Question about HP OfficeJet 7310 All-In-One InkJet Printer
HP 7310 All-In-One giving a dark line one scans and copies
When I scan or copy a page on my HP 7310 I get a dark vertical line on the output. I get the same result when I put the original on the glass or feed it view the top document feeder. There is no problem when I print a document from the printer. I'm guessing that the moving scanner in the printer is dirty. Is this the possible solution and if so, how can I clean it?
Thanks
Craig
  • craiga_45 Feb 05, 2009
    Hello. Does anyone know how to clean the moving scanner in the HP 7310?
    Thanks
I had the same problem but figured it out. Both sections of the top of the printer open and under the left side there is a separate "scanner window" that you can't see unless you open that side. lift your regular scan tray and then pull the left side up (it opens out to the left) and then left the piece that is under it. You should be able to see the thin scanner window. You can clean it with rubbing alcohol or even windex.
Posted on Feb 12, 2009
How do I fix this
Vertical Bands, Lines, or Streaks in Copies, Faxes, or Scans
support.hp.com/us-en/document/c02881567
Figure : Sample output with vertical colored bands or lines ... Remove any paper from the automatic document feeder (ADF) tray. ... To protect the scanner, do not spray the glass cleaner directly on the glass. .... determine if your printer is still under warranty, and then Contact HP Support to schedule a repair or replacement.
How to get rid of lines on a copied page - YouTube
? 2:10
https://www.youtube.com/watch?v=xTJpCg5sHl0
Feb 17, 2010 - Uploaded by Wayne Springer
When you make copies on your copy machine, does it ever leave a black vertical line ... QLS ' How to Eliminate Vertical Linesfrom Scans, Copies & Faxes ... Part 2- Fix or repair color laser printer with fading, light print, or lines ...
Dec 29, 2015 | Office Equipment & Supplies
I have a HP Laserjet 3015 fax machine connected to a phone line but not a computer. When I send a fax or make a copy a dark vertical line appears on each page. Incoming faxes print with no line. I have...
The fax scanning unit/encoder is dirty.
The fax scanning unit is like a camera. It take a picture of the document.
The glass plate is dirty and you may purchase a FAX CLEANING SHEET.
Officedepot
http://www.officedepot.com/a/products/470251/Office-Depot-Laser-Printer-Cleaning-Sheets/
or similar product to clean out the dirty area.
The dark strip is cause by semi-dry wipe out correction ink.
Give your unit a good cleaning and let me know.
Jul 08, 2010 | HP LaserJet 3015 All-In-One Printer
L7680 all in one W/big & wide dark vertical line
Open the document feeder and clean the scanner glass.
Feb 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Vertical lines (no printing) on copy
Make sure you have visited the HP web site for the OfficeJet 7310 (it's not the 10xi model, is it?)
Check out the page on troubleshooting copying problems.
See if your vertical lines issue is addressed on this page.
Nov 08, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Scans & copies have vertical line through them. I am not using the ADF. I have cleaned the glass & looked at the glass and it does not appear to be scratched. The vertical line is consistent and...
After troubleshooting with HP for about 90 minutes and discussing my lack of enthusiasm at their proposed solution, I purchased a new all-in-on printer.
Nov 04, 2008 | HP Officejet 7310 All-In-One Printer
HP 7310 Deskjet all in 1 printer - scanner problem
try to claen the glass see is there any mark of dust or nay lines of colour just clean it and see
Oct 16, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Vertical lines
hi,
I just want to know that which did you try to use to scan. is that by using the ADF (automatic document feeder) or using the scanner glass?
Jun 18, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
179 people viewed this question
Seeker5211
Seeker5211
