Question about Pool & Spa
Hi, We have the above ground large pool. It was given to us with no directions to put it together. We watched the video My question is are you suppose to cut a hole in the liner for the pump hose or for anything to put it together? My Husband and I say no..Can you help? Thank you Claudia
  • 297 Answers
Do not cut anything
all intex pools come preformed,holes cut, and ready to go
go to intex.com and pull up the manuals in pdf form and watch the videos on there web site also
Posted on Jul 13, 2009
  • 547 Answers
No there should be a attcment all ready there
Posted on Feb 12, 2009
Ive got power, hot and cold to my existing pump and shower, but the pump doesn't start, just makes a whirring noise.
Above Ground Pool Pump Won't Start or is Humming & How ...
? 6:16
https://www.youtube.com/watch?v=RH78q36liks
Apr 15, 2014 - Uploaded by Above Ground Pros
Above Ground Pool Pump Won't Start or is Humming & How to Fix It ... Pool Motor - Humming-Loud Noise ...
How to fix your pool pump from humming - YouTube
? 2:43
https://www.youtube.com/watch?v=3v2v6aDDq9A
Mar 25, 2013 - Uploaded by James Hayward
Do you have a pool pump not priming (pumping water) andmaking a humming noise ... not only give a ...
pool pump makes humming noise and does not pump - Trouble F
Dec 08, 2015 | Home
REPLACE POOL LINER
Good luck on your warranty. I'm sure it will be pro-rated. 10 years is a long time for a liner to last. It usually costs 2,000-3,000 for a new liner and installation.
Jul 11, 2014 | GLI Pool Products Pool & Spa
I have a proline de 1.5 hp above ground pool filter. How much de do I put in the filter? Thanks
one pound of D.E. for every 10 square feet of filter area, there should be a data plate on the filter telling you what the filter area is.
Jul 30, 2011 | Waterway 1.5hp Hi Flo Above Ground Pool...
Our dirt devil pool cleaner keeps sticking to the pool floor and will not move around, what do we need to do?
Make sure that your unifram is installed with the opening in a vertical position. If it is horizontal, you pool cleaners line will not have proper suction. You will also want to check for obstructions in the flapper that would cause the cleaner to not move properly. Finally, make sure that this is the proper cleaner for your pool size. If you have an in ground or very large above ground pool, it is possible that the pump you are operating with is too strong for the cleaner to move properly.
Apr 09, 2011 | Dirt Devil POOL CLEANER FOR ABOVE-GROUND...
I have a Pool Eye PE23 and the instructions don't show how to install it on an above ground pool. Do I put it on the railing as I haven't got a deck for the pool?
This particular pool alarm is made for an inground pool. As far as I am aware, you cannot use in on an above ground pool. You will need a pool alarm that is designed for an above ground pool.
Aug 04, 2010 | SmartPool PoolEye In-Ground Pool Alarm...
Skimmer and Vacuum set-up question
Here is a link to Intex website for the manuals and videos. Intex Pool
Jun 25, 2010 | Intex "" Metal Frame Pool Set (56998e)...
Sand in above ground pool
what type of sand make sure its for pools should only have 2 bags max in filter
Jul 24, 2009 | Hayward Pro Series 18" Above Ground Pool...
I have a intex above ground pool 18 x 42 and I need a manual to help me with the filter how do I put it on
go to intex.com
they have a few pdf files and also videos showing how to do it.
Although these are the salt water system it is still the same set up and procedure. Just pretend it is your pump when reading or watching the video
Jul 14, 2009 | Intex Easy Set Pool 15x36
Lopsided 18x4 intex round easy set pool
I started out with easy set pools a few years ago and finally gave up and went to their steel supported ones.
I have put up over 20 above ground Intex pools and have learned a few things in the process:
A: The larger the pool with the air ring at the top the more difficult it is to fill to its maximum potential.
B: Eventually the pool is going to collapse with people in it, especially if someone leans over the edge with their arms on it which is a perfectly natural thing to do.
C: It is virtually impossible to get an area beneath the pool level without scraping the ground and measuring it with, in your case, at least a 16' long 2"x4" on its edge with a level on it.
D: Trying to build up the ground on one side with sand will eventually result in collapse of the pool.
E: There is a type of stiff styrofoam ring that you can buy in sections to go around the bottom of the pools, but that will also result in collapse unless it is used for what it was developed, and that is a rigid wall pool.
F: Out of the three types of pools that Intex sell, the easy up with the air ring (the worst), the steel supported all the way around (next worse). and the rigid side, only the rigid side is forgiving to a tiny degree where unlevel ground is concerned.
For your size of pool everything must be exact and completely level or at one point it will collapse. There is little more discouraging than seeing all those gallons of water run out onto the grass. Once the water goes over the edge, no amount of people can prevent the collapse.
Finally I have learned that, with above ground pools, you get exactly what you pay for. My 5th above ground Intex pool was the best, but even with the ring around the edge at the bottom and the rigid side, I was still wasting my money unless the ground was aboslutely level. You just have to cut away the dirt until the level shows no angle.
I wish you all the luck. If you feel a desire, I have 5 Intex pools in my barn I will give to you if you pay the freight. Each was a dissapointment and a waste of time, energy, and above all, money.
I finally spent about $750 on one, had a professional crew level the ground, and it stays up through the winters even.
May 25, 2009 | Intex 15' X 42" Easy Set Pool Complete...
Pool & Spa Logo
617 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
