Question about TruTech PVS31170S1W 17 in. LCD Television
Add cable channels to remote
Was using antenna now on cable
how do I add cable channels to remote?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
In most models, there would be a MENU button. Pressing on that would display choices, look for SETUP. Use channel up/down to move, volume up/down to select/. You would be provided with choice of AIR, STD, HRC or IRC, select CABLE. Thereafter perform CHANNEL SEARCH. In other models it would be similar with variations.
Pls post back result(s). Good luck and thank you for using FixYa.
Posted on Feb 01, 2009
  • 80 Answers
You want to go to the menu on your tv and keep going until you find the Auto-Tune Channels or Tune Channels. That will take a few minutes and after it is done you will be able to go through channels. If you are talking about Digital Cable you need to use the remote that came with your Digital Cable Box. Hope this is what your question is referring to.
    Genius:
  • 2,920 Answers
You need to get into the menu and change it from air to cable and then run the channel search.it will find all the channels and you wont have to do anything else.
  • 10,594 Answers
TV will search cable channels and store it in memory. Please start Auto Preset function in TV to store all available channel data in TV memory.
How can I get my channels set up
On what make and model TV using what system or service
Feb 02, 2018 | Televison & Video
I want to save the channels and turn my antenna to another direction and scan I loose the channels that I had can I save them some how?
The only way that I solve this issue is to write down the channels available from one direction on paper. Do the scan in the second direction. Return the antenna to the first direction and then manually add the rest of the channels. Depending on the TV, you either type in the channel number with the remote control or find a Add Channel option in the TV Channel sub-menu.
At least with my TV that doesn't have an Add Channel option in the Channel section, going to a digital channel with the remote doesn't store the channel number if the signal isn't strong enough for the tuner to resolve. Analog channels can be added when the signal is poor.
If you know all of the local channels in each direction from AntennaWeb ( http://www.antennaweb.org ) or TvFool
( http://www.tvfool.com ), you can use that documentation to add the channels at each antenna direction.
I hope this helps. If you use an electronic antenna rotor with a remote control, you may be able to program turning the antenna automatically when you change the channel. Check the documentation for the device to program this.
(Note: on my TV that adds channels only when I type in the channel number, recorded digital channels can disappear from the list if if I visit a channel with poor signal strength. Until the antenna is directed towards that transmitter, I can't add the channel back into the list.)
Nov 03, 2017 | Televison & Video
Connecting rca tv model#F20352SF to a tv converter box
  • Connect ANTENNA OUT of STB to antenna terminal on rear of TV OR, for better picture, connect 3-wire cable to color coded L AUDIO, R AUDIO, and video outputs on rear of STB and connect other ends to L AUDIO, R AUDIO, and video inputs on rear of TV.
  • If STB connected to antenna terminal of TV, set CH 3/4 switch on rear to whichever channel is NOT used in your area.
  • Connect antenna to ANTENNA IN of STB
  • Connect STB to power and use STB remote to turn on
  • Turn on TV
  • If STB connected to antenna terminal of TV, use TV remote to select channel 3 (or 4).
  • Use STB remote to select SETUP and perform channel search.
  • Use STB remote to change channels.
Oct 23, 2016 | RCA Televison & Video
Tv wont tne in to ch9 why iam getting all the other channels
If you are using an antenna to receive broadcast TV you may have to rescan to add channel 9 back into the TV's channel list. If this does not work, it may be seasonal or a weak signal from your channel 9 broadcaster. I use a signal booster on my antenna (purchased at Radio Shack..)
Dec 10, 2014 | Samsung Pn64d8000 64-inch 1080p 600hz 3d...
I HAVE A RCA 42" LED TV. I RECEIVE MY SIGNAL FROM AN ANTENNA. I CAN ROTATE MY ANTENNA, SCAN THE TV FOR CHANNELS, AND THIS WORKS FINE. THE PROBLEM IS IF I HAVE TO ROTATE THE ANTENNA FOR OTHER CHANNELS,...
on B:Press the MENU button on the remote.Select Setup.Select Auto Program.Choose Air or Cable.Select Auto Program to let the TV reprogram the channels.Check that the channel is programmed into memory. There are a couple of ways to do this: Use the TV menu system. Accessing this setting varies depending on the model TV that you own. Here are two options that are common on many TV's: Option A:Press the MENU button on the remote.Use the VOL and CH buttons to move through the menu and add any missing channels try this if not r
Do a full reset if this dosnt work
Dec 25, 2013 | RCA L42WD22 42 in. LCD Television
Want play from antenna
May just not be good enough antenna to receive the signal--try to with the remote direct enter a channel you expect to see and if it works you can in the menu add that to the memory---manually enter and add each possible channel.
May 01, 2012 | Toshiba MW20F51 20 in. TV/VCR/DVD Combo
I am trying to connect dish network as a remote Tv (a second tv) on my panosonic P46c2. My old tv connected with a coxial cable into the "antenna cable in". How do I see the picture on this tv?...
You may need to run a channel scan or add the channels manually in your TV menu. If you need assistance please e-mail me at: daniel.busa@dishnetwork.com
Daniel Busa
DISH Network
Customer Service
Apr 20, 2011 | Panasonic TCP46S2 TV
I can only get channels 600 through 900 which I have never see before.I cannot get regular channels or cable channels.It is not a flat panel t.v.Q1435A is the model number
Hi -
If you have a cable TV line connected directly to the TV, an antenna or a cable box connected by coaxial cable, I would suggest running the automatic channel scan (AUTO-PROGRAM) again:
1. Press the AV key on the Advent remote control repeatedly until TV is displayed in one corner of the TV screen. If you don't have the Advent remote, use the TV/AV button on the front of the TV.
2. Press the MENU key on the advent remote or the front of the TV to open the on-screen menus.
3. Use the CH+/- keys on the remote or on the front of the TV to highlight PRESET then press VOL+ to select.
4. Use the CH+/- keys on the remote or on the front of the TV to highlight ANTENNA then use the VOL+ key to select either AIR (for antenna) or CABLE.
5. Use the CH+/- keys on the remote or on the front of the TV to highlight AUTO-PROGRAM then press the VOL+ key to start the automatic channel scan.
Once the channel scan is complete, the TV should automatically return to viewing the first channel found during the scan. Do not press the MENU key during the scan or the scan will not complete.
If you are using a cable/satellite receiver and it is connected to the TV by any means other than a coaxial cable, you do not need to run the channel scan. You should simply select the correct AV input using the AV key on the remote or the TV/AV key on the front of the TV (see step 1 above).
If you have done all of the above and you are still unable to get the channels on your TV, please post back for further assistance. You can reply to me by clicking on "Add a Comment" below your question. Please let me know whether you are using a direct cable line, antenna or cable box, etc.
Regards,
BElectric
Mar 26, 2011 | Televison & Video
I pressed the menu button on my remote and went to channels then I went to antenna scan and lost all my channels how do I rectify this problem?
just go to menu and choose turbo/maunal search or go to channels and press right arrow key on your remote it will revert back to its previous settings
Dec 06, 2010 | Televison & Video
We don't have the original remote, but a universal. Channels only go up to channel 13. Is there a way to add channels?
Check that you have selected "cable" instead of "antenna" as a signal source and then autoprogram the set. These features can usually be found through the on screen menu using front panel buttons.
Oct 24, 2009 | Samsung TX-P3264 32" TV
TruTech PVS31170S1W 17 in. LCD Television Logo
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
