Washing machine drain hose/pipe leak
Where the drain hose goes into the plumbing pipe next to the washing machine, water starts coming out out the top of the pipe when the machine is running. The black drain hose hangs down into the white pipe.
We have tried snaking it from inside and from the roof with no luck. any suggestions?
  • 15,935 Answers
Make the standpipe longer (the black pipe).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
2 Suggested Answers
  • 2920 Answers
SOURCE: Leak from pipe/wahing machine drain hose
try running the snake from the top to the bottom. they ell pressure hose ends that you inser into the pipe on the end of a hose and when you turn the water on it weslls and applies pressure to push out whatever is in there. they cost about 8.00 and you can buy them at lowes or home depot. just tell them what you need and that it screws onto the end of a hose for unclogging backed up drains. im not sure whats its called but they will know
Posted on Feb 01, 2009
The washing machine fills constant and water drains out straight away.
your drain hose is installed incorrectly. it rise at least 36" or so (preferably higher) before it enters the stand pipe (drain pipe connected to the houses plumbing), and there has to be an air break (i.e., not sealed off where the drain hose enters the stand pipe). hope this helps.
Mar 06, 2011 | Washing Machines
Is it possible to slow down or reduce the rate at which water drains out of the washing machine? My drain line is restricted and if the load is more than "Small", it drains too quickly and starts...
There is no flow adjustment on the drain on any washing machine, I had a similar problem on my old washing machine, I discovered the problem was the waste water pipe in my house was clogged with scum from detergent residue, I poured liquid plumber where the washing machine drain hose goes into the waste pipe in the house waited for 1/2 hour, then filled the washing machine with hot water, reinserted the drain hose, and wrapped it up with duct tape to prevent further leaks, and the force of hot water uncloged the pipe, .Problem solved
Nov 08, 2010 | GE WHRE5260E Top Load Washer
Automatic washing machine plumbing requirement
The automatic clothes washing machine counts on a pressured water system - like what is provided in a town / city or from a well that has a pressure system to deliver water at pressure like when you open a valve for a bath tub, sink or shower.
You need to have a plumber provide valve/faucets for both hot and cold water. The valves are sometimes called a "hose bibb" with a threaded end that the hoses connect to and then are connected to the back of the washer. When the hoses are connected and the valves are open, the automatic washer will open a solenoid valve when the time is right to allow water to flow in, then closees. Some owners keep the hose bibb valves open forever after they connect the washer, others close the valves after they are done washing all loads for the day/week.
You will also need a drain provided that connects into the house plumbing. The Whirlpool Duet provides the drain hose from the washer which drops into the pipe the plumber provides. It is important that the drain pipe allow air to move past the washers drain hose, to allow proper draining.
Hope that helps. Please post back how things come out, OK?
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Jan 08, 2010 | Washing Machines
Feb 01, 2009 | Estate TAWX700JQ Top Load Washer
After washing cylce complete; 3-4 inches of water is left
it sounds as tho water is getting intyo machine after use. there are 2 possible causes.
either
inlet valve leaking. turn water off and see if this stops water accumulating. if it does, then you need to replace valve to cure.
or
if drain is plumbed into spigot on sink trap then every time you drain sink, some of the water goes down the drain hose.
to cure, take the drain hose up as high as possible in a swan neck
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I, Just got a new washing machine about 2 weeks ago it is a indesit WIB101. The Problem Is That When The washing is finished, the next day it still has 3-4 inches of water left in the bottom of the drum
i bassume the water is coming in after cycle finished. source can be two things.
water valve leaking - not probable on a new machine but to check, turn water off and see if water comes in.
if drain is plumbed into a spigot on the sink trap, when you empty the sink, some of the water will go down the drain hose. to cvure, take the drain hose up in a swan neck as high as possible
Sep 14, 2008 | Indesit Washing Machines
Drain and vent
vent pipe in the house?sounds like a plumbing issue in the house. unless your drain hose is to far down the drain pipe.
Apr 14, 2008 | Whirlpool LSR5132PQ Top Load Washer
Washing machine
there is a tool that hooks to you garden hose that goes in your pipe and expands then blows water down the drain to blow out stoppage it work great you can get it at your local hardware store
Dec 20, 2007 | Washing Machines
Water overflowing from drain pipe
The problem with the new washing machines, is that they dump 20-22 gallons of water in 4-5 seconds. This amount is far more than the garden hose test will submit the drain to. Here are a number of solutions, I hope that one of these will help you.
#1 As mentioned above, you can restrict the flow of the drain pipe. I recommend a 3/4" x 6" brass nipple, or a 1/2" x 6" brass nipple, depending on your specific situation. The brass nipple will not corrode like a galvanized nipple.
#2 There is also a rubber cap that you attach to the drain pipe that fits around the drain hose tightly.
#3 Some situations might require that you have to raise your drain pipe. It is recommended that it be at least 36". This allows for gravity to assist the drain.
#4 Some situations will require that the drain pipe be increase in diameter. Older plumbing applications were installed using 1 1/2" piping. With the newer washing machine discharge volume, the 1 1/2" pipes will not support the discharge. Your drain line will need to be changed to 2". This option will be one of the more costly fixes, depending on the amount of line that needs to be changed.
#5 Some plumbing installations installed without a p-trap will need to be changed. The p-trap keeps sewer gas from coming back into the house. It also allows for a smooth transition into the drain line. Any restrictions in the drain line (i.e. ells, tees,) will cause the soap in the gray water to foam up which will cause the drain line to slowly back up.
I hope these solutinons help.
Jun 03, 2006 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
1,923 people viewed this question
Top Washing Machines Experts
