Question about Canon MP140 PHOTO AIO All-In-One InkJet Printer
Can't install ink cartridges into Canon MP140 printer
There is no visible place for the cartridges to go they just slide arouind.
  • 1 more comment
  • Anonymous Feb 05, 2009
    damn machine!
  • dogmaster_bo Feb 10, 2009
    can't read the color
  • Anne Hill Mar 02, 2009
    i cant fit the cartridge, there is no place to click it into........ help!!!!!
By default, when you open it the dock for the cartridges is parked at the far right. And with the power off (which is how I tend to open up machines) it stays there so if it's a new machine you don't even know they're there.
Try powering the printer on, THEN open the main cover: the docks slide to the left. Then it's simple enough to put the cartridge tilted with the 'smile' lower and facing you, push it along the channel like the little diagram under the cover shows until it clicks into position.
Push it firmly in: if the LED reads E,1,5 either it's not properly in or possibly the little gold connectors at the front end of the cartridge (pushed furthest into the dock) are smeared/obscured so there's not a connection.
Posted on Feb 15, 2009
  • 258 Answers
You can find the manul for it here http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
search on "Canon MP140"
It says to put the cartridge in slanted and push upwards until it clicks, see the pictures in the manual
Posted on Feb 01, 2009
Mp140 printer- do I have to put both black and color cartridges? I have only black here and printer has an error.
Yes both ink cartridges need to be installed in the printer for it to work.
You will either need to purchase new Canon ink cartridges for your printer or refill your old ones.
Take care!
damnor01
Jul 16, 2011 | Canon MP140 PHOTO AIO All-In-One InkJet...
E 5 error code
this is what your error means
E5-5
= The ink cartridges are not installed or a non-supported ink cartridge
is installed, or the ink cartridges are not installed properly.
are you using brand new supported ink cartridges?
are they in the right way?
Mar 01, 2011 | Canon MP140 PHOTO AIO All-In-One InkJet...
CANON MP140 REPLACE WITH NEW IN BUT WILL NOT RECOGNISE THEM BUT I JUST WANT TO USE THE SCANNER BUT IT WONT LET ME AS IT IS DISPLAYING ERROR 5 MESSAGE
hi, first remove your ink cartridge; and clean inside the carriadge, install a new cartridge, and reset your ink counter use this link to reset the ink counter, http://www.fixya.com/support/r7066832-reset_canon_pixma_mp140 if my solution helps you please vote it thanks
Nov 30, 2010 | Canon MP140 PHOTO AIO All-In-One InkJet...
MP140 can't recognise the black cartridge that I've just installed. Error code 4 - any ideas? I've tried the manual - nothing, and not much luck online - Thanks
Error code 4 normally indicates that there is no unk, and the solution is by installing a genuine cartridge, Try to use Black PG40 remanufactured Canon printer ink cartridge. This cartridge is a high capacity cartridge which has been filled with 23ml of ink compared with the 16ml (Black) that you get with the originals. Compatible with: Canon Pixma MP140. if this error still occur it is better that you try the following procedure below:-
When you insert a refilled ink cartridge into your Pixma MP140 printer you should get a warning about the refilled cartridge. You should also be prompted, asking if you wish to disable ink level detecting. Agree to do so, and you won’t get the warnings again because the ink levels won’t be monitored by the printer.
Thanks
Oct 12, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
My pixma mp 145 is not working. it shows error 5.please give me its solution
Error 5 means
The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
try to change your catridge if it is old one.
Hope this helps
Thank you
Oct 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
CANT PUT INK CARTRIDGE IN CANON MP140
For a tutorial (with images) on how to replace the ink cartriges, click on this link (CANON FAQs for your printer) :
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15294&kbpage=yes#
Then, in the "Please enter your question..." textbox, type "replace ink cartriges".
Click on the link that says "How do I replace ink cartridge(s)?"
Aug 16, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
My canon mp140 shows E4
From CANON FAQs for your printer:
Issue: ERROR LED: E, 4
Solution: Press and hold Stop/Reset button for at least five seconds.
Clearing the Ink Error If you want to continue printing in this condition, press and hold the <Stop/Reset> button on the printer for at least five seconds, and then release it. Replace the ink cartridge and close the Scanning Unit (Printer Cover).
If printing is in progress and you want to continue printing, press the Stop/Reset button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing. The resulting print quality is not satisfactory, if printing is continued under the ink out condition.
Apr 01, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
I placed a re-filled ink cartridges in my canon mp140 printer and
Computer chips in cartridges must be reset before the printer will recognize them as full. If you paid a shop to refill your cartridges take them back and complain. The best places will test the refilled cartridge before giving it to you.
Please note durability of prints using cheap ink is usually very poor, and as a result the manufacturers ink is usually much the better choice.
Mar 05, 2009 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon pixima mp140 error code E4
following error codes i found
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
Apr 24, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon MP140 PHOTO AIO All-In-One InkJet Printer Logo
1,711 people viewed this question
old marine
old marine
