Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Oven door does not close tight - Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    ive seen this a lot over the years while on service calls.you can replace door springs.but many oven doors are loose including mine at home and they cook just fine.
    Sergeant:
    Champion:
  • 291 Answers
You will need to replace the door hinges / larry
Posted on Feb 07, 2009
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 | Ovens
Oven door does not close properly
When you say "oven door does not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Or is it some other closing problem?
If it is the former, then it is a sign of the door hinge springs wearing out. The solution to this is to replace both hinges on the offending door.
Sep 01, 2011 | Neff B1421 Electric Single Oven
My Wolrd Pool Double Oven Door will not close all
same problem, I tried to adjust the level and tip the oven back, but that didn't work either.
Two options exist, change the hinges, or close the door with a hammer handle between the door and oven. Place the handle down low by hinge, then push the door closed very firmly to pull the hinge outward a bit.
Jan 03, 2010 | Kenmore Ovens
Ovendoor not closing for tight seal...
You should feel the door pull closed when you as you lift it and get near the closed position.
There is some spring linkage associated with the hinge pins at the bottom sides of the oven.
I cannot find the oven you indicated, but I did find exploded views and parts list of the topic post oven on the SearsPartsDirect website.
Jan 28, 2009 | Kenmore 99123 Electric Kitchen Range
replacing hinges on this oven. Take a look.
Dec 14, 2008 | Hotpoint RB787 Electric Kitchen Range
My Amana oven door will not shut tightly.
twist a tesher like a roll and put it betwing the door and the frame of stove then close the door gently to bring back the hinges to position.
Nov 17, 2008 | Maytag MER5755QAS CleanDesign Electric...
Oven door hinge replacement installation
kitchenaid superba oven door will not stay closed.
Oct 22, 2008 | Kitchen Ranges
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
66 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
