Question about Reddy Heater-170,000 BTU Kerosene Deluxe
Won't run with cover down.
It will light and bur'n with cover lifted off. when i close the cover it shuts off and smokes. Ive cleaned the filters tried adjusting the spring and ballbearing and also cleaned plug. it's only a year old was used in our foundry there is a lot of sand...
  • viking92 Feb 04, 2009
    Reddy 115 Pro, same problem. Runs fine with cover off, won't light with cover on. Checked pressure, igniter, & filter. Need help.
Is there a safty switch on the door, if there is check that first
Posted on Feb 05, 2009
Lights come on and it beeps when u select cycle but it wont run
Do you hear the water going in? If not, the float switch is probably stuck . From the inside you can see the cover usually on the front left corner on the floor of the dishwasher by the bottom rack. Remove the screw and float cover. The you see a small piece sticking up, gently push on it many time to try to free and clean it. This is actually pushing the float switch. Clean the plastic covers of soap gunk. Reassemble and try. The switch can be accessed from underneath if you want to replace it. Also a clogged or defective water valve will not allow water to enter.
Mar 24, 2014 | GE Dishwashers
42" MTD riding mower. Won't start. Had a tough
White smoke or semi white can be produced in several ways. One way is oil this is normally a whitish blue to blue smoke and has the apparent smell of oil being burned.
Read more: http://wiki.answers.com/Q/What_can_cause_white_smoke_from_the_exhaust#ixzz1ZTQwS4Al Hope this helps
Sep 30, 2011 | Mtd Garden
98 escort start smoking battery light came on car shut off and nw won't start
something serious here and i have no idea to be honest ---without lifting the bonnet and having a good look myself .could be anything but without a good look??
Sep 26, 2011 | 1998 Ford Escort
After I start the pressure washer,do i push the choke back in,or leave it on?because it was smoking a little bit when it was on and running.or is that normal?
You turn it off after is warmed up, if it is smoking some , depending how bad it is won't hurt, unless it is running rough or smokes bad. Then needs possibly light tune up. You know oil change, fuel filter, clean air filter.
Jun 09, 2011 | Garden
It won't run and dumps fuel.I've dipped thecarburetor and cleaned it well.the fuel just runs out the lower spring covered house that dumps out onto the ground
The problem is a bit of trash is preventing the float needle from closing fully to stop the flow of gas. Try this; drain the float bowl then close the drain and turn on the gas. Tap the float bowl solidly with the end of a screwdriver handle. The object is to free up the float / shake loose the trash. If doing that a couple of times does not fix the problem, Remove the float bowl and spray the interior of the carb using spray carb cleaner. Pay special attention to the float pin area. With the float bowl off you should be able to gently lift and lower the float. Lifting should shut off the gas and lowering should let the gas flow again. If the float shuts off the gas when raised, put the float bowl back in place and see if the carb still over fills. If so, then the float is defective and you will need a new one. Please rate my answer. Thanks. tombones49_151.gif
May 30, 2011 | Kymco 990 Super Duke Black Motorcycles
The filter looks very durty how do i clean it
If it is split unit, lift the front cover up. and gently remove the filter. Clean with warm water. Don't use any detergent. And re fix gently, and close the top lifted door. Helpful?
Dec 20, 2010 | Heating & Cooling
Printer reads out "Carriage Jam". Have done all the usual stuff.... shut down,unplugged, cleaned around connections and still reads out "carriage jam". Makes a lot of noise after opening carriage and...
hi
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hp Cartridge issue
Complete the steps below in the order presented to resolve the problem. It might not be necessary to complete all of the steps.
Step one: Reset the printer
  1. Without turning the power off, remove the power cord from the back of the printer and from the wall socket.
  2. Wait 30 seconds and reconnect the power cord to the printer and to the wall socket. Turn the unit on if it is not already turned on.
  3. Check the printer for the error message. If the error message still displays, go to the next step.
Step two: Clean the cartridge contacts
Figure 1: Lifting the top cover
Lift the top cover.
  1. Locate the ink cartridge indicated in the error message. Squeeze the gray tab below the cartridge slot to release the latch, then lift the latch.
Figure 2: Unlatching cartridge
1 - Black cartridge
2 - Color cartridges
  1. Remove the cartridge indicated in the error message.
Figure 3: Removing cartridge
Gather cleaning materials:
    • Distilled, filtered, or bottled water (do not use tap water or alcohol or platen cleaners)
    • Lint-free cloth or swab. Eyeglass wipes and coffee filters work well.
  1. Lightly moisten the swab and squeeze out excess moisture.
  2. Holding the cartridge by its handle, wipe the copper contacts.
Figure 4: Wiping the contacts
1 - Copper contacts
  1. Replace the cartridge, then close the latch and the printer top cover.
Jul 29, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Light won't go on; Model MMV1153WB-O
You can download owner's manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
Enter it as MMV1153WB0 (no dash, zero on the end, not "oh")
Or just get it here, to be more exact.
On page 4, it says:
"Installing/Replacing Filters and Light Bulbs
■ Grease filter: Grease filter is on the underside of microwave
oven. Clean monthly. Slide the filter away from the tab area,
and drop out the filter. To reinstall, place end of the filter into
the opening opposite the tab area, swing up the other end,
and slide it toward the tab area.
■ Charcoal filter: The charcoal filter is behind the vent grille at the
top front of the microwave oven. The charcoal filter cannot be
cleaned, and should be replaced about every 6 months.
Remove 2 screws on the vent grille, tilt the grille forward, lift it
out, and remove filter. To reinstall, place the filter into its slotted
area – wire mesh side up, replace vent grille, and secure with
screws.
■ Cooktop light(s): The cooktop light bulb(s) is(are) located on
the underside of the microwave oven, and is(are) replaceable.
Remove bulb cover screw, and open the bulb cover. Replace
bulb, close bulb cover, and secure with screw.
■ Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove 2 screws on the vent grille,
tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws."
HINT: Unplug the oven before removing or installing the bulbs, or you may need this service.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. Hope this covers it.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
May 06, 2010 | Maytag Over-the-Range Microwave
Choke on or off
up=on
down=off ok buddy also you should realise anyway it will smoke alot more with choke on
Aug 28, 2009 | 1998 Honda XLR 125 R
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
79 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
