Question about Kenmore 22422 Top Load Washer
Kenmore elite clothes washer model 22952
I have the same problem as others. The machine takes on water, but most of it goes down the drain. The water level does not rise; the machine will not engage the wash cycle.
Any advise, please respond here or contact
  • 15,935 Answers
If you have ever experienced the problem where you washer continually fills but never reaches the proper level (not an overflow). Or, the wash tub water level cannot be maintained, because the water level keeps dropping. You may be experiencing what is known as “siphoning”. This occurs when there is no air gap for the drain line at the standpipe. The standpipe is the drain pipe at the wall where the washer drain line is placed. With no air gap, a vacuum is created, and water will begin to drain from the wash tub prematurely. To prevent this from occurring, follow this advice:
* The standpipe should be 2 inches in diameter to allow a sufficient air gap between the top of the standpipe and the drain hose.
* The standpipe should be a minimum of 34” from the floor, and should not exceed 72 inches in height.
* DO NOT seal the top of the standpipe. Many consumers seal the standpipe in the belief that this will prevent overflows, or get rid of drain odors. This often creates more problems than solutions.
* DO NOT place the drain hose too far down into the pipe. Water stays in the drain trap area of the standpipe. If the end of the drain hose rests in this area, no air gap is created, and this can also cause siphoning. 4 to 6 inches is sufficient.
* The drain hose length must not exceed 10 feet in length. Excessive drain hose length can cause drain problems and back wash.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
Apr 25, 2017 | Kenmore Washing Machines
Got an F02 code on my Kenmore ELite HE3 washer. How do I unlock the door to get the water out?
Try pushing the start/pau botton several times,this causes the drain to start drining, when it stops and starts flashing again,push the botton again.The water needs to come down a level and sometimes it may start to spin.I've had several problems with this type of washer,But all machines do this.After you get the clothes to spin,remove them and put,draino-max gel or Rooto-rooter drain opener in drum and let it sit 1-3hrs.then run machine heavy-duty hot-water no clothes,you may have to run it several times to get all the cleaner out.the pump may be clogged with animal-hair or strings from clothes.good luck
Jul 10, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite filling w/ Water when not running
your water inlet valve on the back where the water supply comes in is leaking. It needs replacing.
Jun 03, 2010 | Washing Machines
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore HE4 washer won't drain. gets code f02
take bottom panel off ,,it has a screw out filter,,this filter fits directly in your pump..its clogged,,your pump is the fist part you see when you open bottom panel
Dec 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Quiet 2 Model 45862402
When the machine drains can you hear the water going into the drain? I thinking your pump is not pumping from debris or the drain hose to far in the drain. The kick panel below the door has three screws 1/4 or Torx T20. There is a clean out left side of the pump, the large screw handle removes and does have some water behind it so wrap a trash bag around the clean out before opening.
Oct 22, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3t model 42922
After the complete wash cycle is finished, the clothes are still soaking wet sometimes. This is not an every load problem.
Aug 12, 2008 | Kenmore 46462 Front Load Washer
Kenmore 22422 Top Load Washer Logo
265 people viewed this question
Sal De
 Brian Main
Brian Main
