Question about General Electric PT970 Microwave Oven
Built in oven takes hours to reach desired degrees set.
Pt970 model - not heating up to requested degree. I set the oven to 450 degrees at exactly 11am. It is now 1:38pm and the oven is only at 296 degrees. Why does it take so long. This is the 2nd time I am using the oven, I thought the first time would take long as it is new, but 2+ hours and still not at 450 is crazy. Can you help me please?
  • General Master
  • 9,098 Answers
There may be a problem with either the door seal or the thermostat.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails, you can download GE owner's manuals and installation instructions here in case you don't have yours.
Once you look it over, if you still have a problem,
GE Customer Service is here and they should be able to help you check it or send service if you have a problem.
Posted on Feb 08, 2009
While using the oven setting on our GE Profile Advantium, at 450 degree setting, the oven stopped mid-baking. I feel there is a fuse for this? is it easy to do ourselves or should we get an expert?
I regularly repair these.
Feel free to contact me via my site with your full model number and FCC ID number as shown on the tag in or on the oven for free help.
Nov 26, 2016 | GE Microwave Ovens
Panasonic microwave does not achieve desired temperature
They never do ! You have to check the temp at where the air comes out of the fan and you need to use a remote electronic thermometer.
the old oven type won't work sitting on a the shelf. 275 degrees at best. Take it back it's not broken ...the just don't work as advertized
Apr 07, 2014 | Panasonic NNCS596S Microwave Oven
Thermador warming drawer takes 45 minutes to reach 190 degrees on high setting! That can't be right! Tech support said it should be 220 degrees on high and should take 20 minutes to fully heat.
I recommend that you go with your microwaves and claim to fix it. This can be a problem with magnetron, or power diode, capacitor faulty, or thermostat.
God bless you
Oct 27, 2013 | Thermador 30 inch Convection Warming...
PT970 combo oven: microwave does not heat. tried all combinations of settings, no heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
May 06, 2011 | General Electric PT970 Microwave Oven
When I preheat the oven it takes an hour to reach 200 degrees. Is this normal? I am sure it was a lot quicker than this.
An hour to go from room temperature to 200 degrees F (or even C for that matter) is unacceptable.
There is a problem with either a control, sensor or heating element. You should have this oven serviced to restore it to proper working order.
Mar 30, 2011 | Microwave Ovens
Have samsung american fridge freezer with ice dispenser i bought it second hand the problem is the digital display says the freezer is 20 degrees but its freezing inside also every minute or so we hear a...
If it's American, the temperature probably reads as fahrenheit. If so, 20 degrees F is 12 degrees F below freezing which converts to only -6.67 degrees Celsius.
Domestic freezers should be set to -17 degrees Celsius (= 0 degrees F), so the beeper is warning you that the freezer compartment is far too warm. If it's working correctly and has the temperature control set correctly, then it should achieve the correct temperature if you leave it for 24 hours and do not open the door nor try to use the ice dispenser. If the freezer is full of unfrozen items and so has to cool those down as well, then it may take even longer to reach the correct operating temperature.
Te operating manual for your appliance will tell you how to set the temperature correctly and whether it's possible to select between fahrenheit and Celsius scales. Most models allow you to set an override on the beep alarm as well. I cannot guide you on this without knowing the exact Samsung model.
Please take a moment to rate my reply.
Sep 22, 2010 | Microwave Ovens
15 yr-old GE electric oven takes over an hour to preheat to 450
After jiggling the lower burn element the oven heated up in the normal time. Perhaps a connection had come loose.
Feb 14, 2009 | GE JEM25 Microwave Oven
Sharp R-1874F Low Convection Temp
We have the 2 service manuals you need to refer to for this model and have uploaded them to our site here and here to help you.
You will need the
free Acrobat Reader to view or print them in case you don't have it.
The manuals have a safety info, disassembly info, troubleshooting chart, test procedures, part numbers, etc.
I would first suspect a bad thermistor, but it should be checked, as well as the line voltage at the outlet, etc.
The best place to order parts for this brand is Encompass (formerly Tritronics). Or you can call them toll-free at 866-779-5835.
Jan 08, 2009 | Sharp R-1874 Convection/Microwave Oven
Convection Preheat doesn't reach the Chosen Oven Temperature
I would first suspect the thermister (thermistor) or a low line voltage, weak control board relay etc.
But the service manuals will show you how to safely disassemble, test and repair the unit.
We have the service manuals for this model and have uploaded them to our site here and here to help you.
You will need the
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 04, 2009 | Sharp R-1870 Convection/Microwave Oven
General Electric PT970 Microwave Oven Logo
50 people viewed this question
Top General Microwave Ovens Experts
William Miller
William Miller
ken skalski
Steve Mason
Are you a General Microwave Oven Expert? Answer questions, earn points and help others
