Question about Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Thank you Just wanted to thank you again for helping with my surround sound. It was making me crazy! I think that it is very nice of you to be a part of this site and help people who are electronically challenged such as myself. Thank you again.
  • 362 Answers
I'm glad I could help, You did get it working right? If you could take time to go to the original question and rate the solution it would be greatly appriciated.
Thanks again  Lone99star
Posted on Feb 01, 2009
  • Jason Morris Feb 01, 2009
    i see now you gave rated a FixYa!  Thank you very much.
    Let me know if I can help with anything else.
    Lone99star
I was wondering if there's a way to change audio out from variable to fixed cause I want the volume out only from my surround sound not from the tv I heard If I switch from variable to fixed the problem...
No variable audio out means that whatever the volume is at on the TV it will output that level from the TV. So if you have your surround sound on and if you change the volume on your TV it will also make your surround sound louder with out having to turn up that volume on your surround sound, but if you have your volume muted then so will the audio out. So if it is a fixed audio out then no matter what level you have the TV set to it will output the same level. If you just want audio to go to your surround sound then just hook the video cables up to your TV and the audio to your surround sound. I would guess that you are using Red and White cables... If you are that only gives you left and right audio. Not surround sound, so you would want to run optical, HDMI, digital coax, or the analog 6 channel audio cables.
Sep 09, 2010 | Televison & Video
Have surround sound only when play dvd..
if you have a sat/cable box it may have audio outputs that you can connect to the input of the surround unit or if your tv has an audio uotput it can be connected to the surround unit. The audio outs of the tv may or may not adjust with the tv volume. This will not produce a true surround signal because th tv does not output a true surround signal. But yo can adjust the surround unit to get a nice sound.
Jun 26, 2009 | Philips SoundBar DVD Home Theater with...
Can older receiver support Hdmi with an adapter?
The optical cable will get you 5.1 surround sound - but only if the game has surround sound and your PS3 is set to output surround sound. Even the PS2 will do that. DTS is one 5.1 surround format and the optical cable will handle that too.
Check your settings on the PS3 and make sure you are:
Using the optical out, and
outputting a 5.1 surround signal.
I think you will find your JVC is adequate for this purpose. Please post back if you are unsure of how to set those options.
Jan 15, 2009 | Audio Players & Recorders
No sound
Yes, But thank you for being available. It was the cables in back of t.v and dvd player our son took them off to plug in his 360xbox and he reconnected them wrong when he was done.
crazy huh!!
thank you again and merry xmas
Dec 13, 2008 | Philips LX3700D System
Nakamichi AV-7 (issue with surround mode - prologic)
Nice Receiver!
>In your surround sound settings make sure the levels are set correctly and the distance from your listing point to the furtherest
speakers are set to accommodate the levels etc.
>How many speakers 5.1, 6.1, or 7.1 (1meaning subwoofer)
>Pro-Logic supports 5.1 but not sure about 6 or 7
>Pro-Logic II does support all
>Make sure you are hear the sound from all sometimes the sound is really faint if you are in surround mode
Thank You and good luck
Aug 28, 2008 | Nakamichi AV-7 Receiver
Problem with Surround Sound when watching TV
No wonder you havent gotten no reply your listed under wrong tv
May 06, 2008 | RCA D52W19 52" Rear Projection Television
Center speaker
mine is doing the same thing, you can hear a click sound and the channel will die. I think it is a relay or a shunt that trips when something goes wrong with that amp. I dont think it is worth repairing as there are some nice receivers out there for cheap. Maybe just a cold solder joint somewhere? Anyone know where and Ill dive in and resolder and post the results.
Feb 24, 2008 | Sony STR-DE545 Receiver
Bose cine mate speakers
No it won't be like surround sound, but you'll have the next best thing: a nice, powerful, natural Hi-Fi sound. I have a 46 inch 1080p Sony connected to a Sony Blu-Ray and Bose Cinemate Speakers. No complicated rear speakers wiring, no awkward center speaker to hide. The only drawback is that Bose doesn't have (yet) a code to operate the Blu-ray player with the Cinemate remote control.
Hope this helps to make your decision.
Feb 17, 2008 | Bose Cinemate Digital Home Theater System...
No Sound
Hello, Just checking one thing that could be preventing your audio from working.____If you take a look in the red circle in this picture, make sure the jumpers are on as indicated OR make sure the case audio cable is connected in there.
May 17, 2007 | ASUS P5S800-VM Motherboard
Onkyo srtx601 receiver
Please add a comment to your previous post next time, it makes it easier to see this post has a relevant history. I had to go check in your profile when I saw the word "still". Shooting in the dark, and saying the obvious(just bear in mind a month ago I was going crazy over a problem that ended up being the blanace knob turned to the right) - could it be that you're not using a digital signal? I'm not sure you can get surround with analog. Make sure all settings are for digital, and that you're using a coaxial/optical cable going from the DVD to your receiver. I hope you'll end up embarassed but happy. Good luck
Jun 17, 2006 | Onkyo TX-SR601 Receiver
Sony BRAVIA  KDL-46S2000 46 in. LCD HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
