Question about Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum
Bad on/off switch hoover U6476
How can I replace switch
  • otisandlinda Feb 24, 2009
    I believe it has to do with the cable that extends down to just above the light. I am having the same problem.
It's probably the power switch. My switch was dicey for a couple years, finally gave out. Easy to replace.
Remove the two screws just above the WARNING on the rear of the upper handle assembly, then slide the whole assembly to the rear of the vacuum.
Remove the dust bag cover. You will see two holes just above the upper corners of the dust bag. Remove the screws from these recessed screw holes.
Open the furniture cleaner cover and remove the cleaner attachment. Remove the single screw that was hidden behind the attachment. Then remove the attachment housing by pulling it towards the front of the vacuum.
Inside you will see the rear of the power switch. Pull off the power wires (don't worry, easy on/off male/female connectors, no soldering).
The switch is held in by tension bars at the upper and lower rear of the switch. Firmly press down on one of both of the upper/lower tension bars, and push the switch through the housing from the rear of the switch.
Replacement part number is 28161067, about $2.50. Shop will charge about $85 to repair it themselves.
Posted on Feb 19, 2011
2 Suggested Answers
SOURCE: hoover windtunnel U6476-910 switch doesn't work
This has happened to me on at least two of my well used hoover windtunnels that I've owned. Easy fix: take the handle off and tightly wrap duct tape or electrical tape around the black plastic "switch rod". Doing that will make it thicker and thus able to activate the on/off switch again.
Posted on Feb 04, 2010
How release locked handle on Hoover U6476-910 vacuum?
heck for a release button or lever at the base.
Nov 28, 2015 | Hoover Vacuums
How to Troubleshoot hover and tunnel U6476
Hi! Below are step-by-step instructions for trouble-shooting your Hoover U6476.
1. Locate the primary filter behind the side grille. Wash the filter, squeeze it out and allow 24 hours to air dry outside of the vacuum. It should be washed about every other month.
2. Locate the secondary filter located in the vacuum base under the paper bag. The secondary filter can be washed in the same manner as the primary filter.
3. Replace the bag if it is full.
4. Remove the hose from both ends. Use a broom stick to gently loosen and clear any clogs from hose.
5. Remove the bottom plate and brush-roll. Use a wooden spoon or something similar to loosen and remove any clogs from the lower hose.
6. Check that the brushes are still spinning. If not, replace the belt.
Hope this helps!
May 31, 2014 | Hoover U6476-900 WindTunnel Vacuum
Beater bar does not turn. Belt is not broken but is so slack that it won't turn the bar. Do I need a new belt or is there a way to adjust the tension?
No, once the belt is stretched and worn there is nothing you can do, you have to replace them. Here is the belts you need for your model:
Hoover U6476-900 Belts
Apr 08, 2010 | Hoover U6476-900 WindTunnel Vacuum
My Hoover Dirt Finder red light stays on. All
Inspection of the circuit board found that the 470uF capacitor looked damaged. I replaced it and I now have the Green and Red lights are working correctly.
Jan 19, 2010 | Hoover U6476-910 WindTunnel Upright Vacuum...
I have a hoover wind tunnel model# u6476-900 and I'm having trouble replacing the belt. The extra belt that came with it was belt # 38528-035 and it's smaller then the old one and I'm having a hard time...
yes it is the right belt. the easiest way to get that belt on is to put it on the motor shaft first, stretch and start at the top of the self propelled pulley and rotate til the belt tracks on. you will need to keep pressure on the belt while you rotate the pulley. make sure you install the 38528-034 first before the flat belt
Jan 07, 2010 | Hoover U6476-900 WindTunnel Vacuum
I have a model u6476 self propelled hoover.The switch will not turn or off all of the time.The plastic slide does not operate the switch but slides over it.The switch seems to work easy enough by...
If the rod isn't pushing the switch, then something inside the handle asm. broke and isn't holding the rod in place. More often then not, it is the switch, but could be the rod in this case.
May 12, 2008 | Vacuums
Hoover U6437-900 / U6439-900 Windtunnel Bagged Upright Vacuum Logo
217 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
