The hot water faucet leaks from the deck valve bell when turned on. I removed the faucet handle and can see the top of the cartridge. Is the cartridge the problem? If so, how do I remove it? Where should I purchase a replacement?
It is a rubber gasket that is leaking, Pull the cartridge with a cresent wrench. There will be a paking nut on the top of the cartridge where the handle connects. You should be able to remove this with a pair of pliers. There will be a rubber o-ring inside. Take that to the hardware to to find a replacement to it. It wont be hard to match they keep tons in stock at ace or lowes
