Question about Maytag Neptune MDE5500AY Electric Dryer
I need to get to the gas controller on my maytag 5500 dryer.
I can't figure out how to get inside the front of the dryer
  • 750 Answers
Hello jp_wilson
Welcome to Fixya
My name is Huum,
At this site is the schematics and diagrams of the unit
http://www.pcappliancerepair.com/model-display.php
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Feb 03, 2009
Neptune dryer 5500 no power
This dryer has 2 thermal fuses. One next to the control stat on the blower housing and another on the heater element. You could quite possibly have a bad blower wheel or simply a lint build up cauing over heating. To get inside this dryer you remove the door first. The you can remove the front. Once that is removed you can pop the top and get the front shroud off. You cannot work from behind.
Sep 17, 2012 | Maytag Neptune MDE5500AY Electric Dryer
Maytag gas dryer MDG6400AWW heats up for 2 minutes and that's it everything else runs. and twice I smelled gas when I opened the dryer door. the timer was replaced 2 years ago. Is there another problem?
turn gas off to dryer. For safety it is best not to wait get your gas company to find leak(i don't think they charge for that)if it is at the control valve you should take the screws that hold the coils down out.Remove coils and rubber O rings and replace all with new ones it comes as a kit
Aug 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag mdg5500aww gas dryer sensor
First of all shut off the power by pulling out the plug.
If you are sure of the sensor issue then you need to remove four screws on the inside of the door. Two screws are located on the left and two on the right, look at the hinge and you will find two. The door will lift out when you remove the screws. When the screws are out of the front, the front panel can be remove by pulling on the outside surface.
Aug 11, 2009 | Maytag Neptune MDG5500AW Gas Dryer
No heat and can't get front off
remove the door and the screws on opposite side pull front away and down remove corner brackets "L"s and raise top..unplug of course !
Jun 01, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDG 5500 AWQ heats sporatically
your dryer has a safety feature that it will not run or heat when the door is opened. It is so no gas fumes are exhauseted into your home. Once the safety is engaged, It will not allow the dryer to restart for a short while. It should clear itself after only a few minutes. Hope this helps, good luck.
Apr 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Need to clean Maytag Model 5500 electric dryer
HI THE FRONT COMES OFF BY REMOVING 2 SCREWS FROM THE BOTTOM ALMOST CORNERS AND PULL TOWARDS YOU THANKS THE APPLIANCEDOC
Sep 07, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Lint trapped inside dryer housing
SHUT OFF POWER AND GAS
1. Begin by opening the door removing the two screws on the left side of the door opening.
2. Then remove the screws that secure the door hinges to the cabinet. Lift off the door (may take some wiggling)
3. Grasp the outer top sides of the front panel and pull toward you.
4. Lower the front panel and lift off.
5. At each top corner remove the screw and latch that hold down the top.
6. You should be able to do the rest from here.
Jun 14, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
77 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
