Question about Hitachi 53UDX10B 53" Rear Projection Television
Double vision how do i set the convergence on my ultra vision
  • 42 Answers
Does the magic focus work on your set ?
If it doesn't you must replace the convergence Ic's with a kit that is available through your local parts distributor
You must replace all resistors in the kit
If you are not good at soldering and de- soldering have a local tv shop do it for you
Good luck
Posted on Feb 08, 2009
Hitachi ultra vision green and purple double vision picture about
Convergence is out, need convergence board repaired, usually bad stks, 392-110s
Jun 07, 2009 | Hitachi 60V500 60" Rear Projection...
My hitachi ultra vision television is giving a double picture
This is a common problem with rear projection TVs. It will require pulling the convergence board out of your set and replacing two large ICs and several 1 watt resistors. It can be fixed no other way.
May 17, 2009 | Hitachi ULTRAVISION L42V651 42 in. LCD...
Double vision..
Adjust the convergence in the menu. If it will not adjust then solder connections on convergence ics or ics themselves need replaced.
Apr 26, 2009 | Televison & Video
Red and Green double vision
Depending on the age of the unit. You have a convergence problem. This is not uncommon. You can contact a servicer thru this homepage and have them look at it. Convergence issues could be anywhere from 200-350 depending on your area.
Dec 17, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Samsung tv #hcm5525w is on but has double vision
The problem sounds like it is the convergence output ic's are bad. I would let a repair man fix it.
Nov 14, 2008 | Samsung HCM5525W 55" Rear Projection...
Double vision
you need to replace both convergence ICs they are STK392-110 you can get replacment ICs at the following link with free instalation intructions with pictures. Here is the link.
http://servicemanuals.vstore.ca/
Aug 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Double vision tv
MY TV WON'T COME ON? MY POWER SURGE WORKING IS WORKING.
Jun 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Double vision on my samsung HDTV 1080i
If one or more of the colors, red, green or blue have separated from each other and you can`t correct the problem using the convergence procedure as described in the users manual, that would indicate you have a convergence problem. Bad solder connections on the convergence output chips are common. If the set had a rough ride down the stairs while moving, that may have facilitated in exposing a preexisting condition. However, the most likely cause is the natural failure of one of the convergence output chips and or related components and not the move. The fix is to have a qualified technician address the problem. This is not a do it yourself job.
Feb 22, 2008 | Televison & Video
Double vision pretty much
This problem from what you are describing is a convergence issue the customer menu has a option that might help set convergence. if that doesent work a technician may have be called to adjust convergence or see what part has failed in the convergence cuicit
Feb 18, 2008 | RCA R52WM24 52" HDTV Projection Television
Double lines
There is a manual convergence setting. Press Menu until you see the option of convergence. Save settings by pressing Power until you see Save Ok. You can exit the convergence screen by pressing the PIP button. 0 reloads the convergence. It will periodically go out of wack again.
Dec 22, 2006 | Apex Digital GB4308 43" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
55 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
