Question about Konica Minolta magicolor 2300DL Laser Printer
My Dl2300 will not allow me to change the other two cartriges.
I have replaced the black and cyan it will not move beyond cyan.
You can go to the command panel on the printer and press the menu. Where it tells you about the amount of color that is left if you hit the color you need to replace it will automatically rotate to that color. All you will have to do then is open up the door.
Posted on Feb 04, 2009
I have a color printer hp office jet 7130 all in one and its only printing in cyan. is the printhead off? or broken can it be fixed and how much would it cost?
Go to paint create black,cyan,megenta & yellow images & print it, observe which colors are not printing,If back missed replace black cartrige, if any color missed out of remain three replace colour cartridge.There is no option to switch off the catridges & printer can recognise the faulty cartridge and it will show on displays.
You can order cartridges online.
Sep 25, 2011 | HP Officejet 7130 All-In-One InkJet...
Cyan ink cartage does not work in epson t11 plz tell me what can i do. lllllll;htgg;lp gkjhjjhkljkljkljiokggyu0ijhgjhpjnp[to[otto
Jast push some ink through the print head plastic pipe.Take a seringe of full ink, put off all the ink cartrige, then set the seringe front hole on the cyan black pipe (that are usually set in side the cartrige). Then push cyan ink into the pipe.
After that, I think your printer would work again.
Thank you
shohagtush
Oct 27, 2010 | Epson Office Equipment & Supplies
Hp clj 5550 not printing cyan
Check the black cover on the pick up assembly under the cyan cartridge. If it is only a fraction too high cyan will not print. Make sure it is clipped in place correctly.
Jan 20, 2010 | HP LaserJet 5550 Printer
After cyan ran out, installed new cartrige. Printer produced everything colored blue as red. Purchased new cyan cartrige and the problem recurred.
The problem seems from your new cyan cartridge.
It doesnt print cyan ink.
Try to clean print head and test print for each color
from the utility menu
Sep 09, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Epson rx595 changed to cartriges everthing fine
Try cleaninig the ink before reinstalling it again,if problem pesist,clean the surface contact on the printer and put back the ink,if pops up again,replace the ink.
Jul 13, 2009 | Epson Stylus CX6000 All-In-One InkJet...
HP 9000s Cartrige Problem
The Black cartridge chip is affected by its neighbors: Lc and Lm. Sometimes there's a problem with Lc or Lm chips and the printer says Check Black ink. You can keep changing the Black but the Black was OK. What can be done:
- clean golden contacts on all 3 cartridges (Lc, Lm, K) with alcohol
- if you can, reach with a long swab inside the cartridge slot on the printer and clean the gold pins there
- re-insert cartridges with printer OFF, and turn it on
- if still no help, you can buy spare chips online here: www.hp9000cartridges.com
Mar 23, 2009 | HP DesignJet 9000 InkJet Printer
Wont print ANYTHING if ONE ink cartrige is out
need to replace all to! some printers are like that wont print unless all inks are full and inplace!
Feb 26, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Cyan toner does not rotate to front to be change
um... Cyan is blue isn't it?
Magenta Pink,
Yellow = Yellow and
Black = black.
Oct 02, 2008 | Dell 3010cn Laser Printer
Colors Murky... HP DeskJet 1120c
REPLACE COLOUR CARTRIGE.IF THE CARTRIDGE IS DAMAGE ON THE INSIDE THE THREE COLOURS SOMETIMES MIX CREATING A COLOUR WHICH LOOKS BLACK
May 11, 2008 | HP DeskJet 1220c InkJet Printer
Konica Minolta magicolor 2300DL Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
