I need instructions on how to remove and replace the brush. I have lost my manual
Hi!
To replace the Brush Belt:
You will need a Phillips head screwdriver.
1. Turn the machine OFF and unplug from the wall outlet.
2. Step on the release pedal to lay the handle down on the floor.
3. Remove the Tank-in-Tank and SmartMix Bottle and set them aside.
4. Turn the machine over to expose the brush.
5. Look for the red retainers, which hold the black brush arms and gear-type brush belt in place. Unscrew the two Phillips head screws. Set these parts aside.
6. Loop the replacement brush roll belt around the brush end and the red pulley with the ridges.
7. Alternate holding each brush arm in place while replacing the red retainers.
8. Replace the Phillips head screws and turn until snug.
9. Turn the machine right side up to replace the Tank-in-Tank and SmartMix Bottle.
Thanks
Hi there, try this link. this should help ya:)
If you turn it upside down you should find several screw holes . they are phillips head screws. you have to take the bottom of the machine off to get to the brush and removing the screws will allow you to do so. once the bottom is off you can pull the old brush and put in the new one
it may be broken you wouldnt know unless you go to change out the brush as you are doing.you might want to invest in a new one rather than try to find parts for this one.
if there is a piece missing or broken then you need to replace the machine.it stands to reason that if its broken to replace it
The housing that holds the brush is not secure. I don't know if something is missing or broken
This was no help.
This was no help.
