Question about Lexmark X7170 All-In-One InkJet Printer
I have a X7170 it has recently began printing with vertical blank areas on the printed copy. In other words up and down on the page there missing copy. I have changed ink cartridges and this does not help. It has been occuring off and on, now it does not print anything with out the verticle lines with out type in it.
  • Anonymous Apr 16, 2009
    mine was printing with blank horizontal lines. just had to clean the cartridge as shown on the lexmark website
  • 63 Answers
Uneven vertical lines can be adjusted by
performing the printhead alignment adjustments.
The user is directed through the Lexmark Solution
Center to perform the printhead alignment
adjustments when replacing a printhead cartridge.
The alignment can also be performed from the
control panel by selecting the Maintenance Option,
then Align Cartridges.
Posted on Feb 01, 2009
Transfer Belt Leaving Color Streaks on Pages
Try replacing color toner of the same color that are the lines.If the void was in the same place all of the time then I would say use a Q tip dipped in 90 proof alcohol and clean laser.
Apr 21, 2014 | Brother BU300CL Transfer Belt, 50,000...
Lexmark X7170 will not print in grayscale
i have cannon 3530 xerox machine ... it shows error code 350 ?? any solution ??
Jul 28, 2013 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
My officejet pro 8500A prints black vertical lines down the page when I make a copy. I have cleaned and aligned the printheads. What else can I do?
Happened with me too. Turned out to be a small sticky smudge on the ADF glass. That is the smaller glass scan area to the left of the large glass scanning area.
When using the ADF to scan or copy, make sure the smaller glass area is clean along with the rollers.
Oct 05, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
My HP Pro 7780 has recently started making copies (through the feeder) with 2 large blank streaks down the middle of the page (lengthwise). I am worried that this is also happening when I send a fax as...
Does this happen when you print, or only when you copy? If you print out a configuration or user settings page, or print a page from the computer, is it also missing two vertical lines of print or is it only when you are copying?
If it happens when you print, you may need a cleaning, or you may need to replace the toner or drum cartridge. If it's an inkjet machine, there's a possibility there is some ink or grease on the encoder strip (a small belt-like plastic strip that goes through the print-head carriage).
If it only happens when you copy, test both the flatbed and the document feeder. If it happens on both then you may have a bad scanner. If it only happens when using the document feeder, you likely have some whiteout (or something) on the glass. When you make a copy in the flatbed, the scanner moves across your document. When you make a copy using the document feeder, the document moves across the scanner. In this case, if there is anything on the scanner glass (like whiteout) your copies will be missing a vertical line of print data (it could be white if there is whiteout on the glass, or it could be dark if something dark is on the scanner glass).
Usually you can lift the flatbed cover and look at the glass to see if anything is on it (usually at the left side of the scanner). Clean the glass, first with alcohol to remove the obstruction, and then with a little windex to remove anything the alcohol may have left behind.
Sep 23, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
After refilling my black cartridge, my lexmark X7170 AIO (on printer copy setting) prints out a blank page even after printing an alignment page showing black bars & blue dashes (no other colors?) I...
Try to print some more pages. The ink will take time to go down as it is not free flowing. This is due to the air beetween the new ink and the old ink, after some printing the air is push out and then you can have a clear print.
Sep 11, 2010 | Lexmark Office Equipment & Supplies
Printing blank pages from word and now every time canon 6530
There is a service update from Canon, where a part needs to be change in the laser area. You can try to slam the toner door shut to see if it changes it temporarily, but a laser shutter arm needs to be changed.
Mar 25, 2009 | Canon MF-6530RF Factory Reconditioned...
VERTICAL PRINT LINES
Check the front paper exit rollers for fit and alignment also the paper deck guides close to the planten area, if the printer is dropping print vertically down one side of the page, this can be caused by debris or anything that lifts the caridge assy the slightest bit, also check the print head seating and ribbin cable for proper alignment
Apr 04, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Vertical lines
1st print a report, can you see the lines? Then either the drum is faulty or the laser scanner is. If the lines are not present when printing a report, make a copy and see then if the lines appear. If so, the scanner is faulty. Try cleaning the glass with glass cleaner. However, blank lines mean that bits are missing from the scanner itself and the scanner will need to be replaced.
Feb 27, 2008 | Brother IntelliFax-2820 Laser Fax
My Hp 1020 printer is printing full black pages.....
is this a laser printer? have you replace the toner cart?
Dec 12, 2007 | HP LaserJet 1020 Printer
Color print lines
try to replace with colour catridge bye
Sep 24, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Lexmark X7170 All-In-One InkJet Printer Logo
206 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
