Question about Tomtom GO 300 GPS Receiver
My TomTom 300 Go screen base electrical prongs are bent
Please Help, my tomtom 300 Go Screen Base Electrical Connection
Prongs are "Bent" need to Fix. Where can I take it to get it Repaired?
I live in Mira Loma, California 91752 Zip Code area.
  • 416 Answers
  • 6,784 Answers
Best buy can repair this in house. you should get it back the same day.
Posted on Feb 01, 2009
TOMTOM One issue
call TOMTOM or go to their website, you may be able to send it back in for replacement or repair, it may even be covered by warranty.
May 20, 2009 | Tomtom ONE GPS Receiver
Turns off and on sporatically
Which model is it ?
On the Go 300/500 series there's a reset in the base. You will need a thin pin or similar to reset.
Take out the map card then turn the unit on.Push the pin into the reset hole at the base.
You will then get the start screen and the maps will reload once you replace the memory card.
On the 7 series, simply hold the on button down for approx 15 seconds until the start screen begins to show.
Apr 29, 2009 | Tomtom GO GPS Receiver
Have TomTom 910 Having Problems Charging it.
The 910 satnav/mounting interface is dreadful- it is the cause of half the problems on this site! You can order the battery on the net. Google VF5 or Samsung ICR18650-24. To replace, strip off rubber strips. You need a mini star screwdriver, carefully pull unit out of cover gently levering at the side. Carefully observe plastic carry through which acts as button on the front and base clip underneath- this must be reinserted correctly. It is a vital part of the structure- observe it carefully! Remove upper small PCB and large PCB after removing 2 electrical connectors. Battery located under PCB. Dispense with rubber mounting. Reassemble carefully battery holder (loosely until you have placed previous plastic carry through). Tighten battery holder to hold plastic strip which must be located over mounting bracket, carefully reinsert both electrical connectors (different sizes), reattach large PCB then small one, then screw back in cover. It is likely you will then be stuck on initial screen with unit not booting correctly. You must then do software resets (opened paperclip inserted into invisible hole next to connecting strip at back). It is likely that you will have to connect to Tom Tom HOME to do this. I failed here as the darn unit will not connect to my computer.
An awful piece of equipment- I have gone Garmin!
Mar 18, 2009 | Tomtom GO 910 GPS Receiver
My TomTom 510 will not hold charge and now cannot be switched on
If you are not bothered about using it on battery your tt should work if you have it hooked up to a external power supply such as the car charger or home charger. If it doesn't work using either of the power supplies then your problem is deeper than just needing a new battery. Check the pins on the bottom of your tt to see if they are bent, or out of place. The most common problem for them is the negative pin on the far left with the lcd screen facing away from you gets bent or is not making contact even though the green light is on.
Hope this helps
Mar 06, 2009 | Tomtom XL 330 Car GPS Receiver
Screen is blank, shorted out?
If you had the prongs backwards, you probably blew the input diode. I don't know of anywhere other than Tom Tom for service on these.
Feb 02, 2009 | Tomtom ONE 3rd Edition GPS
4 prong power cord that plugs into back is bent/broken
Don't try using the system as you are at danger of electrical shock - buy a replacement powerpack direct from Bose.
Dec 11, 2008 | Bose SoundDock digital music system...
Tomtom gps
The TomTom One is known to have sound problems on some units. The 2 main problems:
  1. The speaker is blown or distorted ( needs replacement ) ( some speakers out of old laptops will fit )
  2. The earphone socket on the base of TomTom is dirty or has bent contacts . ( slightly bent contacts will cause sound to dissapear or become broken-up )
Sep 15, 2008 | Tomtom ONE GPS Receiver
Tomtom power problems
you need to reset the system by holding a pin in reset hole for 15 sec. This is located at the base of the tomtom and is clearly marked(very small print but it is there)
Feb 10, 2008 | Tomtom GO 300 GPS Receiver
Blank screen
Reset the unit by pushing a bent paperclip or pin into the hole on the bottom marked 'reset' turn it back on, plug it in & charge it via USB overnight or as long as you can in the car, make sure the led on the top is green, tap the bottom right of the screen & check the battery symbol on the unit says charging underneath.
If this doesn't help.
If its NEW take it back!
contact tomtom about the problem...
Dec 16, 2007 | Tomtom ONE GPS Receiver
RX3715 Won't turn on or charge, won't respond at all!
unplug the screen and make sure none of the prongs are bent or broke at all.
Jul 30, 2007 | HP iPAQ RX3715 Pocket PC
Tomtom GO 300 GPS Receiver Logo
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
