Question about Denon AVR-886 Receiver
I reset the microprocessor that my denon avr-886 , but is not working
  • tango0672 Feb 01, 2009
    I have denon avr-886, the button power indicator is flashing rapidly ( red) , I reset did the microprocessor but i still have the same problem , turns off the receiver.
  • John Weinreich May 11, 2010
    You need to be more specific what won't it do? no power? no audio? turns off? re-post with more info.
  • 336 Answers
One or the output channels is probably bad you can check for a short on the output transistors using an ohm meter. Make sure that the receiver is un-pluged. The ouput transistors will be on a large heat sink.
Posted on Feb 01, 2009
Denon AVR-1513
disconnect speakers then try again if still shutting down you will have bad outputs.
Aug 26, 2014 | Denon Audio Players & Recorders
Denon avr-1612 keeps shutting off and on
You have an output problem, check outputs for short
Apr 07, 2014 | Denon AVR-1612 5.1 Channels Receiver
Denon AVR-1912 firmware upgrade failed
I'm having the same problem, Denon has taken down the firmware upgrade for yours ( and mine) AVR-1912. My receiver is also stuck in the update fail loop. Supposedly they will have it back up, but I don't know the timeframe.
Lots of others are having the problem with the firmware upgrade. Go to
http://www.avsforum.com/t/1334369/the-official-denon-avr-xx12-model-owners-thread/16380
and that should help you out, though I can't say how much. I've gone as far as resetting the microprocessor, but it keeps trying to update, and then fails...
Dec 12, 2012 | Denon AVR-1912 3D Ready A/V Receiver - 90...
How do I restore factory defaults on my Denon AVR-2809? I can't see it in the manual. Thanks
Register and download the USER GUIDE (10.6MB) for free at retrevo.com
http://www.retrevo.com/support/Denon-AVR-2809CI-Receivers-manual/id/21864dj590/t/2/
Page 60
Resetting the Microprocessor
Perform this procedure if the display is abnormal or if operations cannot be performed.
When the microprocessor is reset, all the settings are reset to their default values.
1 Turn off the power using <POWER>.
2 Press <POWER> while simultaneously pressing
<STANDARD> and <DSP SIMULATION>.
3 Once the display starts flashing at intervals of about 1
second, release the two buttons.
Mar 30, 2011 | Denon Audio Players & Recorders
How do I reset my Denon avr-589? I would like to reset my reciever back to original settings.
Press the power button, and speaker a and speaker b simultaneously and hold until the display begins to flash then release speaker A and speaker B buttons. That resets the microprocessor.
Jan 02, 2010 | Denon AVR-1508 Receiver
No display; No power
Your unit has a hard short in it. This is usually a power supply problem. Most likely the rectifier has failed. This should be a relatively simple and inexpensive repair. Figure on $10 for parts plus the local labor rate.
Dan
Jul 16, 2008 | Denon AVR-1804 Receiver
My denon reciever display wont't work
I read something the other day in the user manual about re-setting the microprocessors if the display doesn't display properly. Turn the amp off.  Hold down the input mode & analog buttons while turning power on. The whole display should flash on & off at 1 sec intervals, then release the two buttons. This resets the microprocessors & supposedly fixes display problems.
Jun 23, 2008 | Denon AVR-2805 Receiver
My Denon AVR-887 Keeps turning itself off
I have one and the same thing happened. try resetting your microprocessor and if that does not work, then check the wiring of the speakers. if that is working fine and no wires are touching then I unplugged everything and was still having the issue. took it in for service and it was found that the transmitor was shorted as the speakers that I was using was too high in ohms. it is possible that it could be your caps also if resetting the microprocessor does not help. You can find out how to reset the microprocessor from your manual. If you have the Denon avr 887 with the system turned off hold the power on button and the speaker A and B at the same time for a few seconds. This is compatible to rebooting your computer. Hope this works for you as this was and is my husbands favorite past times.
Dec 01, 2007 | Denon AVR-887
Denon AVR-886 Receiver Logo
224 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
