Question about Panasonic (KX-TG1032S) Phone
I can't remember how to record my outgoing message ?
Pls advise on how to record my outgoing message on my voicemail for Panasonic 6.0
  • 214 Answers
Here you go...
Recording your greeting
message
You can record your own greeting
message (max. 2 minutes and 30
seconds). If you do not record a
greeting message, a prerecorded
greeting message is used.
1 {MENU}
2 {V}/{^}: “Answering devicei
{OK}
3 {V}/{^}: “Record greetingi
{OK}
4 After the handset beeps, speak
clearly about 20 cm (8 inches) away
from the microphone.
5 To stop recording, press {OK}.
6 {OFF}
If this helps you solve it, plz rate this fixya. Thank you kindly.
Posted on Feb 01, 2009
KXTG9341 Top light flashing and 'New Voicemail' message on handset display, but no new message recorded on the answering machine.
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone.
Please contact your telephone company for instructions on accessing their voicemail system.
Feb 27, 2014 | Panasonic DECT 6.0 Expandable Cordless...
I want to change the greeting on my outgoing voicemail and cannot remember how to do so? I know I pushed a particular button and held it but it's been years since I've needed to change.
The TGA-101S isn't an answering machine, and thus doesn't have an outgoing message. Please consult the documentation for your answering machine, or else repost your question specifying the make and model of the answering machine.
Jan 29, 2013 | Panasonic KX-TGA101S Cordless Handset
I have recorded an outgoing message. However, at the end of the new outgoing message an old obsolete outgoing message starts to play. How do I get rid of the old outgoing message?
You will need to remove the old message. There SHOULD be prompts. IF NOT try going to a very quiet room and hit record but do not say or make noise and this will record silence over the old and new message. Then attempt to retry.
ALSO - look for a 'reset' button and remove all batteries if you have power outage back up batteries.
Unplug the phone - and try again.
Here are the instructions from the manual:
To Change Your Personal Greeting:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
Best of it
Gary @ Fix Ya
Jul 20, 2011 | NorStar M7324 Telephone
How do you change the outgoing message on this phone?
Need to acces the mailbox for that phone as the mailbox owner, then enter the options menu and listen to the prompts to record the outgoing message.
Dec 08, 2010 | Lucent PARTNER18 Corded Phone
I can't record the outgoing message.
I believe that I've found the answer you've been looking for. After
looking through the support section of the Panasonic UK site, linked
to from the above link, I stumbled upon the manual for your phone. It
can be downloaded at:
http://www.support.panasonic.co.uk/sys/ttips/Panasonic/Communication_Products/Dect/KX/TCD735/KXTCD735.pdf
(You should right click on the link and click Save Target As to save a
copy to your computer)
Detailed instructions on how to record a new outgoing message can be
found on page 78 of the manual, but I'll list the simplist way here
for you:
1. Press INT then #
2. Press 7 and then 6
3. Record your message, press 9 when you're finished
It's also possible to record a new message using the menu on your
phone. Detailed instructions for that can be found in the manual, also
on page 78.
I hope that solves your problem! However, if you need any further
clarification on this answer, please feel free to ask.
Mar 04, 2010 | Lands Phones
Changing main voicemail message
This may be specific for my system, but hopefully it helps:
Connect to your voicemail (for us, we can either hit the voicemail button or dial 1650)
Once in, press #6, it will ask for a mailbox number, dial *9998, it will ask for a password (the default is 1234#)
Press 5 to modify messages.
Press 3 to record custom service menus.
It will ask you to pick which menu (1-100). Our day menu is 1, and night is 2. I'm guessing yours will be the same.
From this point, it becomes the same as recording a standard voicemail greeting. It will play the current greeting and you can press 1 to re-record it. Do so, and then press #. Press 2 to accept and you're done!
Dec 24, 2009 | Panasonic KX-T7630 Corded Phone
How do I record new outgoing voicemail message
depends on your provider, if you call your own phone number (voicemail) it should give you options to change a few things, if not contact ur provider
Dec 03, 2009 | Motorola Mobility W385 Cellular Phone
Creating an Outgoing message that tells a caller to leave a messa
To Create Your Personal Greeting:
Please let us know if that was helpful enough.
Good Luck & Thanks
Shiv.
Aug 13, 2009 | NorStar Flash Voicemail Power Supply Only...
Recording and setting phones for nighttime
When calling your Voicemail and getting AA press * . Ext 70. Input password follow the instructions for box 800
Mar 17, 2009 | Comdial Impact 8024S Corded Phone
Record outgoing message
Call your service provider and ask them what their voicemail service number is an dset up your voicemail that way.
Mar 11, 2009 | Samsung SGH-G800 Cellular Phone
Panasonic (KX-TG1032S) Phone Logo
690 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
