Question about Hayward Easy Clear 40 Sq Ft Cartridge Pool Filter with Pump
Im having trouble opening the sring clamp on the hayward pool fil
I loosened the spring clamp on the filter, but filter clamp will not open.
  • 125 Answers
Once the ring is unthreaded it may need a good hard tug to open the filter lid.
Posted on Feb 26, 2009
How do I unlock my Hayward Xstream filter. I can not get the filter top off
Same problem, brand new filter... I'm 190 lb guy who works out 6 days a week, I can't open this filter for the life of me. If I knew it would be so hard to open I'd have opted for a less expensive sand filter. Cartridge are supposed to keep the water clearer but if you can't open the filter to clean it without spraining a wrist or having a heart attack (or both) what good is it? Beyond mad, I'm thinking of just biting the bullet next spring and buying a filter that actually opens. Even the brand new Hayward chlorinator didn't work properly this past summer, i,thought they were supposed to be good products, dealing with their customer service is pointless.
Sep 13, 2014 | Hayward Pool Products Hayward Xstream...
How do I remove air from pool filter lines?
with out seeing your set up not to easy,but lets try
1 your pump room is below surface of pool, make sure your pool level is high enough to return water to pump via the skimmer hole in side of pool at surface level. water should fil pump basket. check that you have a good seal on glass cover. no water in basket check if valve from pool is open still no water close valve fill filter chamber with a hose close glass cover start pump and open valve immediately.
2 pump room above pool level, close inlet valve fill pump filter with water close glass cover securely start pump and open valve.
a good drawing of you equipment and its position relative to pool how and ware u connect vacuuming hose
May 30, 2012 | Hayward Pool & Spa
Cannot get filter apart, all 12 bolts are removed but i still cannot get it apart??
This is called Vacuum lock. You need to open up the purge valve if there is one, and if not, you must let air into the system somewhere. Try opening the pump pot or loosening any close by pluming unions
Sep 24, 2010 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
We have a hayward sand filter and have replaced the entire mult-port valve gaskets etc. The pool runs on filter but after we vacuum backwash etc...when we put the handle back to filter water continues to...
There is more than one version of these valves. The model like sp072 has a 5 spoke spider gasket that has one opening larger than the rest. Be sure it is in position so that the large opening lines up with the large opening in the valve. If it's a SP0714 then the rubber is molded on the valve itself and would have to be replaced together. In either case, the seal is provided by the spring pressure forcing the valve faces together. That is why you should depress the handle, and only turn the valve while it's depressed, and the pump is off. After you turn to the selected location, then you release handle, and the valve surfaces should spring back together. Be sure the lever has spring tension on it in case you left it out while working on it) You can download complete manuals from www.haywardnet.com Good luck!
Jul 05, 2010 | Hayward SAND FILTER, PRO SERIES
Installing multiport valve.
No, the o ring should not squeeze out. When putting the top and bottom components together....
  1. Make sure surfaces are clean...No lube!!!
  2. Make sure o ring is clear
  3. Install o ring usually on lower half but depends on model
  4. Gently place upper half on lower
  5. Place clamp around the halves (this can be tricky)
  6. If there is a tension spring with the clemps, do not use it yet
  7. Without the spring, insert bolt and start tightening the clamp
  8. The halves should slowly come together
  9. Make sure the halves and band are aligned
  10. Once the top is on the bottom fairly secure, loosen the clamp and re-tighten with the spring this time till the spring is compressed with no gap between the colis on the spring. If you have two tightening clamps, do this at equal intervals.
I dont know the exact model you have, but this is a standard procedure... Good luck..
Jul 11, 2010 | Hayward SAND FILTER, PRO SERIES
Hi I am having trouble getting consistent power. I have taken it apart and cleaned it thouroughly only to find that the problem still remains. Any suggestions?
Try bumping the filter. You might have D.E. coated with normal accumulation of pool dirt, algae, etc. Your pool filters pump strainer or skimmer baskets could be clogged. Make sure there are no obstructions in your impeller. Finally, check the cover gasket, hand knobs, hose, clamps, etc. Replace or tighten as necessary.
Jul 03, 2010 | Hayward EC-40 DE Pool Filter with pump
Directions on removing filters
Removing the filter on these automatic pool cleaners is easy. It should be in the easy open bottom. After you disconnect, turn the unit upside down and locate and loosen the captive screw. You can clean this area and reapply the captive screw.
May 25, 2010 | Hayward Navigator Pool Cleaner
No suction from hayward variflow pro series sand filter
Try these tips. I am guessing that one of these is the reason that your pool filter is not working properly. If you try these suggestions and they don't work, let me know and I will trouble shoot with you again.
1. Check skimmer and pump strainer baskets for debris.
2. Check for restrictions in intake and discharge lines.
3. Check for air leak in intake line (indicated by bubbles returning to pool.
4. Backwash your filter.
5. Be sure Vari-Flo valve is set on “Filter” position.
May 22, 2010 | Hayward SAND FILTER, PRO SERIES
Hooking up filter to pump and pool
This website contains a copy of the owners manual for the S180T pool filter. It should have all of the information that you need.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
It is in PDF format. let me know if you have any trouble opening it.
May 21, 2010 | Hayward SAND FILTER, PRO SERIES
My pool sand filter pump isnt filtering the water
sounds like the sand has clumped together inside filter. you can open filter and replace sand charge or dump into wheel barrow loosen sand and flush clean with hose and put back in
May 13, 2009 | Pentair Sand Dollar 19" Filter with 1 Hp...
Hayward Easy Clear 40 Sq Ft Cartridge Pool Filter  with Pump Logo
140 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
