Question about Whirlpool Calypso GVW9959K Top Load Washer
LD code appears after a few minute of starting the washer
Whirlpool washer calypso gvw9959k
  • Anonymous Feb 08, 2009
    Just started yesterday. ld ( Long Drain) came up after a few minutes. The book says check the drain hose for kinks or clogs. Emptied the washer and tried to drain, then got ob (off balance).
    Tried power reseting and starting again, ld again.
    Scholar:
  • 49 Answers
Check the pump impeller for debris. Coins, socks, draw strings - etc. - can get sucked in and jam or slow down the pump. To check this you have to go into the washer from beneath (unplugged, and manually drained or wet/dry vaccuumed out). Remove the clamps which hold the water tubes onto the pump motor, taking care not to spew water into the motor windings (they're open). May have to put a finger or probe into the plastic pump tubes to see if there is something in there. If no debris, could be a bad or failing pump. The new design is a single piece of pump/impeller, and you cannot disconnect the pieces without a special tool. The old style pump/impeller can be separated and is a metal serrated shaft into a plastic impeller hole that can strip out when debris jams the impeller.
Posted on Jun 13, 2009
Whirlpool Calypso error code
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine and replace the part that has gone bad. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 31, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
What does "Ld" mean?
Ld
Long Drain
Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Check for obstructions.
www.appliancehelponline.com
Mar 22, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Get alarm code ld
CI code comes on just seconds after I start the machine. The machine itself is leveled on all sides.
Dec 26, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Our washer gets to about 23 minutes left and it comes up with LD. What does that mean?
ld is long drain time. Maybe you have something in the drain pump or stuck in the drain.
Nov 12, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso: LD error message
hi replace the hall sensor... this will remove ur LD error code...
thank u
rate me!!
May 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer won't empty water....
Ld Long drain "Ld" flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets.
Press STOP/CANCEL to clear the display.
Mar 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool washer error code problem
LD is long drain associated with two problems the drain hose install and the pump. Debris in the pump and a drain hose inserted too far will cause most of these issues.
Sep 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
What does ld mean on my washer?
op is probably ob, off balance, the ld is long discharge, most likely the pump is bad or full of junk, the origional pumps were updated to a better design so as not to get stopped up.
Aug 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
LD.;....................
LD= Long drain if the unit has taken more than 5 min to drain out the water this code appears.. you eiter have a pump issue or a pressure switch issue.. does all the water go out of the unit??
Feb 16, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
188 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
