Question about Microwave Ovens
Sanyo microwave model em-s5002w won't heat...sounds louder
My 4 yr old Sonyo microwave model #em-s5002w, suddenly sounds louder and won't heat anything. Turn table and inside light still work as does the outside control pad.
Too new to go bad. I unplugged it and plugged it back in again and nothing changed.
    President:
  • 1,214 Answers
Sounds like a component failure in the microwave circuit.
It will be one or more of the following -
Fuse
Diode
Capacitor
Transformer
Magnetron
Reply back and I can help you more. These failures happens to new or old microwaves.
Posted on Feb 01, 2009
I have an old Sanyo Microwave Model EM-FL90N which has worked great, everything works but it seems not to be heating stuff up. The manual is not of much help either. Any suggestions? Help?
Javaid,
You might want to consider replacing the microwave if it is more than 8-10 years old. Sounds like you have a magnatron that is going bad and that is what does the cooking, and to replace it could cost you almost as much as a newer microwave. Hope this helps!
Mar 24, 2016 | Sanyo Microwave Ovens
Model em-p672w. What caused it to stop working?
Sanyo EM-P672W Microwave Oven Repair Questions ...
www.fixya.com > Forum > Microwave Ovens > Sanyo
Recent Sanyo EM-P672W Microwave Oven questions, problems & answers. ... Mysanyo super shower microwave wave stopped working it shows on the display to press clock key but ... What would cause my Sanyo Microwave to not heat up?
Sanyo EM-P672W Microwave Oven Sanyo microwave fuse ...
Nov 19, 2015 | Sanyo Microwave Microwave Oven
How do I use power feature?
Sanyo EM-S5002W Instruction Manual & Cooking Manual
www.manualslib.com > ... > Instruction manual & cooking manual
Sanyo EM-S5002W Manual Online: Control Panel And Features. OPERATION (1) ...Sanyo instruction manual microwave oven em-s5002w. Hide thumbs ... cooking. (4)POWER LEVEL. Use to set power levels other than. 100%. (5) KITCHEN ...
Oct 09, 2015 | Sanyo Microwave Ovens
I wish to replace a lightbulb
MOSTLY A SAMM DOOR ON THE SIDE...U NEES A SCREW DRIVER..OPEN IT UP AND REPLACE THE GLOBE..AND REFIT THE DOOR
Oct 18, 2013 | Sanyo EM-S5002W Microwave Oven
I need to change the lightbulb on my em-s5002w Sanyo Microwave. What screwdriver size & style do I need for lower star-shaped screws
The star-shaped screws are called TORX and range in size from T-1 [small] to T-50[ quite large]. a set of inexpensive bits that fit a driver handle can be found at a hardware or auto supply.
Jan 24, 2013 | Sanyo EM-S5002W Microwave Oven
Can i make a cake in sanyo EM G4753?
Yes. Follow the cooking instructions supplied.
Dec 23, 2010 | Sanyo EM-S5002W Microwave Oven
No heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
djghn
May 25, 2010 | Sanyo EM-S5002W Microwave Oven
How to replace light
there is either a panel on back of unit you can remove and light bulb is there, if not you will need to remove case to change bulb.
Nov 25, 2009 | Sanyo EM-S5002W Microwave Oven
The cardboard cover inside the microwave broke, how do I get a replacement. Is it safe to run it without it ?
NO, it's NOT safe to run the microwave without it.
It's not that it's harmful to you--because it's not--but it IS harmful to your microwave. That cardboard cover that you're talking about is called a "mica shield," which, in short, protects your microwave from frying itself.
I'd say talk to Sanyo to see if they can get a replacement for you (which they usually can, or they can at least tell you where to get one). According to their website, www.us.sanyo.com , it doesn't look like they have a support phone number, but they have service locators--I'd say if you can give one of the centers a call, and give them you model, they might be able to help you out with getting the mica shield ;)
Good luck! :)
Aug 28, 2009 | Sanyo EM-S5002W Microwave Oven
Sanyo microwave EM-X515G
I'm thinking that the circuit board has a problem. I doubt it will work but disconnect all the connectors on the board...with the power off and reconnect. It may clean off some goo. If not, use your method as long as it will work and then consider a new board.
Dec 15, 2007 | Sanyo EM-S5002W Microwave Oven
Microwave Ovens Logo
217 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
