Question about KitchenAid KFP750 Food Processor
Spinach stuck in food pusher
How can I remove the spinach from the plastic? The plastic is not a removeable piece.
  • 24 Answers
PLZ CONTACT 022-23051554 \ 20395757
Posted on Feb 03, 2009
I cannot get the top off the main cylinder on my DLC-85
The pusher sleeve has what I describe as a plastic "clip" on it - if you look carefully at this clip, there is a circle that says "Press Here". If you press on that clip, the whole pusher sleeve will ocme out, and then you will be able to remove the lid.
May 02, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Tip
The Cuisinart 7 cup food processor will not start?
Check out this options Remove the work bowl completely. Turn the machine on and use a pen to depress the dark grey or black button on the base of the Food processor. If the motor doesn't spin, it needs repair. If there is spinning:Make sure the handle of the bowl is facing the front of the food processor. Place the lid tab just to the left of the handle and slide it toward the handle until it won't turn anymore. Remove the pusher sleeve from the lid and reinsert it with the lock facing the front of the food processor. Slide the lock into the locked position. If it still doesn't work, replace the third piece on the work bowl - the one piece that you haven't replaced. It will then work. This will help. good luck.
on Mar 08, 2010 | Food Processors
Food processor does not work but light is on
Put the work bowl, lid, and pusher on one piece at a time - handle of work bowl faces the front of the food processor, hollow feed tube faces the back, and the sliding lock switch on pusher sleeve faces the front. Should turn on.
If it doesn't, test the motor - remove the work bowl and other parts completely. Plug the base in and turn it on, and use a pen to push in the dark grey or black button on top of the base - if it spins, the motor is still good - you may just need a replacement part. If it doesn't make a sound, it needs to be sent in to Cuisinart for repair.
Mar 29, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
Tried to use my powerprep pluss cuisinart food processor and nothing happens. The on button lights up but nothing happens when i press the pulse button.
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the lid lined up with the handle of the work bowl.
Put the pusher sleeve in the lid, with the metal piece facing the front of the processor.
Your processor should now turn on.
If it doesn't call Cuisinart and see if you are still in-warranty (3-year warranty).
-Tha Mp3 Doctor (also loves Cuisinart)
Mar 23, 2009 | Cuisinart DLC-2014 PowerPrep Plus Food...
Cuisinart 7 cup food processor wont' start
Remove the work bowl completely. Turn the machine on and use a pen to depress the dark grey or black button on the base of the food processor. If the motor doesn't spin, it needs repair. If there is spinning:
Make sure the handle of the bowl is facing the front of the food processor. Place the lid tab just to the left of the handle and slide it toward the handle until it won't turn anymore. Remove the pusher sleeve from the lid and reinsert it with the lock facing the front of the food processor. Slide the lock into the locked psoition. If it still doesn't work, replace the third piece on the work bowl - the one piece that you haven't replaced. It will then work.
-Tha Mp3 Doctor
Jan 06, 2009 | Cuisinart DLC-5 Food Processor
My food processor turn on button won't work.
Cuisinart Food Processors – Motor Test
First, do a motor test by removing the work bowl completely and using a pen to press in the grey button on top of the base (with the food processor turned on of course), toward the back. If the processor spins, the motor is still good. At that point, I would inspect the work bowl pieces, lid, pusher assembly, etc for cracks/damage. If all appears well, insert ALL the pieces back into place and try again. If even one piece is out of place, the processor will not spin.
If it no longer spins, the motor has a problem.
-Tha Mp3 Doctor
Nov 25, 2008 | Cuisinart DLC-5 Food Processor
The plastic ? bowl of the processor is stuck
With the food processor I have it will not allow you to remove the bowl unless the top is off.Try take the top off or putting it on.Then remove it from the processor.
Sep 22, 2008 | KitchenAid KFP670 Ultra Power Food...
I can't get my food processor (DLC-2007N) to start. It looks like everything is locked in place, and the light goes on, but the motor won't start.
Aug 31, 2008 | Cuisinart DLC-2007 7 Cups Food Processor
The cuisinart food processor doesn't work.
-Tha Mp3 Doctor
Aug 26, 2008 | Cuisinart DLC-8S Pro Custom Food Processor
CAN'T GET TOP ON TO OPERATE AND CANNOT FIND CD FOR 14 CUP CUISINART FOOD PROCESSOR
Do these directions in reverse - (the how-to DVD is generic - not for each individual Cuisinart food processor):
Removing a Cuisinart Food Processor Work Bowl
You have to remove the pusher first by twisting it off. Then press the sides of the pusher sleeve inward and slide the sleeve up and out of place. Then twist off the lid - all twisting on these food processors works either clockwise or counterlcokwise - not both. Then twist the work bowl to the left (clockwise). Voila!
-Tha Mp3 Doctor
Apr 13, 2008 | Cuisinart Limited Edition Metal MP14 Food...
KitchenAid KFP750 Food Processor Logo
127 people viewed this question
Top KitchenAid Food Processors Experts
xalint1
xalint1
Shehu Pro
Shehu Pro
Andrew Taylor
Andrew Taylor
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
