Question about Toshiba Satellite M45-S165 Notebook
Boot problem I did chkdsk /r from a Windows Xp CD and after 8 hours it was on 56%. It stopped and said that this volume has one or more unrecoverable files (or something like that). I would format the hard drive but I need the data in it and i haven't made any backup. If I re-install windows will they be erased?
  • 596 Answers
When you install XP (again) it will search for previous installations, It will locate the previous install and ask if you would like to keep the current files or reformat the drive. Choose to keep the files. When the install complete, you will still have your files and a new install of the os. (NOTE: sometimes if your files are stored in those damaged file, they may be unrecoverable. With that, my other solution would be to install the os on a new hard drive and connect your 'old' drive as a slave. This should give you access to your files.
Posted on Feb 01, 2009
  • 129 Answers
If you repair the os using the cd, The personal files will remain as is.But if you format the drive and reinstall the os then everything is wiped out. Try repairing the os, If not then log on using the safe mode and copy your data on to a different drive. Or use a floppy to log through dos mode and back up your data
Unmountable boot volume
get a copy of hirens and run HDD regenerator I think you have some bad sectors and a corrupted windows.
Feb 03, 2013 | Dell Latitude D410 Notebook
HAL.DLL is missing or corrupted, xp doesn't boot
if it was running for more than 30 hours, it wasn't doing much. You can try copying hal.dll off of a known, good-working XP pc, and replace it with the one on your broken PC. It's better if you extract it from i386 folder but grabbing it from another pc should work fine.
Aug 09, 2012 | Microsoft Windows XP Professional
Cannot boot on any mode.
get a bootable xp cd boot from cd after booting press r key on the screen u get now xp will start in recovery console now login on it after type the command chkdsk and after completion chkdsk /p after that chkdsk /r exit recovery console restart pc if it doesnt work ur ram module has some problem
Jul 10, 2010 | Microsoft Windows XP Professional for PC
Stop: 0x00000ED
0x000000ED Unmountable Boot Volume
Boot to the Windows CD, go to recovery console, run CHKDSK /R see if the issue resolves, if not replace the HDD
May 15, 2010 | Dell Dimension 2400 PC Desktop
Blue screen/crash problem
All you need is to borrow an original cd and repair.
Boot from a windows xp cd.
Be sure to use the same version of cd like windows xp home or windows xp professional.
Also use you original windows product key.
Second repair option you can do..
You can run the command below and check works.
It will repair windows errors.
All you need to do is to boot with a cd xp an select repair options by pressing r.
then type the command below
Type in chkdsk /r/f
you will be prompted to dismantle the volume click yes
Ok
Jan 19, 2010 | ASUS G71Gx (G71GX-A1) PC Notebook
Unmountable boot volume hp pavilion ze4400
Recommend entering Windows XP CD, and entering R once the CD Boots up, and enters installation mode.
This will bring you into the Admin panel, enter password, and than enter chkdsk c: -f Once this is completed eject CD, and than restart XP.
Jun 30, 2009 | HP Pavilion ze2000 Notebook
HOW CAN I FIX MY COMPUTER? ITS READING UNMOUNTABLE BOOT VOLUME?
You need your Windows XP cd for this fix.
Boot from the Windows XP CD and at the first prompt, press "r" for repair. Press 1 when asked to choose windows installation and then enter the admnistrator password. If you don;t have one, just press "enter" and it should show you "c:\windows>"
At this prompt, type the following
chkdsk /r
THis should take quite sometime but will fix the problem at the end. when you get the c:\windows prompt again, type the word "exit" and your system will reboot and load windows XP normally
Mar 07, 2009 | Dell Latitude D600 Notebook
Machine will not complete recovery ''file c:\I386Dist .......DLL
I would recommend booting the laptop with a Windows XP CD and select "Recovery Console" option
Then once in the Recovery Console type the following CHKDSK C: /R
That will run the Check Disk (CHKDSK) utility and will probably fix your problem so that the files can be copied during the recovery process..
NOTE: THIS IS VERY IMPORTANT... Once you start the CHKDSK utility with the /R option
you must let it complete the task... And depending on the size of your drive it could take several hours to complete ..(even if it appears to be "stuck" it is NOT ...) When CHKDSK finds a bad sector it will then attempt to move the data to a good sector so that it can be used again (And this takes time even on the fastest PC's) And interrupting the process can possibly cause your drive to become unusable depending on what stage it was one and what it was doing. (And of course if it has been days or something and it hasn’t moved even a notch then of course go ahead and reboot it. But if it’s been just a few hours then LEAVE IT ALONE)
After CHKDSK utility is finished you should see some sort of message on the screen saying "CHKDSK found errors on the volume and fixed them all" or something like that. And you should be back at the command prompt. Just remove the XP cd from your drive and type "EXIT" and that’s it
You should now be able to restart your restore operation again and hopefully it will be able to recover that file..
NOTE: There are some occurrences where CHKDSK is unable to recover a file completely but this is very rare. (if that happens then let me know and we can move to the next step. But from the way it sounds your drive has errors that must be fixed before you can proceed..)
I hope this info helps
Darren K
///SYSTEM ONE Networks
Nov 19, 2008 | Gateway MX3215 Notebook
Boot volume err
Computer Crashes, they seem to happen at the most inconvenient times. Always when you need the computer the most. I've run across this boot error message many times since Windows XP was released and luckily most of the time this problem can be solved with a few simple steps.
Basically the error means that Windows XP is having trouble booting from Drive C. Following the steps below, you should be able to troubleshoot this problem and get your computer back and running.
Causes of Unmountable Boot Volume
Many times this error occurs when I have swapped a hard drive and used the wrong IDE cable to connect it. If your computer uses an Ultra Direct Memory Access (UDMA) hard disk controller, and you use a standard 40-wire connector cable to connect the UDMA drive, you may experience this error. Make sure you are using the correct IDE cable.
Also, if your BIOS settings are configured to force the faster UDMA modes, this error may occur. In this situation, restart your computer and enter the BIOS and load the "fail-safe" default settings and reboot.
If neither of these issues are the cause for the Unmountable Boot Volume, then the issue most likely is caused by a damaged BOOT.INI file in the root directory of the boot drive or file system corruption.
Follow the steps below to correct these file system issues:
1) Start your computer with your Windows XP CD-ROM, or with Windows XP boot disks
2) When the Welcome to Setup screen appears, press R to Repair the installation using the Recovery Console
3) If you have a dual-boot or multiple-boot computer, select the Windows installation you want to access
4) Type the administrator password when you are prompted, if no administrator password is set then just press Enter
5) At the command prompt, type CHKDSK /R and then press Enter
6) Once CHKDSK has finished checking and repairing the hard drive, type EXIT and press Enter to restart your computer
If this procedure does not work, repeat it and use the fixboot command in step 5 instead of the chkdsk /r command. FIXBOOT writes a new partition boot sector to the system partition. The fixboot command is only available when you are using the Recovery Console.
Oct 18, 2008 | Computers & Internet
Toshiba Satellite M45-S165 Notebook Logo
67 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
