Question about Dynex 32 in. LCD Flat-Panel HDTV
Dynex tv codes for universal remote
Ccc
  • jvelasco183 Feb 02, 2009
    I tried to program my 32 inch lcd dynex tv to my dish remote with no results,dose dish net works even work with dynex?
    Champion:
  • 279 Answers
How do I fix 2004 545i computer?
check any exposed wire behind CCC, If all wires checked ok, you need to replace CCC. After you replaced CCC needs to be programmed. It cost you a lot of money. I hope this will help.
May 12, 2014 | 2004 BMW 5 Series
How to log on to D-Link dgs-2208_ds
On your computer, enter the 'IPCONFIG' command.
Find the IP-address for the "gateway".
Start Internet Explorer, and enter 'http://aaa.bbb.ccc.ddd
where 'aaa.bbb.ccc.ddd' is the IP-address of that "gateway".
Login with ID/password of the router.
Apr 27, 2014 | D-Link DGS-1008D 8-Port Gigabit Ethernet...
Ccc.exe
Ccc.exe is a process for Catalyst Control Centre: Host application, see what is ccc.exe So, try to un-install Catalyst Control Centre and install newer version.
Nov 29, 2012 | Samsung R600
Hi, I have a BMW 525D '06 My problem is that the navigator suddenly stop working - "Reading error. Please insert DVD" and I can not use the navigator. Often it occur after aprox one hour drive....
This SIB may apply to this issue:
SI B 65 24 07
Audio, Navigation, Monitors, Alarms, SRS August 2007
Technical Service
SUBJECT
CCC Navigation Map DVD not Detected
MODEL
E90, E91, E92, E93 (3 Series) with SA 609 (CCC Navigation)
E60, E61 (5 Series) with SA 609 (CCC Navigation)
E63, E64 (6 Series)
E70 (X5) with SA 609 (CCC Navigation)
Vehicles produced from 8/31/2006
SITUATION
When entering into the navigation system, the screen only displays "Please insert DVD", even though a DVD map is inserted in the drive.
CAUSE
Incorrect map DVD
CCC software or hardware error
PROCEDURE
On a customer complaint basis proceed as follows:
Always verify that the correct map DVD is used (identified by DVD-CCC). Try a known good map DVD and see if the problem is resolved.
Update the complete vehicle per SI B09 05 01 (Programming and Coding with Progman) Procedure B, using Progman 25.00.00 or higher.
If the fault is still present, replace the DVD drive. Refer to Repair Instructions RA 65 83 580
PARTS INFORMATION
Part Number
Description
Quantity
Refer to EPC
DVD drive
WARRANTY INFORMATION
Covered under the terms of the BMW New Vehicle Limited Warranty.
Please refer to the latest KSD for all applicable labor operations and allowances.
If the appropriate labor operation is not contained in KSD, then a work time labor operation should be used.
Mar 07, 2011 | 2007 BMW M6 Convertible
Can't setup dual monitors on ati radeon x1050
Hello
You might have installed ATI's CCC, "Catalyst Control Center", along with the display drivers. I suggest you download the latest combo-CCC and drivers for your video card. ATI comes out with new drivers pretty fast. When using dual monitors CCC is where you want to setup your monitors. After you set up the catalyst control center you'll find it much easyer to assign what monitor displays what. One other suggestion. ATI will want you to uninstall any other software for your ATI card even though all you have is ATI software.
Hope it helps, if so do rate the solution
Dec 21, 2010 | ATI Computers & Internet
CPSS over L2ckt over fast ethernet
[NB3600]---fr_uni---(PE1)----FE----(PE2)---fr_uni---[NB3600]----[NB NMS]
below is the config.
> *PE1*
> fe-0/0/0
> description "conctd to PE2";
> mtu 1546;
> unit 0 {
> family inet {
> address 192.168.0.1/30;}
> family mpls;}
> e1-1/0/0
> description "conctd to NB3600";
> encapsulation frame-relay-ccc;
> lmi {
> lmi-type ansi;}
> unit 0 {
> point-to-point;
> dlci 513;
> family ccc;}
> l2circuit
> neighbor 192.168.1.254
> interface e1-1/0/0.0 {
> virtual-circuit-id 513}}
> *PE2*
> fe-0/0/0
> description "conctd to PE1";
> mtu 1546;
> unit 0 {
> family inet {
> address 192.168.0.2/30;}
> family mpls;}
> e1-1/0/0
> lmi {
> lmi-type ansi;}
> unit 0 {
> point-to-point;
> dlci 513;
> family ccc;}
> l2circuit
> neighbor 192.168.0.254 {
> virtual-circuit-id 513;
Jul 03, 2009 | Alcatel Newbridge MainStreet 3600...
My ducted dometic roof unit wont cycle on when i try to reset t stat it reads ee i think my upper board is bad
The upper board is a possible problem, however before you drive yourself crazy after purchasing a new one and it not working, try removing the CCC from the wall and obtaining a piece of the cable that connects the upper unit to the CCC. You should be able to get this at any local Dometic repair facility or dealer. With this piece, plug the CCC directly into the upper control and try resetting it. If this does not work, then it is either the CCC or the upper control board. You can also try turning all the dip switches to off in the control board and resetting the CCC and then turning them back on to their original position and resetting. This will sometimes work if the two just lost communication.
Hope this helps,
Jeff
Rate me please!
Jun 24, 2009 | Dometic Rooftop RV Air Conditioner
A/C Thermostat display is blank
find the stat wire and jump red to green to see if fan comes on if so then stat bad if not check for 24v ac transformer or 5 amp fuse
May 08, 2009 | Heating & Cooling
Have a Rowe Ami mmcd-1 jukebox but having keypad problems
Rowe Ami jukeboxes are prone to dry joints (called cold joints in the USA), this is cracking around the soldered connection pins that connect the wiringing to the circuit boards. If you can solder correctly then I would advise you to check all of the boards for cracking around any of the pins on the boards. So check out the following:-
Power supply board
CCC
Mechanism control/decoder
Keyboard
I would check out the Keyboard/Display the display board controls the title flip buttons.
I have seen a nuber of brand new display units for sale in the USA on Ebay for very little money.
When these were first made they were an arm and a leg. If you bought the combined unit that was put into the HML hideaways you could refit into your jukebox.
If You are not good at soldering then my advice would be send the boards to a Rowe Ami specialist for testing/repair.
Regards
Alan Hood
ami-man
UK
Jul 24, 2008 | Wurlitzer Jukebox CD Player
ATI Mobility Radeon X600 continuing problem
Hi eltrury,
Here is a link to explain Modding. http://en.wikipedia.org/wiki/Modding
You're notebook share's you're main system memory with you're onboard (Video card built into you're notebook's main board).
If you're notebook has a total amount of system memory of 512MB & you're video card is using 128MB to function. Than you're notebook will only have 128MB to run. (And that is not enough for a Windows XP system to function. It will run! Like a dog with two broken legs. You're video card is an ATI. That said, ATI comes out with newer versions of its software drivers quiet often. So upgrading you're software can be preformed once a month, if you like. ATI's catalyst control center is part of the ATI's software. CCC is a section of software where you can adjust a range of settings to you're preference. Like add more red color to your monitor. Adjust you're display screen. It's a long list. There is a Help button within CCC.
Most people never need to enter CCC. It's for people who know what to adjust & why. CCC's greatest function allows people to run dual monitors. CCC can detect when two monitors are connected to the video card & the user can adjust the color for each display separately. CCC is also acts like a software manager. It helps keep the video running stable. For those who do not have an abundence of hard drive space you can elect not to install CCC & just download the driver software.
This next link will take you to ATI's web site.
http://ati.amd.com/support/driver.html
Here you need to click on three choices. In the first window you would click on you're operating system. EX: Windows XP home or pro. Than you would click on ATI Mobility Radeon. Than click on, Mobility Radeon X600. Lastly, click on the GO button.
Suggest you run the Installation Verification Software on the site. When it finishes the ATI software should start the download.
Enjoy!
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 21, 2008 | Computers & Internet
Dynex 32 in. LCD Flat-Panel HDTV Logo
251 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
