Question about Galaxy Radios DX-2547 40-Channels Base CB Radio
Galaxy 2547 i was wondering how i can turn up rx on my radio ..
  • 3 more comments
  • daylonrrober
    daylonrrober Feb 02, 2009
    yes i was meaning recieve gain i have a a99 and rg8 big coax and a galaxy 2547 i am new and just asking thanks
  • daylonrrober
    yes it does i have it turned all the way up my buddy has a tempo one and a car mount antenna sitting on the ground lol and can hear better than me . i have my a99 set at 57 feet .
  • daylonrrober
    yes my swr is 1.2 and he is about two miles from me the a99 is good for 11 meter sevice it said turn the rings all the way down to set swr and also to use on 11 meter band i was just wondering if from factory my radio was maybe not set up
  • daylonrrober
    daylonrrober Feb 03, 2009
    me and my friend could hear the same guy only i was not able to understand him but he could hear me so my friend played the middle man lol the radio is about two weeks old as far as needle moving no it was not but the person was about 30 miles away i hope that helped fill ya in
  • m3odq May 11, 2010
    What do you mean by rx? Are you talking about recieve gain?
    If you want to hear stations from further away, have you considered your antenna set up? This is after all, the part which "grabs" the received signal for you.
    What type of antenna do you have? What type of coax / feeder?
    M3ODQ
  • 4 Answers
On a Galaxy DX 2547 CB radio there are two RF knobs. One says RF power, this is your TX power control, turn clockwise to increase. There is another knob that is a knob within a knob that says Mic(inner knob) and RF( outer knob) the outer knob is your RX rf gain so to speak. Turn it clockwise to increase receive sensitivity. The Mic (inner knob) is your mic gain.
Posted on Sep 16, 2012
    Problem Solver:
  • 17 Answers
Is there a dial marked RX Gain? Does this radio have this feature?
M3ODQ
Posted on Feb 02, 2009
  • m3odq Feb 02, 2009
    How close is your buddy to you? Dont compare what he can hear with what you can hear. Have you checked your SWR reading? Is the antenna resonant on the frequency you want to use?
    M3ODQ
  • m3odq Feb 03, 2009
    ok, what do you mean "he can hear better than me" ? Do you mean stations from further away? or are you both hearing the same stations and he is recording a better signal on his meter?
    Are you working local stations or DX (distance)?
    When you use radio you are communicating with AUDIO (mouth and ears)
    NOT VISUAL (eyes)
    When you hear another station, grab the RX gain control and close your eyes! Now try turning up and down and LISTEN. When it sounds good your job is done.
    Forget what the meter says!
    Also, that radio has a VFO (variable frequency occilator), and not set channels like a conventional CB. So double check that you are spot on frequency.
    How old is your radio?
    There is a good chance that, with age, it has drifted off scale. Which baisicly means that when you have 27.500 00 on the screen, you could be closer to 28.000 00!
    Turn your RX gain right down.
    Have your buddy transmit on a set frequency like 27.000 00 for 2 or 3 minuites on his lowest power output.
    Set your radio to 27.000 00 also.
    Read the meter. Try to get the needle OFF full scale and aim for half way. Do this by turning the RX gain up and down.
    Now tune up and down in frequency and see where the needle peaks.
    If it peeks anywhere apart from 27.000 00 then the radio needs re-allignment
    Try that and let us know!
Galaxy 2547 off frequency
1 one thousandth of a number and you are worried. now if it said 27.18350 instead of 27.1850 then you would be off frequency.but for that little bit its not even a problem
Mar 06, 2013 | Galaxy Radios DX-2547 40-Channels Base CB...
How do I add channels to the Galaxy DX 2547
you have to buy a switch at radio shack that will let you add channels I think its a # 275-1386A .Then the fun begins . Heres where to go to get the rest of the information so if I print one thing wrong you can't yell that I told you to do it. These are the correct directions @ www.cbtricks.com look for galaxy 2547 and then look for freq conv and it all yours.
Jun 15, 2012 | Galaxy Radios DX-2547 40-Channels Base CB...
Galaxy dx 2547 base cb frequency drift problems
for upper ssb adjust L21 for 16.51250 mhz . adjust L22 for 16.50750 for lower ssb. you do have a frequency counter don't you ?
Jan 01, 2012 | Galaxy Radios DX-2547 40-Channels Base CB...
I WANT TO BUY A GALAXY 2547 CB RADIO. I FOUND ONE AND IT SAYS EXPORT USE ONLY . WHAT DOES IT MEAN, CAN I USE IT. THANKS
Normally, this radio will only work on CB frequencies. I suspect the radio has been modified to get channels below and above the regular 40. If so, the radio is no longer type-accepted by FCC. It is unlikely you would get into trouble using the radio.
....Don at NTCB, Inc.
Jun 25, 2011 | Galaxy Radios DX-2547 40-Channels Base CB...
New radio, TX/RX freq. off 7khz and clarifier non functionable
under warranty that would be cover no charge.! send it in.. The clarifier on a factory radio will only adjust the RX.. not the TX.. unless there's a "course and fine." the course would do both. the fine would be rx only
Feb 22, 2011 | Galaxy Radios DX-2547 40-Channels Base CB...
90900237 is the serial number on my galaxy 2547
According to a post in a recent forum it was made in September of 2009. I am not sure this info is accurate but it was published as such.
Jun 12, 2010 | Galaxy Radios DX-2547 40-Channels Base CB...
My galaxy 2517 (NO TX)
if you have another radio put it right next to the 2547. turn on the monitor radio with no antenna on the same channel and key the 2547. if you can hear it the final transistor is bad. let me know if that worked
Jul 18, 2009 | Galaxy Radios DX-2517 CB Radio
Galaxy 2547 no transmit
HI,
Sorry, the best I can do is recommend you to Galaxy as they are the sole repair station for your radio. ( according to them ). Here is the web link. Good Luck
Galaxy DX Radios -- Tech Support
Ed ( Radio Man )
NC Electronic
Mills, Wyoming
307-266-4675
May 04, 2008 | Galaxy Radios DX-2547 40-Channels Base CB...
Galaxy Radios DX-2547 40-Channels Base CB Radio Logo
376 people viewed this question
Top Galaxy Radios Radio Communications Experts
Steve
Steve
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
