two flashes: Out of paper or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
bullet.gif Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
bullet.gif Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. However, when printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it will be a cause of trouble.
See Replacing an Ink Tank
bullet.gif Six flashes: No print head installed
Install a print head.
bullet.gif Seven flashes: Defective print head
Contact a Canon service representative.
bullet.gif Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
i_note_us.gif Note
Canon recommends to call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
bullet.gif POWER lamp flashes alternate green and orange:
An error that requires contacting a Canon service representative may have occurred.
Turn the printer off and unplug the printer from the power supply. Plug the printer back in and turn the printer back on.
If the problem remains, contact a Canon service representative.
Apr 14, 2009 | Canon BubbleJet i550 InkJet Printer
Why does everyone go quiet when I mention Epson r285 , 2 red flashing lights and service needed. Does no-one of you highly intelligent boffins know how to reset a simple printer. Ive asked and asked on...
Bit late in replying but this guide for dealing with the R285 has been up for a while now.
It tackles everything from installing a waste ink tank to resetting the waste ink counter.
Wrote the thing myself following quite a bit of interest... Hope it helps.
Apr 06, 2009 | Epson Stylus 2200 InkJet Photo Printer
2 red lights flashing service required
press maintence power and the small ink button all at the same time this will reset the printer
Apr 05, 2009 | Epson Stylus 2200 InkJet Photo Printer
Canon i850 InkJet Photo Printer Logo
159 people viewed this question
old marine
old marine
