Question about Fisher and Paykel IWL12 Top Load Washer
When washer is filling it makes a load screeching noise
Washer is fisher paykel model IWL 12
  • Anonymous Mar 14, 2014
    Load screeching noise when filling
  • 145 Answers
Hi, welcome...
Your water pump is going bad most likely. This is easy to diagnose and also easy to repair. Under the control panel on top is a "tech sheet" that explains how to put the washer in "test mode". Set the machine in test mode and run the water pump independently and you will probably hear this same "schreeching" sound. The water pump runs at the begining of the wash cycle to recirculate the water and mix the detergent with the incoming fresh water. You also can "check" this by using the "PERMA PRESS" cycle. The perma-press does not use the recirculation feature, so the schreeching noise will be delayed to the first rinse cycle if the pump is bad.
The part number is 420325P and you can get them from
Posted on Feb 01, 2009
Fisher Paykel washer makes a screching noise
Turn the washer over and see if this model uses a belt to drive the transmission for the washer, if so replace it, I will bet it does, if not the transmission is defective.
Oct 07, 2016 | Fisher Washing Machines
Replace fisher paykel iwl 16 mother board with gwl 11 motherboard
I cannot find your mothers IWL16 model, but I have found various similar machines that are the same phase as your GWL11 machine, the electronics in there although different are compatible, you can swap the drain pumps, there almost universal, avoid the drive shaft machine, fix the other one If you want further help, post a photo of both pcb's (the electronics) After swapping your machine will stil require programming which is simple enough
Sep 14, 2012 | Fisher and Paykel GWL11 Top Load Washer
Model IWL 12 error code 12
CODE 12: Flood protection error.
If the water valves are on contiuousy, check that the valves
turn off mechanicaly (remove power from smart drive.
Secondary source: check the pump for blockage and drain hose
for correct height and kinking
Sep 25, 2010 | Fisher and Paykel (IWL12)
Screeching noise after water starts going in
Hi just read your posting.Now put the machine to a spin cycle and push start,Does the noise happen in this cycle? If the noise doesn't happen then try a cold water fill but turn the hot tap off first.If the noise still doesn't happen then try a hot water fill but turn the cold water off first. This noise sounds like one of your water valves is faulty.Please reply with additional information on the questions and I am sure we can rectify this fault.
Jul 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Replace drain pump
Hi just read your posting.Now if you look underneath the machine have you got the pump with a fan on it?It should be colored red or black.If you have this pump type the locking tab is on the right hand side of the pump looking from the front of the machine.If you have the other type it has two screws holding it to the base of the bowl.Hope this helps and please reply and tell me which pump type you have and if you require further help.
Jun 09, 2010 | Fisher and Paykel IWL12 Top Load Washer
Fisher Paykel Gw11, leaking, loud noise, not going through cycle
pump is a common fault and easy to change for about $25. all sound related. new machines are pretty inexpensive. your call
Aug 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
When filling with the side fill pump makes loud screeching noise
Hi Tom. if the noise is a loud SCREECH that almost sounds like a wounded bird, you need to replace the water pump. The part is easy to replace with no tools and you can get one from Fisher Paykel Parts:
Dec 11, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel IWL 16 ''I need service'' message & fault code 12
The first thing to do is to check if the water valve is good - probably burnt /stuck open.
Nov 16, 2008 | Fisher Paykel Eco IWL16
Screeching Noise From Fisher & Paykel GWL115 Washer While Filling
if its while filling may be water pressure try turning tap down (hot)
Apr 04, 2008 | Washing Machines
Fisher and Paykel IWL12 Top Load Washer Logo
374 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
