Question about Amana ALE643RB Electric Dryer
Amana dryer doesnt heat up
I have an electric Amana dryer that runs good (tumbles) with no noise, etc. It simply will not heat up. How do I determine if it is the control setting switch, thermostat or heat element
  • bkrmd93 Feb 17, 2009
    ALE634RAW dryer...drum turns, won't heat up...breakers at my house panel are NOT tripped, breakers are OK...any suggestions?
  • 547 Answers
No heat. heat element
Posted on Feb 11, 2009
My Amana Heavy Duty Dryer will not heat up. It tumbles but it doesnt warm up. WE have cleaned out the the machine and the vent to the outside.
You didn't state if it is a gas or electric dryer. If gas the igniter element is bad, if electric the heating coils need replaced. Goodluck Google burdfrenzy
Nov 26, 2010 | Amana Dryers
My electric dryer runs but no heat.
Hello there:
There's no heat If your dryer doesn't heat, check these: Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
I will post the pictures of the heating element in a seperate post
Best regards mike
May 27, 2010 | Amana NDE2335AY Electric Dryer
The problem I am having with my Amana model NED7800AYW makes a loud noise when running
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgs453q2
May 15, 2010 | Amana NDE7800AY Electric Dryer
No heat
Your dryer needs 208 - 220 volts for electric heat. If you have determined (in some way) that you have sufficient voltage coming to the dryer, then your issue may be a defective heat element, thermostat, timer, etc. Contact an appliance service company.
Apr 14, 2010 | Amana NED5200TQ Electric Dryer
Dryer screeches
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Apr 14, 2010 | Amana NDE2330AY Electric Dryer
My maytag dryer is making a loud noise when tumbling the clothes. It is heating up okay
heatman101
hfgh
Feb 02, 2010 | Maytag Neptune MDE4000 Electric Dryer
My amana electric dryer starts (makes noise, heats) but the drum does not turn or tumble. What can I do?
there is a big belt inside that turns the drum , your belt maybe slipped off or broke.
Aug 20, 2009 | Amana Dryers
My Amana dryer LEA30AW makes a loud knocking noise while running and then shuts down. There is heat. It seems to be worse with a larger load. Any ideas??? Thx
heatman101
fo
Jun 08, 2009 | Amana NDE2330AY Electric Dryer
Amana ALE643RB Electric Dryer Logo
656 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you an Amana Dryer Expert? Answer questions, earn points and help others
