Question about Dell Inspiron 1000 Notebook
Screen changes to a small box of colored lines.
My Dell inprion 1000 has been perfect, then one day the screen went blank and in a very short time after, a small box appered in the middle of the screen with about an inch margin around it. In the box there were colored lines running up and down. Now I can start it and it will do just fine for a short while then it happens again. I took it to a reair shop and in a very short time without even starting in up, was told it was the video chip and that it needed a new mortherboard, costing more than it was worth, might as well buy a new machine. I felt that they just didn't want to work on it.
What do you think?
  • 258 Answers
Check whether it is only the screen that is faulty by
connecting it via a vga monitor cable to a desktop screen.
If you do not have a friend with a desktop computer then most repair shops will do this for you.
Once connected there is a function button which will switch between the laptop screen and the monitor
If it's only the screen it may be worth fixing, circa $200
Posted on Feb 01, 2009
What causes my LG 55LS4600 55" tv to have sound but no picture.
It is a common problem for the LG model. The problem
is defective LED back lights ASSY. You have to open the display panel & replace the burned LED strips.
Jan 13, 2018 | LG Televison & Video
XPS Gen2 / M170 display issue, mind boggling
What are the BIOS versions and what are the mother board revision numbers?
Mar 10, 2014 | Dell XPS M170 Notebook
MY SONY TV LCD MODEL KF-50WE620 screen went blank. When I turn on the green light it blinks on 40-46 times every second, then turn to red color to Stand mode and blinks for 160 times, then move to power...
There is no reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
Tom Miller
Broadcast Eng
Mar 04, 2011 | Televison & Video
Different color vertical lines on screen Sony KDF-E55A20
Go to the last page of troubleshooting in the manual and perform the system reset procedure. Basically hold the Wega "arrow up" as you manually switch the TV off. It will automatically switch back on and reset. I had only vertical colored lines on the screen, with audio but no response to any remote control functions. The rest worked perfectly.
Aug 06, 2009 | Sony KDF-E55A20 55 in. LCD Television
Turned computer on one day last week and the Dell E171 flat panel monitor showed nothing but vertical lines. The mouse showed as a strange assortment of colors in a small square and the screen adjustment...
Try another monitor, then change the graphics settings to lowest possible, then reboot the PC, and see if your screen works again, if it does, check the documentation for your monitor and make sure you do NOT exceed the maximum color depth / resolution for your monitor, also, make sure not to exceed the refresh rate.
if this does not fix your monitor issue, check the cables for missing pins, freyed wireing / broken insulation.
Again, if this doesn't fix your problem, try the monitor on another PC, and if still a no-go, you may have a damaged inverter board in your monitor, or other componant / wire based issue.
If another monitor doesn't work on your computer, try swapping the graphics card out, it could very well be a dieing graphics card.
May 29, 2009 | Computers & Internet
Dell blank page keeps appearing how can I correct
Sounds like your screen saver is set to a very short period, like 1 minute or less.
Try this, Right-Click on the Desktop Wallpaper (behind the icon on the desktop, NOT on an icon), then select Properties.
When that dialog window opens, Left Click on the Screen Saver tab at the top of the window.
This will select that page of options.
On the Screen Saver page, about in the middle of the page you should see
Wait: (and a box with a number in it) minutes (check box) On resume, password protect.
I suspect that the number in the box is small, like 1 or 2, try changing this to something like 15 minutes.
Now this solution assumes your on Windows XP, this is done slightly different on Vista, please inform me if this doesnt help you!
Hope this helps you, Good Luck :)
Apr 15, 2009 | Dell Studio 1737 Laptop
Laptop video failure
Sounds like you may have "hit the problem" But to me sounds like the chip itself is no good anymore. Any chance of getting a chip off another board and replacing it?
Jan 27, 2009 | Computers & Internet
Black on bottom of screen
do me a fovor, i need your firmware version? to do this, press Input 619. in the center of the bottom of the screen, is three digits 5?.? please provide me with these numbers. you may just need firmware updates.
Sep 28, 2008 | Dell W5001C 50 in. Plasma HDTV
Screen blank
clean the connector inside de base then clean the flex (connector) bottom of the screen (silver cable) .
not fix ? change all the flex/ keypad around 60 $
Mar 10, 2008 | Motorola Mobility RAZR V3
Kogi monitor ... it goes blank
Where can I buy the power cord for my KOGI L5QX?
Feb 09, 2008 | Kogi L7CH Monitor
Dell Inspiron 1000 Notebook Logo
Alun Cox
