Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door won't open
I hit the button on the wall mount or on my remote and the unit just buzzes and won't open. Sometimes it will open for about 5 days then doesn't work for 20. Any help out there?
Thanks
  • 2 more comments
  • jwkchansen Feb 11, 2009
    Problem just started today. Left the house, noticed door didn't close all the way so I hit the button again and it closed. Came home, and door would not open. Inside the garage, the wall button just makes the door motor "buzz". There is a lot of tension on one side of the chain. The motor says it is a LiftMaster Security + 1/2 HP.
  • scorp9311 Feb 14, 2009
    It is a Sears 1/2 horsepower. Model 139.53636SRT. I got it in 1994. It is chain driven
    Now I've think I've gone from bad to worse. I just went outside to get info on it and make sure the green lights were on the "eyes" of opener near the ground. I had a flashlight and pointed it in one of the eyes and the green light on one side went off. The other side is green. I measure from the ground and both eyes are the same distance from the ground and from the wall. I even moved them slightly up and down to try and get the other green light on and now it won't go on.
    Now when I hit the button, the motor buzzes and the light flashes..
    Now what?????????????
  • marty metzger May 11, 2010
    disconnet trolley. does it run? is door frozen down?
  • Rob
    Rob May 11, 2010
    What make and model do you have. What kind of drive is it?
  • 423 Answers
I don't know about the ground sensors, I do know they are a safety feature so it won't come down on something if the eyes are blocked. Try replacing the bad "eye"
For the buzzing noise, check the capacitor to see if it has blown out and requires replacement. To test this, you should be able to disconnect the door, open it manually, reconnect the door to the carriage assembly, and close the door using the GDO. The capacitor is only used to give the machine enough power to initially lift the door. It does not use the capacitor to close. Other signs to a blown capacitor is white secretion physically coming out of the capacitor. Get the MFD (microfarad) number range off the capacitor and the voltage (usually 220 volts, possiblye 330.) and find a replacement capacitor for the brand of your opener.
Posted on Feb 14, 2009
My Lift Master remote does not work. The wall mounted unit will open and close the door, but the remote control does not. I've changed the battery with a 1a battery from Radio Shack- but it still won't...
Check the wall console. If it has a lock button and the LED is flashing, the GDO is locked. None of the remotes will work, only the wall button. If it is locked, press the lock button and hold for a couple seconds and release. The LED should stop flashing, and the remotes should start to work.
If the door will open but not close, and the lights flash 5 times, check the door sensors. Make sure the sensors are aligned with each other, and the LEDs are both on.
Jan 11, 2011 | liftmaster 373lm Liftmaster Craftsman...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Opener Clicks only and LED blinking 5 times
Just fixed this problem tonight. Had the 5 blink/flash thing. Opened it up and saw that the motor wasn't spinning so it wasn't a bad rpm sensor. Jumped the red to black and then the blue to black to verify motor worked. At that point assumed it was the logic board not telling the motor to start, but I could hear the click of the relay. Pulled the logic board out and noticed a solder joint that had failed directly behind one of the relays. Resoldered that joint and the garage door opener worked again like a dream. Hope that helps someone else.
Feb 28, 2009 | Building Materials
Grage door blinking yellow, click and won't open with anything.
TRY RESETTING THE UNIT BY UNPLUGGING IT FOR ABOUT 5 MIN.
IF WHEN YOU PLUG IT IN THE REMOTES STILL DON'T WORK TRY TO REPROGRAM THEM.
IF STILL HAVING TROUBLE--
COUNT THE FLASHES - GOTO LIFTMASTER.COM DOWNLOAD A FREE PDF FOR A SIMILAR UNIT (THE MODEL NUMBERS ARE DIFFERENT BUT THE CODES ARE THE SAME).
HOPE THIS HELPS
Jan 24, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage Door only opens with wall unitq
The unit is in the lock mode, push and hold the lock button in for about two seconds and the green LED should stop flashing. Your remotes should work.
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Neither remote control will open door but wall mounted button wil
Make sure the code set inside the remote is the same as in the main reciving unit code.
Dec 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Remote only closes the garage door, will not open it
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
In your case the expansion of the wall in the afternoon may be enough to cause pressure on the wire to increase the problem – works in the morning but not the afternoon.
Also after you change the batteries you need to reprogram the remotes.
HOPE THIS HELPS
Aug 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
309 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
