Question about RCA 32F531T 32" TV
How to disable parental lock
Lost password was wondering if there is a way to reset it so i can watch the blocked channels MY toddler son was playing with our RCA tv and locked the tv on me. I do not have the org. remote ( believe he threw it away on me and i didnt know it thus went to dump) ..... PLEASE HELP !!!!! Not sure exaclty what RCA brand it is cause i bought it off of someone else when they were moving.... it is silver and has speakers built in on both sides on front of tv is tv/video button, menu, volum. up/down, chann. up/down and power button
    Scholar:
  • 85 Answers
You can go into the menu and see if there is a reset or something that will set the tv to factory defaults. This will erase all passwords for parental lock. If you can give teh exact model of tv that would be great it is usually on a sticker on the back side of tv. I hope this helps and if not if you can locate the model number i can help you more.
Posted on Feb 21, 2009
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Sansui TV/VCR/DVD combo
This solution is provided by one of our experts premtech
Child Lock
Combos
--Should have original remote. Press and hold the power button for 6 to 10 seconds
Combo Model T25208, V-Chip Forgotten Password
If you forget your password, simultaneously press VOLUME down on the TV/VCR front panel and the 0 number button on the remote for a few seconds. This resets the password and you can enter a new one.
Combo Model 13TVR62, V-Chip Forgotten Password
If you forget your password, press STOP/EJECT on the TV/VCR front panel and MENU on the remote simultaneously. This resets the password, but not the limits you’ve set.
Televisions with Parental Lock Feature
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
CTC169AU
Channels that have been locked can be viewed only when the PARENTAL CTRL function is set to OFF. This can only be done with the remote control-it can not be changed with the buttons on the front of the TV.
Therefore, after you turn on PARENTAL CTRL, you simply hide the remote control so that your children can not watch the locked channels. The locked-out channels will remain unviewable even if the TV is unplugged or the channels are autoprogrammed again. The only way to view locked channels is to use the supplied remote control to set the PARENTAL CTRL function to OFF.
The PARENTAL CTRL and the CHAN CTRL functions work hand-in-hand. The instructions below will first tell you how to turn parental control on or off with the PARENTAL CTRL function and then how to lock desired channels with the CHAN CTRL function.
1. Repeatedly press MENU to select SETUP MENU, and then press + or - to display setup functions. Repeatedly press MENU to select the PARENTAL CTRL function. . When this function is set to ON, PARENTAL CTRL is activated and any channels you locked with the CHAN CTRL function will not be viewable. . When this function is set to OFF, PARENTAL CTRL is deactivated and all channels are viewable.
2. To lock channels, press the MENU button to select the CHAN CTRL function. Select a channel you want to lock by pressing CHANNEL up or down. Then press +. The CHAN CTRL setting will change from NORMAL to LOCKED when that channel is locked. To return the channel to NORMAL, press the - button. Repeat step 2 for each channel you want to lock. If the PARENTAL CTRL function is set to ON while you are locking out channels, each channel will go blank as you lock it. When the PARENTAL CTRL function is set to ON and a channel which has been locked out is tuned, the TV will display the words PARENTAL CONTROL to let your kids know you have locked it.
CTC185's
If the front panel function buttons don't work, (menu, ch up/dn etc.) but the functions work normal with the remote, enter the "Channel" menu with the remote and turn "Parental Control" off.
CTC203's
In the event you have forgotten your password, perform the following procedure:
Press and hold for 3 seconds the TV button on the remote while pressing the menu button on the TV.
This procedure will turn off the parental lock and erase the previous password .
Another Possibility To Try For Various Models: If TV's in the Parental mode and askes for a password that's forgotten, Press menu on the TV, select Parental Lock #4 on menu, then with the remote press Mute, Display, Clear, and Reset buttons in sequence.
TX808 Chassis
If Parental Controls have been set and you don't know the password, do this:
Press and hold the volume down and the channel up buttons at the same time for 5 seconds.
Now you can reset the password to 0000, and using that password you can now access the V-Chip menus.
TV's (Made by Daewoo or possibly Apex, ie. GE model 24GP653)
The factory default pass code of 6688 is also the override code, in case the owner forgets their pass code. If that doesn't work, another place in the owners manual says to push Function and Mute on the remote at the same time. Function is the top right button.
Jun 28, 2008 | Sansui DTV2760 27" TV
Fpa lock on how do i get this offf
hello Lock/Unlock Parental Controls
Selecting this option lets you lock and unlock parental controls settings
using a password.
If you do not lock parental controls, none of the settings for V-Chip,
Channel Block, or Front Panel Block will take effect.
If you forget your password, press the MENU button, then select Parental
Control
(the password entry screen appears). Simultaneously press and
hold CH+ and VOL+ on the front panel for 8 seconds. Parental Controls
unlock and the Parental Control menu appears. You can enter a new
password by locking the Parental Controls again.
Front Panel Block
Selecting this option lets you block (disable) or unblock (enable) the TV’s
front panel. The remote still tunes to any channel. When using this as a
Parental Control method, remove access to any remote that is capable of
operating the television while you have the front panel blocked.
Don’t forget to lock parental controls after you change the status. If you
don’t, the front panel block will not take effect .if this don't work get back to me i've got manual good luck
shaun
Sep 19, 2009 | RCA R52WH73 Projection Television
Go in and reset the code.
Jul 02, 2008 | Televison & Video
your owners manual has the procedure for overriding the parental lock so you can re-set it again. It is a little complicated and requires the pushing of a couple of keys at the same time. Look at your manual. If you don't have it, download it from the net.
May 06, 2008 | Mitsubishi WS-55819 55" Rear Projection...
MAnual/Reset Parental Control Code
According to the manual, "If you forget the password, you can erase your current password by pressing the number 8 button on the remote four times, thn press the enter button to confirm the setting. PASSWORD: 8888"
A picture of an unlocked lock indicates that Parent Lock is NOT active.
Parent Lock Levels:
1: Kid Safe 5 : PG_R
2: G 6 : R
3: PG 7 : NC _17
4: PG_13 8: Adult
It also says that it takes 3-5 seconds to reset the unit to the factory default. I hope this helps! Karen
Feb 17, 2008 | Durabrand Portable DVD
Parental block
You can try these codes 2211 or 3308 if they do not work you will need to reset the unit. You will need to unplug it for 45 minutes that will reset the TV to factory settings. Then the pass codes I provided should work.
Sep 16, 2007 | Televison & Video
27inch tv serial# 27r410T
Press vol-on tv& child lock on Remote together. Press mode on Remote using channel +/- to select child lock select new pin press mode E
Aug 08, 2007 | Sharp 25VS-J250 25" TV
Lost parental password
GET TO YOUR SON THE PASSWORD HE ENTER AND WHEN ENTER IN THE PARENTAL AREA SET IT OFF.
Jun 07, 2007 | RCA F27664 27" TV
Most of the stations are blocked!
Welcome to the wonderful world of the vchip. Making better babysitters through tecnology. From what I understand the control if placed in a ram and cannot be reset without the password. I would call RCA and talk with a tech there might be a generic unlock code like on the old playstations. You may have to prove you are the rightful owner and over the age of 18.
Jul 30, 2006 | RCA E13319 13" TV
RCA 32F531T 32" TV Logo
238 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
