Question about Sony RDR-VX515 DVD Recorder/VCR
Command mode change disabled remote
Command mode was changed to DVD1 by mistake and the remote by default is set to DVD3. We cannot use the remote to access system menu and change it back. How can we get the recorder back to default factory settings without the remote? I have a SONY RDR-VX560. Set command mode to DVD1 and now remote control does not work. I'm trying to access System Menu to restore factory setting which I hope will correct this. Anyone know how to get to this menu without the remote control?
  • 6 more comments
  • bradsox Feb 23, 2009
    Command mode was changed to DVD1 by mistake and the remote by default is set to DVD3. We cannot use the remote to access system menu and change it back. How can we get the recorder back to default factory settings without the remote? I have a SONY RDR-VX560. Set command mode to DVD1 and now remote control does not work. I'm trying to access System Menu to restore factory setting which I hope will correct this. Anyone know how to get to this menu without the remote control?  Also, you can't access the menu from the DVD console.  Does anyone know if this can be done?
  • mek5976 Apr 02, 2009
    bszyman, I have exactly the same issue. If you come across any answers, please let me know.
    I have the original remote that came with the player
  • Anonymous Apr 23, 2009
    I have the same problem and tried the enter/#1 key and it didn't work for me.
  • Anonymous May 15, 2009
    I had the same problem and holding the enter key and the number 1 simultaneously fixed it. The manual reads select 3 and enter...wrong! Listen to Mike, he was right.
    Dan
  • Anonymous May 18, 2009
    Same thing. Command mode changed and now can't access system menu! HELP!
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Do you have original DVD recorder remote?
  • Anonymous Mar 28, 2014
    Image at top left corner is 2" higher then left corner. Mount is fine. Looks like horizontal keystone prob - but no setting to correct it...
According to Sony, if you turn the power on and hold the Enter key and the #1 key down together for at least 3 seconds, everything will default back to factory settings.
Mike
Posted on Apr 03, 2009
  • mek5976 Apr 16, 2009
    Turn the power on and hold the Enter key and the #1 key down together for at least 3 seconds, everything will default back to factory settings.
I accidentally changed the command code from dvd3 to dvd1 and now my remote doesn't work, and I don't know how to access the systems menu to change it back.
Since unit has been set on DVD1 remote mode so you need to set remote control itself on dvd1 mode to communicate with unit.
Press and hold Enter and 1 numeric key on remote control for 5 seconds, this will change remote control to dvd1 mode, now unit will accept remote control signal and you can operate it normally.
Thanks.
Jan 02, 2011 | Sony RDR-VX535 Player
I can't return to command mode dvd3 (default) from dvd1. Now my remote is useless and I can't find a way to bring up the main menu so I can get back into command mode dvd3.
Slide remote lower cover and look for DVD Command mode set switch, set it to DVD-3 position, your RDR-VX530 will accept remote commands.
Thanks.
Dec 21, 2010 | Sony RDR-VX530 DVD Recorder/VCR
Set up sony RDR-VX535 recorder to DVD1. now remote does not work.
See the manual on page 22.
The solution is to reset your remote code to DVD1 (default is DVD3).
Press the ENTER button and NUMBER ONE button simultaneously for at least three seconds. Viola, control returns.
Feb 22, 2010 | Sony RDR-VX530 DVD Recorder/VCR
COMMAND MODE SETTING HAS BEN CHANGED FROM DVD3 TO
press enter and 1 or enter and 3 hold for 5 sec should match whatever unit set to
Oct 02, 2009 | Sony RDR-VX530 DVD Recorder/VCR
Locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Jul 28, 2009 | Sony Televison & Video
DvdRDR-GX360
It´s is easy to solve. Your DVD was seted to DVD1. Push enter button plus 1 no remote control.
Now you are able to commnad your DVD and go to System Menu and change to DVD3 again.
After it, don´t forget to backup your remoto control to DVD3. Push enter button plus 3
Dec 13, 2008 | Sony RDR-GX300 DVD Recorder
Can not get my sony dvd to get off of dvd1 and it is now locked u
Go to your DVR and manually turn the DVR off. Press the STOP button for
two or three seconds. The DVR COMMAND MODE setting will display in the
DVR window. (DVD1, DVD2 or DVD3)
Set the remote to the COMMAND MODE setting that was diaplayed by depressing
both the remote ENTER key and the desired number key (1, 2 or 3) and holding
them both at the same time for 3 seconds.
You can now use the remote to set the DVR to the desired COMMAND MODE.
To do this depress SYSTEM MENU on the remote and go to SETTINGS and then
COMMAND MODE. Select either DVD1, DVD2 or DVD3. Once you delect a setting
that is different from what was set, your remote will stop working again.
Reset your remote to the desired COMMAND MODE by depressing the remote ENTER
key and the desired number key (1, 2 or 3) and holding them both at the same
time for 3 seconds. The remote should now control the DVR.
Nov 14, 2008 | Televison & Video
Dvd recorder rdr-hxd860
press stop button then the power button together the player will go off. put it on again the remote should work.
Mar 15, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Command codes
Read page 23 in the manual.
Press "enter" & the #1 keys together for 5 seconds.
Then press stop.
Press "system menu" & change the option back to dvd3.
Then press "enter" & the #3 keys together for 5 seconds.
Press "system menu".
Or call Sony Main Support # 1-800-488-7669
Mar 07, 2008 | Sony RDR-GX355
Remote doesn't work
Slide the bottom part of the remote control down. Switch the bottom right button to DVD 1. There might be a white sticker that covers it so remove the sticker first. Then hold down the "Enter" button and the "1" button down at the same time for a few seconds. That should make the remote work again.
Feb 25, 2008 | Sony RDR-VX530 DVD Recorder/VCR
Sony RDR-VX515 DVD Recorder/VCR Logo
1,107 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
