Question about Jetway V266B Motherboard
Booting problem I have a jetway v266b motherboard that turns on and fans run but nothing else happens,no beeps nothing happens
  • Dick
    Dick May 11, 2010
    Has it been like this since it was new? How old is it now? What have you changed recently?
  • 3,153 Answers
Disconnect all devices from the power supply EXCEPT the motherboard
Remove any extra cards including video etc.(plug monitor into the onboard)
If you hear any beeps these can indictate where the fault is.
either of these sites below will help you further with that
Beep codes P
c
More beep codes
Power up the pc and see if the fans are working.
If not then double check the power connections to the board.
If you still have no fans it is time to suspect the power supply as the probable cause.
If the fans worked then you should have gotten a display which told you there was an error and offering you a chance to go into the BIOS. ignore it and shut down the PC.
Now connect one drive only and boot again.
Repeat that until you identify the component that is giving you a problem.
Once you find the problem then remove or disconnect and carry on with the rest to see if another component might also cause a problem
If there is only one problem device then you may want to investigate that device further, Unless you don't mind replacing it
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through fixYa.
Thank you
Posted on Nov 26, 2009
This is a known problem with the V226B motherboards unfortunately, we've seen quite a few of these (although strangely some are still perfect) and this seems to be a fault that develops with some, after some months or years in use. You may find that repeated power cycling will bring it back to life temporarily, but the only real solution is to replace it I'm afraid.
Neil
  • 50 Answers
Please check the RAM to begin with, unplug the power cord and remove the RAM. Now, plug in the power cord and try switching the Comp and see if there is a any sound from Mobo. It should idealy warn you that there is no RAM with continous BEEP. If that happens, the Mobo is fine.... Grab a new RAM and try it out. The system should boot now. (If there was "No RAM warning beeps" when you switched on the system without RAM). There are many issues that may put down the Mobo but in most cases its the RAM that stops functioning... Try this and see if it helps. Please post your result here so that we can see if you need further assistance.
Posted on Feb 09, 2009
Think cpu is bad cpu fan looked up
Replacing the bad caps and fan may fix the problem.
My guess - you need a new motherboard/computer.
Feb 01, 2013 | Jetway V266B Motherboard
I need a manual for the Jetway V266b rev.3 motherboard. Can you help in any way.
Here is the link:
http://www.machspeed.com/manuals/VIPER/V266B.pdf
Adobe reader will have to be installed on your PC.
Hope this helps
Chris
Sep 28, 2010 | Jetway V266B Motherboard
No audio
hi here is the link you need just copy and paste into top of the browser
http://driverscollection.com/?file_cid=388241075640e4766a71576556a cheers where the http is just to make sure lol
Oct 14, 2009 | Jetway V266B Motherboard
Cache
Cache memory is available inside the processor. So in order to increase the Cache you need to change your Processor.
Feb 20, 2008 | Jetway V266B Motherboard
Upgrade of ram
Your board Support 168-pin SDRAM DIMM and 184-pin DDR DIMM (Can't Use DIMM & DDR SDRAM memory Together).
I would run the 184-pin DDR. Supports PC1600/PC2100 DDR DRAM up to 2BG Max. Since you have four memory slots 2x512mb of DDR PC2100 = 1GB would be plenty. You will notice programs load faster & games run smoother. Personally, 2Gb. may help but you will not see the difference. To see a difference it is not all about memory. Mb bus speed, CPU, chipset & speed of video memory all play a part with regards to Pc overall speed. You can download your manual here.: http://www.jetway.com.tw/oldweb/evisn/download/manual/index1.htm
You can download the specs of your board here.:
http://www.jetway.com.tw/oldweb/evisn/product/amd/v266b/v266b.htm
And below is a link for some good ram.:
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=302039&CatId=548
This should all help you decide, best wishes!
Please vote.....
Jan 23, 2008 | Jetway V266B Motherboard
Want to up grade to 2g ddr mem
hi
is this your board?
http://www.geniyisis.com/index.html?/Jetway/v266b.htm
well, if this is your board, you can upgrade your ram to 2gb howerver since it is a dual ram...(SDRAM and DDR) you cant use all the slots at 1 time since they are of different frequencies.
you can use DDr266 (pc2100) as your RAM since this board is a socket A as it is said here in the boards specs.
hope this helps
No sound
I need audio driver for sis 530/620 because no sound
Sep 28, 2007 | Jetway V266B Motherboard
Jetway 867AS motherboard problem
Hi, the problem not your video. It is your memory module, it is faulty. Try another one that is surely working and it should boot right up. Good Luck!
Jun 02, 2007 | Jetway V266B Motherboard
Jetway V266B Motherboard Logo
392 people viewed this question
Top Jetway Computers & Internet Experts
john smith
Tony
Iqbal Husain
Iqbal Husain
Are you a Jetway Computer and Internet Expert? Answer questions, earn points and help others
