Question about Krups Bravo 871 Espresso Machine
How do operate switches inwhich order
How do you operate the switches on krups basic
  • Anonymous May 12, 2009
    i need a user guide for a Krups Type 871 coffee/expresso machine free download (pdf)
  • 13 Answers
Posted on Jun 22, 2009
Combination espresso-coffeemaker XP228. Where can I obtain user instructions?
The documentation seems slim online. I'm guessing perhaps you might have meant a Krups 2280, since the only Krups 228 reference I can find leads to a site trying to download a .exe file, which I'll decline to pursue :-b One site (
XP 2280 Manuals ) says you can order one, but I'm generally suspious of anything wanting you to use their downloader or such. I did find one for a Krups 2070 (
http://kitchen.manualsonline.com/manuals/mfg/krups/xp2070_1.html ) that looks very similar to the XP2280 machine. I hope that helps.
Aug 23, 2015 | Krups Coffee Makers & Espresso Machines
Krups Grill FDE3
If NO LIGHTS come on and not a single thing operates, I too would say that it's most probably the THERMAL SWITCH, activated when the motor gets too hot and is in danger of damage. A very cheap electronic device, quick and easy to remove and replace.
Mar 10, 2014 | Krups GVX2-12 Electric Burr Grinder
Krups xp 7225 replaced piston, reassembled and is now dead, power switch seems ok and all wires firmly attached
Your Power Switch Part No Ms-0675088 need to change.,your
machine have appear any error No ? God Bless
Joseph
Jul 23, 2012 | Krups XP7225 Espresso Machine
Where can I order a krups xp series seal MS-0A01503? It is a seal for the plunger that expels the coffee cake after brewing. It started to leak and I need to replace it.
Nelson Appliance has this: http://goo.gl/bsjqj. I think this is what you are looking for. The description they give is: Boiler center gasket / seal #MS-5015004 for use with Krups XP7000 series espresso machines.
Aug 31, 2010 | Krups Coffee Makers & Espresso Machines
What are the heirarchy of operation?
The following information on "Hierarchy of Operations" was taken from Pages 45-46 of the "Microsoft QuickBasic 4.0: Basic Language Reference" manual for Versions 4.00 and 4.00b. This information also applies to the following products:
  1. Microsoft GW-Basic Versions 3.20, 3.22, and 3.23
  2. QuickBasic Versions 1.00, 1.01, 1.02, 2.00, 2.01, 3.00, 4.00, 4.00b, and 4.50
  3. Microsoft Basic Compiler Versions 5.35, 5.36, 6.00, and 6.00b
  4. Microsoft Basic PDS Version 7.00.
MORE INFORMATION The Basic operators have an order of precedence, that is, when several operation... loadTOCNode(1, 'moreinformation'); The Basic operators have an order of precedence, that is, when several operations take place within the same program statement (without being grouped by parentheses), some operations are executed before others. Operations are executed in the following order:
  1. Arithmetic operations
    1. Exponential (^)
    2. Negation (-)
    3. Multiplication and division (*, /)
    4. Integer division (\)
    5. Modula arithmetic (MOD)
    6. Addition and subtraction (+, -)
  2. Relational operations (=, >, <, <>, <=, >=)
  3. Logical operations
    1. NOT
    2. AND
    3. OR
    4. XOR
    5. EQV
    6. IMP
An exception to the order of operations listed above occurs when an expression has adjacent exponentiation and negation operators. In this case, the negation is done first. For example, the following statement prints the value .0625 (equivalent to 4^-2), not -16 (equivalent to -(4^2)): PRINT 4 ^ -2 If operators on the same precedence level appear in the same expression, they are computed from left to right.
For more information on the "Hierarchy of Operations," consult the Basic language reference manual for your version of Basic. Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 13, 2010 | Microsoft Windows XP Professional
Krups 229 Aroma control switch is broken
Hi john you need to replace circuit board that has timer and auto shut-off I have same problem krups doesn't think it is a safety issue because the coffee maker has a thermal switch. But I still think it is. Also if you are not carefull when you fill with water it will staem back in your face!
SmallAppliance.com has special order replacement boards.
I will be replacing mine
Jul 04, 2009 | Krups Aroma Control 229 Coffee Maker
I have a krups xp2070 coffee/expresso maker just stopped working
Most likely your power module failed. Mine went bad after 18 months of operation. You can order a replacement power module and control module from a Krups service center or from SmallApplicance.com. The replacement is not easy since you have to disconnect all the electrical connections. The module is about $60. I don't know how much the service center will charge to replace it.
Jun 13, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Krups cappuccino manual
Don't know if your still looking, but if you go in the customer service section of the Krups website (krups.com) and ask them for the manual they will email it to you. Or, email me and I can send it to you!
Oct 29, 2007 | Krups Bravo Plus 872 Espresso Machine
Lost operators manual for my Krups 888
The Krups website has all of the manuals available for downloading.
Apr 29, 2007 | Krups Caffe Centro 888 Coffee Maker,...
Krups Bravo 871 Espresso Machine Logo
261 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
