Question about Kenmore 24032\24036 Top Load Washer
Washer will not spin period. NO humm
Kenmore washer
  • Thomas Malailua
    Thomas Malailua May 11, 2010
    will it not drain also?if not its your lid switch!
  • 350 Answers
Dear FixYa Customer Ronnieh49,
A lot of TIMERS just get to much gunk in them!
With the OLD TIMERS you could open it up and spray it with a can of electrical cleaner (same as they sell for computers) and a lot of the time it would fix the problem!
This may also work on your circuit boards in a new appliance just be sure to read and follow the directions carefully!
I recommend Radio Shack for advice & purchase!
Cost about $10.
Good Luck!
jackiaria
Hope This Will FixYa!!!! Please Rate Me!!!
Posted on Feb 01, 2009
    Genius:
  • 2,920 Answers
Id say your motor isshot
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
Washer run through to final spin. stops before finish. motor humms but will not spin
washer works up until the final spin. how do I drain out the water?
Nov 23, 2009 | Kenmore Washing Machines
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Dryer will not start, just humms
sounds like the drum belt maybe broken or worn out.
May 25, 2009 | Kenmore 98702 Stacked Washer/Dryer
When the washer (fisher & paykel gwl 11) goes into rinse mode all it does is humms. The lid lock does nothing and when I fast forward to spin it does the same thing.
Try unplugging the washer to reboot the curciut board. Leave unplugged for 5 min. Then replug and select only one setting. Multiple setting selected in a short period on time will confuse the little brain in the board. Reboot to fix. Be patient!
Apr 30, 2009 | Fisher and Paykel GWL11 Top Load Washer
Kenmore washer humms and smells horrible....
You have a bad motor. ( very common) If you take your model number to a local used parts store you may be able to find a good used motor for cheap. If no luck finding a used one, Order it from sears. (the motor is deffinately your problem, I replace them all the time.)
Nov 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer
Has it stopped agitating completely now or does it start each time then stops? Do you hear anything - say like a humm when you try it afterwards. Dose it spin/drain water from washer?. Post a response so we could know what next
Regards
Sep 01, 2008 | Kenmore 24032\24036 Top Load Washer
Won't fill
check to see if the water is turned on? do you hear a light buzzing or humm noise?
Jul 26, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore washer direct drive
Most likely a bad motor. I have seen same results with a locked up gearcase, but you wouldn't be able to spin tub.
Jan 05, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Sal De
fordexpert
Robert Rankin
