Question about Bissell 9200 Upright Vacuum
Bissel proheat 9200 - trigger not working properly
Cleaned out entire machine & the only problem appears to be the trigger.
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Bissell - ProHeat Mod. # 9200 05240C - No
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
hjghkl
Posted on Sep 30, 2010
How do I get Bissell Proheat 2X to work. Not dispensing water.
Did you clean the filter on the water tank. It's generally a red screen type device. Additionally, there is a filter under the Flow Indicator, unscrew the cap, lift out the propeller, lift the filter screen and clean it. Reassemble in reverse order. If you occassionally run one and half cups of white vinager through the machine it will clean out the calc buildup. Additionally, the filters should be cleaned after each use.
Feb 07, 2016 | Bissell Brushroll Proheat 2X 8920 9200...
Bissell proheat 2x carpet cleaner 9200 How do i
heatman101
teyet
Jul 22, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
heatman101
hjghkl
Jun 07, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
I have bissell proheat 2x 9200 no water or cleaning solution is dispensing from bottom of machine hand dispenser is not working too. how can I troubleshoot it?
Ensure you have water in tank and solution (or water in solution tank). When you start the vacuum up, the pump starts to prime itself. If you have air in the system, it takes a little longer to prime. Allow the vacuum to run for 1 minute before attempting to pull the trigger. Then pull the trigger.
If this doesn't work, you'll need to open the unit up and check the hoses for any clogs, and next test the pump to see if it is functioning.
Jan 21, 2010 | Bissell 9200 Upright Vacuum
When I turn on my bissell proheat 9200-T, it starts leaking
It could be that one of the hoses came loose on the inside. It would be best to take out the screws in the black plate, and open it up to see where the source of the leak is on the inside.
Apr 10, 2009 | Bissell 9200 Upright Vacuum
Bissell Proheat 2x 9200
Sep 04, 2008 | Bissell 9200 Upright Vacuum
Schematic parts diagram for bissell proheat 9200 carpet cleaner
Hi, just go to amazon here: Amazon com bissell proheat carpet cleaner parts and you can find every needed parts. I hope this was helpful. Cheers
Jul 24, 2008 | Bissell 9200 Upright Vacuum
Bissell 9200 Upright Vacuum Logo
241 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
