Question about Frigidaire FRT17G4B Top Freezer Refrigerator
Water drips from evaporator fan channel Frigidaire FRT17G4B
The water ends up on fridge top shelf. Evapoator channel which moves air from past coils though fan to fridge appears to collect moisture, this forms water dropplets in turn,water on shelf. Could my defrost timer be at fault, not defrosting long enough?? The frezzer back shield is channeling water to the drip pan and down to the condenser tray.I am at a loss!!!! Please allow me to thank you in advance.
SpecialEd: aka: Ed Sanger
  • specialed53 Feb 04, 2009
    Drain funnel and drain line are clear and free flowing . With that being said I noticed the tape holding the drain line up at drip pan has come loose and hose lies in drip pan. Should there be bend at hose end , this to stop air from being drawn up thru hose to freezer compartment??
    Again many thanks,SpecialEd
  • 30 Answers
It sounds as if this is a top mounted refrigerator. (freezer on top) If this is the case, check to see if you need to defrost the drain. You could also have a problem with the door seals. Remember the air coming out of the vent is freezer temp minus a few degrees. It could be that the moisture is condensing in that area.
Posted on Feb 01, 2009
My frigidaire fridge is leaking water onto the floor from inside fridge
The evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the inside of the freezer at the bottom of the rear cover.
Jan 24, 2011 | Frigidaire FRT21H8 Top Freezer...
MY REFRI LEAKING ALOT WATER ON THE FLOOR
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit.... The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the top shelf in the refrigerator compartment. Another cause may be the refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something like that, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the water disappears the problem is solved.
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
Aug 18, 2010 | Frigidaire FRS23KF7AB Side by Side...
I have a whirlpool imperial refrigerator; freezer on top; with icemaker....water is leaking from the freezer section down onto top shelf in refrigerator, near back, any help??
The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the top shelf in the refrigerator compartment. This is all you need to do....
Best of Luck,
Concerned.
Aug 10, 2010 | Whirlpool Refrigerators
My fridge leaks water at some point every day onto the floor. It is a frigidaire 20.6 top freeze. I have made sure it is not over full and is and air can move within the fridge. It is cooling but i have it...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 06, 2009 | Refrigerators
Water leaks from the freezer onto the top shelf of the refrigerator
Sep 04, 2009 | Frigidaire FRT17G4B Top Freezer...
I have an extreme amount of condensation appearing in my new frigidaire. my shelves are wet and the food at back of my top shelf has frost. (i live in los angeles, not too sure if that at all factors into...
If it's new I would think the door gasket is ok but that's one thing that could cause it.
The air has to circulate by way of a vent between the freezer and fridge. Make sure the vent door is opening when you adjust the fridge temp.
To complete the circulation the freezer fan behind the back panel inside the freezer must work and the evaporator coils near the fan must not be iced up blocking the air flow. (defrost failure.)
Aug 09, 2009 | Frigidaire FRT17G4B Top Freezer...
Our freezer has snowy ice and now the fridge cools poorly??? cleaned the coils, checked gaskets,drip pan, and it sounds like the fan by the coils is running, any help on what to check for next???
if you have a ice maker check the water inlet to see if there is an air gap if not make sure your your gasket is not bad and your not blocking the air flow from your freezer to your fridge. also check your temp. and make sure that the number difference is only off by no more than one
Jul 24, 2009 | Frigidaire FRT17G4B Top Freezer...
Fridge problem
usually the smell is the water dripping into the pan under unit place cleaners and use charcoal inside unit to remove odars that collect on evaporator and get concentrated then go to drip pan
Feb 11, 2008 | Frigidaire FRT17G4B Top Freezer...
Magic chef fridge #ctb1722grq
Behind the panel in the freezer there is a drain hole that is underneath the evaporator.  It is frozen over.  Take the back panel off and get all of the ice out and run hot water down the drain until it is clear.  When the unit goes into defrost some of that ice melts and drips down thru the vent into the fridge section.
Oct 20, 2007 | Frigidaire FRT17G4B Top Freezer...
Water dripping at top of refrigerator compartment
Try to blow air through the defrost drain hose from the bottom of the fridge to make sure the line is clear for defrost water to drain.
Aug 26, 2007 | Frigidaire FRT17G4B Top Freezer...
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
295 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Electrolux
Electrolux
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
