Question about KitchenAid Architect KBRA20ERSS Bottom Freezer Refrigerator
Icemaker not functioning, water leaking from back of unit
The unit recently stopped making ice, although we were getting a sporadic layer of frozen water/ice on the bottom of the ice bucket. We pulled the unit out and found water on the floor so we removed the metal cover for the fitting and inspected the point where the water feed enters into the back of the freezer unit. We refitted the water feed tube within the fitting, making sure it was well past the spring clamp and that the clamp fit tightly around it.
However, when the water pump kicked in, we got a forceful backspray out of the entry point below the clamp. Does this mean there's a blockage? If so how do we fix? If not what else might it be? Any help would be appreciated, the unit is out of warranty.
  • mkivowitz Feb 19, 2009
    Thanks for the help, we've got ice again!
  • 30 Answers
Sounds as if the fill tube is frozen over. Pull the entire fill tube out of the refrigerator to defrost it or defrost it from the inside of the freezer.
Posted on Feb 01, 2009
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Icemaker not making ice
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking from inside of the refrigerator and we are constantly wiping off water from the floor. The icemaker isn't working.
I don't mean to sound sarcastic here but have you lifted the icemaker arm to see if the leaks stops? If it does the icemaker water inlet thru tube from the back of the unit is somehow wither not alightned with the icemaker inlet or the icemaker itself is letting water go though it.
Having said that if your unit is all froze up in the back of your freeze and the fan can no longer circulate air properly that too can cause bot the icemaker to stop working and a leak if the upper cabinet drain is iced over.
You can make sure it is not an icing / "not defrosting" problem by unplugging the unit and placing a fan blowing into the freezer section for at least 2 hours. Mind you this will only add to your water messes but it is a must do so have the mop and rags ready when you do this. Once you have done the fan routine plug it back in and see if after 8 or more hours that the leaks stop and the icemaker functions.
If after all of this it does funtion normally then you unit is not defrosting and will need to have the defrosting system checked out. NOTE after a few days (3 - 6) it most likely will start freezing up again if there is in fact a defrost problem and it will repeat the same antics in the past. Hope this was helpful.
Jan 18, 2010 | Refrigerators
We have a Maytag MSD2754ARA refrigerator and heard water leaking under it last night. We checked and it is coming from the line connected to the icemaker. The line inside is frozen solid. I have read that...
You'll need to first defrost/thaw the freezer and the water line in order to get water flowing again. This can take some time, so you might want to shut off the ice maker by lifting the ice maker bin arm, which will stop it from cycling/calling for more ice to be made.
You can try to thaw the line by using a household hair dryer, but unless you have only a small area of the water line frozen, it could take some time. That is why it is best to empty the fridge/freezer and keep the doors open and the unit off to allow for a complete defrosting of the unit. Have towels, sponges and buckets handy to get all the water.
It sounds like it could just be the frozen water line, but until you thaw it out, you can't really determine if that's all it is.
Jul 13, 2009 | Refrigerators
Maytag ice maker
ok first the dispencer doesnt affect ice production in any way onle diapencing so for get it the most common promblems will be the filter or the water valves on the back of the unit water and ice are on two different valves so because one works dont mean the other does also check the icemaker fill tube to see if its frozen a leaking icemaker water valve will cause it to freeze im also going to send you the procedure for checking the icemakermoudle its self do this after checking everything else remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Jul 22, 2008 | Maytag MSD2756G Side by Side Refrigerator
My Ice maker stopped working (no water for ice) I replaced the water supply solenoid and plugged it back in. Ever thing worked fine except when the water valve cycled open. Water began leaking from the...
Yes, the short tube that goes from the back of the refrigerator to the icemaker can freeze up solid preventing any more water to pass thru. this is caused by a bad water valve that is slowly leaking water to the icemaker.
Jul 05, 2008 | Refrigerators
Ice Maker problem
check if it has one the filter, hollow ice = lack of water flow into the icemaker
Apr 26, 2008 | Refrigerators
Maytag MS2732GRW ice maker quit
guest make sure your wire arm on icemaker is down same dandcs also for orig poster they have duel water valves one goes to door water one goes to icemaker. icemaker works a general rule more than door water so wears out faster but you have to replace both as they are a unit .other things that will stop ice production are frozen ice fill tube ,bad motor module in icemaker .check that first .if that don't solve it then reply to me and we will get deeper
Dec 31, 2007 | Maytag MSD2732GR Side by Side Refrigerator
Frigidaire Icemaker not making ice.
That on/off arm...you should be able to move it and it will likely make a small click when the switch goes on or off. That arm controls the ice making. There is also a float, is it working freely? It has a switch too. Ultimately, the water is controlled by a solenoid valve. It may be defective. Many of these units are removable to test the switches with a multimeter. Turn off the water and remove to test. Some parts are available...some parts are by the unit only.
Dec 24, 2007 | Frigidaire FRS23KF7AB Side by Side...
Ice maker is not getting water.
check and reset the temp in the ice maker freezer coils them self's
Aug 08, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
KitchenAid Architect KBRA20ERSS Bottom Freezer Refrigerator Logo
118 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
